Decode this 440 pad please #2842333
11/05/20 10:17 PM
11/05/20 10:17 PM
Eyewa
330Scott Offline OP
330Scott  Offline OP
Eyewa
I forgot how to do this and instead of figuring it out, thought someone here can tell me in a nano-second. Please.
The number between the 10 and the HP2 is a 5.
The engine is in my '68 Coronet R/T
Thanks,
Re: Decode this 440 pad please [Re: 330Scott] #2842337
11/05/20 10:21 PM
11/05/20 10:21 PM
Kirkland, Washington
Pacnorthcuda Offline
1968 440 high performance (magnum) assembled on 2nd shift. I think the 10 5 refers to October 5th but other people here will know.
Re: Decode this 440 pad please [Re: Pacnorthcuda] #2842408
11/06/20 02:54 AM
11/06/20 02:54 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
iagree & it should have a partial VIN stamping back by the oil pressure sending unit scope
Re: Decode this 440 pad please [Re: 330Scott] #2842822
11/07/20 01:34 AM
11/07/20 01:34 AM
Eyewa
330Scott Offline OP
330Scott  Offline OP
Eyewa
Thanks, guys.
I am going to guess that the "D" stands for the model year, i.e. 1968 in this case.
I have a 1965 383 and the top line reads A 383 so I am guessing again that Chrysler started using the alphabet to stamp their blocks in model year 1965.
I also have a 1974(?) 440 and the top line of the stamping reads "6T440E". WTH does that mean?
Re: Decode this 440 pad please [Re: 330Scott] #2842843
11/07/20 03:10 AM
11/07/20 03:10 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
6T440E
6 = 1976 model year
T = Trenton, MI engine plant
440 = displacement
E = cast crankshaft
is the '68 440HP original to your R/T? if not, can you share the VIN stamping?
Re: Decode this 440 pad please [Re: 6bblgt] #2845972
11/14/20 12:41 AM
11/14/20 12:41 AM
Eyewa
330Scott Offline OP
330Scott  Offline OP
Eyewa
Thanks again.
Turns out that I have a book by Chuck Senatore that has the answers in it. Duh me
I still haven't crawled under the car to check the VIN stamping on the block. whistling Busy guy, ya know. rolleyes Yah, right...
