69 Rallye dash circuit board ? #2841402
11/03/20 07:14 PM
11/03/20 07:14 PM
IL . usa
cjs69mope Offline OP
IL . usa
Hello ,
I was wondering if anybody knows of a source to get the pins (new) for the circut board on back of a 69 rallye cluster .
One on mine is missing would be an easy fix to solder back on if i had some .
1969 Dodge Charger 1969 Dodge Superbee
Re: 69 Rallye dash circuit board ? [Re: cjs69mope] #2842009
11/05/20 01:01 AM
11/05/20 01:01 AM
GMP440 Offline
GMP440  Offline
Originally Posted by cjs69mope
Hello ,
Thinking out of the box; would needle bearings from an old u joint fit in? Maybe if you had a an old u joint lying around, try to see if the needle bearing will work.
