Taller Upper Ball joints #2840805
11/02/20 04:56 PM
11/02/20 04:56 PM
On the parachute mount
N
n20mstr Offline OP
n20mstr  Offline OP
N
Any one use them ?? I see some no prep and street races use them for more travel and to correct the camber issue. Was thinking of trying a 1" taller one.
NO im not interested in a whole aftermarket front end because i cant lighten the car and then add the weight back ...LOL
....BAD A$$ STREET CAR.....
Re: Taller Upper Ball joints [Re: n20mstr] #2840898
11/02/20 07:29 PM
11/02/20 07:29 PM
Fredericksburg Va
P
plycuda Offline
plycuda  Offline
P
Fredericksburg Va
do they pull in camber or push out. my one car I mess with no prep my car sits low so it gives it more up travel. i might have to look into these.
Re: Taller Upper Ball joints [Re: plycuda] #2840904
11/02/20 07:51 PM
11/02/20 07:51 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
FMJ body Spindles are 3/8” taller. A redesigned upper arm can help as well.
Doug
Re: Taller Upper Ball joints [Re: n20mstr] #2840926
11/02/20 08:27 PM
11/02/20 08:27 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I have ran the taller spindles for years on my cars. I also shorten the rear arm of the upper control arm 1/4" or so by the upper bushing and use the offset bushings. Have never tried the taller ball joints, but they sound like a good idea, too.
Master, again and still
Re: Taller Upper Ball joints [Re: n20mstr] #2841950
11/04/20 10:04 PM
11/04/20 10:04 PM
Minnesota, USA
humpty Offline
humpty  Offline
Minnesota, USA
I run these with a 1" longer stud to correct negative camber on mine:
https://www.qa1.net/circle-track/ro...-ball-joints1/screw-in-style-ball-joints
They increased travel as well up
