Predator Engine #2839470
10/30/20 09:17 PM
10/30/20 09:17 PM
Greensburg, Pa
Mpetros Offline OP
Mpetros  Offline OP
Greensburg, Pa
What's the highest real world horsepower anyone has ever seen out of a Predator Headed Engine with a single four?
What Ci and what RPM did it make peak horsepower?
Re: Predator Engine [Re: Mpetros] #2839567
10/31/20 04:20 AM
10/31/20 04:20 AM
Queensland,Australia
T-bar Online content
T-bar  Online Content
I got a 596" with only 800 thou lift though but 14.3 compression on 112 race gas went 1061 hp on engine dyno and on E85 it went 900 to the hubs running through a 727 and a 9" with a single 1250 APD 3 circuit
Re: Predator Engine [Re: T-bar] #2839781
10/31/20 02:47 PM
10/31/20 02:47 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
This was one that was done last year. Heads are based off the CNC program from my heads from Slawko and intake was ported by Slawko. Carb is a CFM 2.200" throttle blade piece. Its been 5.70 in a stock bodied B body on Caltracs and could take some nitrous as that was the intent originally. Owner has not even tried as he is happy as is. Car is 3900lbs with driver I hear. All steel all factory glass interior etc. Bear in mind dynos are dynos. I actually have a single 4 for mine that will be getting ported soon, I'm sure it cam make those numbers or a bit better with enough carb and mine is a tad smaller cubic inch wise.
Re: Predator Engine [Re: Al_Alguire] #2839899
10/31/20 08:37 PM
10/31/20 08:37 PM
Greensburg, Pa
Mpetros Offline OP
Mpetros  Offline OP
Greensburg, Pa
You guys running a Iron Block or Aluminum?
Hemi or Wedge Block?
Re: Predator Engine [Re: Mpetros] #2839954
10/31/20 10:14 PM
10/31/20 10:14 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Mark have you ever talked to Dave Norris that races at Keystone about his. They have one in his wife’s dragster.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Predator Engine [Re: pittsburghracer] #2839968
10/31/20 11:07 PM
10/31/20 11:07 PM
Greensburg, Pa
Mpetros Offline OP
Mpetros  Offline OP
Greensburg, Pa
I have not. PM me his number I would like to talk to him
Re: Predator Engine [Re: Mpetros] #2840466
11/02/20 01:57 AM
11/02/20 01:57 AM
Mines a World alloy block about 2004 model i think.
Re: Predator Engine [Re: Mpetros] #2840628
11/02/20 11:53 AM
11/02/20 11:53 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Mine is a Wedge as is the one listed. I 99% sure T bars is a Hemi as I know the previous owner.
Re: Predator Engine [Re: Mpetros] #2840651
11/02/20 12:33 PM
11/02/20 12:33 PM
PA.
"Little"John
"Little"John
PA.
Mark I sent you a PM.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Predator Engine [Re: pittsburghracer] #2840884
11/02/20 07:13 PM
11/02/20 07:13 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
This is what you can do with predator heads. This one is a 660. 5.125 strokes 4.53. I just dynoed this one again after damaging it about a year ago. The motor made more power before the repair NA because the chamber was smaller by 12 CCs. The motor is better for nitrous with the slower, larger chamber so I'll leave it as is. The damage came from using the junk che guides indy provided with the heads (I know better but didn't want to wait for real guides). The guides have but one saving grace. I dont think they'd ever grab a valve as long as you could beat it into the guide. The down side is they break with any real heat if you leave any part of them exposed in the exhaust. The result looks like a cigarette load expoded, all mushroomed out with frags going everywhere. I run 2.49 intakes, and shrank the exhaust down to about .04 between them in overlap. Losing control of the exhaust valve when it closed on a frag wacked the valves together and broke a spring. To fix it required sinking the valves and blending the camber back down to the valves giving me 12 more ccs. Taking compression from 14 to 13.
Chuck at best just did a smaller one that got over 1300 too so for anyone that wants to say it cant be done, tell chuck too lol. A max effort NA will make 1400 if you go after it properly. This sheet is with the larger chamber down close to 30 from the chamber increase. Also now requires 1.5 more degrees timing
Starting from scratch use a hemi block . The wedge requires plugs in the intake to access the inner valley bolts. Limits porting, and weakens the guide boss.
Re: Predator Engine [Re: dthemi] #2840911
11/02/20 08:06 PM
11/02/20 08:06 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Sombody said, to do the Predator right, you need to change the lifter bores on the Hemi block as well. What were they referring to, angle, or spacing? Does the stock Hemi layout work, or do you guys order a special Hemi block?
Re: Predator Engine [Re: Dragula] #2841022
11/02/20 11:23 PM
11/02/20 11:23 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
You can use a 48 degree block, but you'll need to use a key way lifter of a something like a ts jesel tie bar, where the bar is between the tappets, not over them. The pushrod will hit normal tappets. Having the block on a 45 is better.
Re: Predator Engine [Re: dthemi] #2841027
11/02/20 11:46 PM
11/02/20 11:46 PM
Dragula Offline
Dragula  Offline
So is that a lifter angle of 48*....But stock spacing?
Re: Predator Engine [Re: Al_Alguire] #2841064
11/03/20 03:43 AM
11/03/20 03:43 AM
Yes mine is a hemi block.
Re: Predator Engine [Re: T-bar] #2841149
11/03/20 10:44 AM
11/03/20 10:44 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
45 degree for standard cam height, and 48 for raised cam normally. Having the option to choose, go with raised cam 45 degree cam bank angle. All it does is stand the tappets up more in line with the pushrods. Spreading always helps, but isn't necessary. Most shelf tappets will deal with .100 spread. .05 each direction. Straightening the pushrod is a good thing for as much as it's feasible. Like I said earlier a 48 will cause issue with the tie bar on standard type roller tappets. Jesel makes a center tie bar that works on a 48, but they're around 3 thousand dollars. They are worth the coin if you're stuck on the 48
As for cam tunnel, a 54.5 mm is 2.125 ford cam size. 55, 60, 65, 70 in my opinion is unnecessary given the rpm range these heads work at with normal cubes. You'll have rod to cam clearance trouble with aluminum rods anyway, so why compromise the rod with a huge cam core that doesn't help anything at these rpms. Go to a 1 inch tappet with a larger wheel than a .904 if you can, and run 1.9 ratio rockers if you're running shelf stuff.
Re: Predator Engine [Re: Dragula] #2841153
11/03/20 10:47 AM
11/03/20 10:47 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
You don't have to change any of it, but you'll need a center bar lifter like the jesel ts tie bar if your block is 48 degree cam bank angle.
In a perfect world I'd do a 45 degree raised cam, +.5 deck block with the lifters spread .1 in each direction for a total of .2 spread. Going more than that on a stock config block will cause the lifters to hit the center cam bearing.
Re: Predator Engine [Re: dthemi] #2841308
11/03/20 03:24 PM
11/03/20 03:24 PM
Dragula Offline
Dragula  Offline
Next question, why are the heads still $12k?
A guy like me that has pretty much wants to go fast in a bracket type car would love to do a 572 or 605 one of these, but the heads at $12k puts it out of my range by a bunch...Is there really that much machining in them? I am thinking these would be way better than my Hemi heads that flowed in the 450's.....So technically, all I would have to do is change cam, pistons, heads & intake, headers. vs. maybe RBRE rockers......Sure lowers the possibility of a dropped valve some.
Re: Predator Engine [Re: Dragula] #2841406
11/03/20 07:30 PM
11/03/20 07:30 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
12 G is with manifold valves springs rockers covers. They are the best thing out there as far as I know.
The hilarious part to me is I was just looking at a hammer headed small block ford at engine systems. 500+cfm small block head, copied after a boss 9 head. 400ci 1100 hp at 10,000 rpm NA. Those heads are cheaper than the predators lol...they also use a wedge manifold so there are dozens of shelf manifolds . Single 4, 2 x 4, blower , turbo, efi shelf manifolds...those heads are also offered as direct bolt on for the chev LS platform...alas, no mopes
I so wish mopar had these options. I still love a blown hemi though...and that still is the top dog in all drag racing period end of story lol
Re: Predator Engine [Re: dthemi] #2841655
11/04/20 12:35 PM
11/04/20 12:35 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
My stuff is clearly not worthy here for sure. As for the price its like most other things IMO the "mopar tax" can be high on some stuff. There are alot of Predator headed engines around here in the midwest for sure, I was actually surprised at how many there were honestly. I went to a Q16 race at Kil Kare and there were 4 other Stratus's there I was in shock. All but one had a Predator, I was the only NA one there as well as a couple predator dragsters, a Duster and a Barracuda.
Re: Predator Engine [Re: Al_Alguire] #2842042
11/05/20 08:27 AM
11/05/20 08:27 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
I don't see many in georgia either, unfortunately. The mopar tax is for sure a thing, and in some ways self inflicted. Every new mopar product has to endure years of scrutiny, and derision, to the point of failure before anyone will buy it. Ford, and chevy has such a large base, anything made will sell enough to keep the doors open. Our mopar providers take it on the chin, even with a home run product like these predator heads. These heads should be the must have head, period. Should indy see enough sales, they might consider doing what need be done with them. The ports are so small in these heads to start with, it takes effort to get them opened up enough to work, and even at that it's not enough.
We can still thank the 426 hemi for keeping the brand relevant. I watched all the 481X stuff be hailed as the next thing to overtake the hemi. Now I see them all coming out, and hemis going right back in lol.
