1957 Dodge truck?? #2843407
11/08/20 11:08 AM
11/08/20 11:08 AM
mn
flyman Offline OP
flyman  Offline OP
mn
So I have put some money down on another 1957 D100 its a V-8 with a 4 speed in it now. The question that I have is will a later model bell bolt up the motor thats in it now.
I believe that the truck has the original motor and trans still in it. Thanks for the help..
Re: 1957 Dodge truck?? [Re: flyman] #2843545
11/08/20 04:50 PM
11/08/20 04:50 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The pre-'62 V-8 crankshaft flanges are way different and they extend further from the block, so you need an adapter to use the later bellhousing.
Re: 1957 Dodge truck?? [Re: John_Kunkel] #2843828
11/09/20 09:26 AM
11/09/20 09:26 AM
AZ
Mike P Offline
Mike P  Offline
AZ
Hard to say for sure without knowing exactly what engine is in it.......I believe the original V8 in this "should" be a 315 Dodge Poly.
John is right about the crankshafts and needing an adapter. The Dodge Poly's will take the same adapter as the first generation Hemi's which are available from several sources including Hot Hemi Heads.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold
1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold
1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears) under construction
Re: 1957 Dodge truck?? [Re: Mike P] #2844989
11/11/20 05:45 PM
11/11/20 05:45 PM
mn
flyman Offline OP
flyman  Offline OP
mn
Thanks for the replies. Thats what I thought.. Guess I will wait till its here till I decide what to do. But I do want a 5 speed behind it.
