Trie Pressure with ET Street Radials #284423
04/11/09 08:37 AM
04/11/09 08:37 AM
U.S.
moparniac Offline OP
U.S.
What is the desired pressure at the track with 315/60/15's ET SWtreet Radials... 16-18psi
Mopar Performance
Re: Trie Pressure with ET Street Radials [Re: moparniac] #284424
04/11/09 09:24 AM
04/11/09 09:24 AM
Northeast, Alpine, NY
9
9 Sec Phill Offline
On a road near you
9 Sec Phill  Offline
On a road near you
9
Yes, I started at 18 and stayed there, tried going down and then up but they liked 18...Phill
Re: Trie Pressure with ET Street Radials [Re: 9 Sec Phill] #284425
04/11/09 09:25 AM
04/11/09 09:25 AM
Illinois
moparmattkos Offline
mopar addict
mopar addict
Illinois
16 - 18 will work real good. My car really liked 16 seemed to hook like crazy!!
www.sikosracing.net Heads up Drag racing
Re: Trie Pressure with ET Street Radials [Re: moparniac] #284426
04/11/09 11:52 AM
04/11/09 11:52 AM
Every tire gauge reads a little different(1/2 to 3 lbs on some) than others usually, try 16 to 22 on yours ands use the pressure that gets you the best 60 ft times My car with the big motor in it didn't change 60 ft. times from 18 to 20 lbs, so I used 18 lbs on a digital gauge. BTW, buy a good gauge and DON'T loan it out
Re: Tire Pressure with ET Street Radials [Re: Cab_Burge] #284427
04/11/09 12:07 PM
04/11/09 12:07 PM
U.S.
U.S.
I have a real nice one.
Mopar Performance
Re: Tire Pressure with ET Street Radials [Re: moparniac] #284428
04/11/09 04:44 PM
04/11/09 04:44 PM
Alliance, Ohio
V
Valiant_Showoff Offline
V
Alliance, Ohio
My ET Radials like 17 psi.
