727 band strut install #2840256
11/01/20 04:15 PM
11/01/20 04:15 PM
templeton,ma
coro500net Offline OP
templeton,ma
I have a fresh rebuilt 727 on my bench, I’m installing an A&A valve body and low reverse servo. I changed the servo but a big issue getting the band strut back in . I used a screwdriver to try to force it in but no luck. Is there a special way to do this or a lot of force? Took adjuster al the way out.
Looking for any input.
Thanks!!
Re: 727 band strut install [Re: coro500net] #2840328
11/01/20 06:30 PM
11/01/20 06:30 PM
SW CO
HemiSportFury Offline
SW CO
No special tool is required, so something is not right. Better look things over carefully.
'64 Sport Fury, 528 Hemi, FiTech EFI, 4-speed, 4.10 Dana 60
'57 Belvedere 2dr sedan, current project in process
'19 Cherokee Trail Hawk Elite
'03 Ram 2500 CTD HO, 6-speed 214,000 miles and still going strong
Re: 727 band strut install [Re: HemiSportFury] #2840377
11/01/20 08:36 PM
11/01/20 08:36 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iagree
Re: 727 band strut install [Re: TJP] #2840390
11/01/20 08:58 PM
11/01/20 08:58 PM
templeton,ma
templeton,ma
Thanks for the info,I will check it over again.
Re: 727 band strut install [Re: coro500net] #2840434
11/01/20 10:57 PM
11/01/20 10:57 PM
Wi.
old_racer Offline
old_racer  Offline
Wi.
the strut has to go in before the the drum is in the band, you know that right?
Re: 727 band strut install [Re: old_racer] #2840450
11/02/20 12:17 AM
11/02/20 12:17 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The back side of the band may not be seated down all the way in the anchor. Wiggle the anchor and the band. Once it sets all the way down you will be able to snap in in.
Doug
Re: 727 band strut install [Re: coro500net] #2840672
11/02/20 01:08 PM
11/02/20 01:08 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Re: 727 band strut install [Re: old_racer] #2840812
11/02/20 05:08 PM
11/02/20 05:08 PM
templeton,ma
templeton,ma
So if the low/reverse servo blows apart that means you have to take the whole transmission apart?
I sure hope not!!!
Re: 727 band strut install [Re: John_Kunkel] #2840816
11/02/20 05:14 PM
11/02/20 05:14 PM
templeton,ma
templeton,ma
Thanks for all the inputs!! John Cope has a YouTube video about changing the servo but it is tough to see how the band strut goes in. Should it go in easy or do you have to force it?
Re: 727 band strut install [Re: coro500net] #2841206
11/03/20 11:50 AM
11/03/20 11:50 AM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Another video
https://www.youtube.com/watch?v=Aci45eVwGJY
You have to force it a little bit , your spreading the band getting it to slide in place
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: 727 band strut install [Re: bee1971] #2841330
11/03/20 04:02 PM
11/03/20 04:02 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
I have seen the struts fall out with to little/loose adjustment
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: 727 band strut install [Re: bee1971] #2841343
11/03/20 05:06 PM
11/03/20 05:06 PM
templeton,ma
templeton,ma
That video made it look easy, Im clearly missing something. I have a local transmission guy coming over tomorrow,I’m sure he will make me feel like a fool. I’ll let you know what he finds.
Thanks to all!
Re: 727 band strut install [Re: coro500net] #2841381
11/03/20 06:27 PM
11/03/20 06:27 PM
AndyF Offline
AndyF  Offline
Yes it just slips into place. You must have the band on upside down or backwards or something like that. Maybe you have the wrong band for your transmission or you have a strut from a different transmission that is too long or some other mismatch of parts.
Re: 727 band strut install [Re: coro500net] #2841392
11/03/20 06:49 PM
11/03/20 06:49 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
if the oal of the new servo is slightly longer that could be the problem !
Re: 727 band strut install [Re: calrobb2000] #2841430
11/03/20 07:59 PM
11/03/20 07:59 PM
templeton,ma
templeton,ma
Thanks for all the info!!
The trans was completely assembled by a 35 year Dodge tech, it was fine before I changed servo. So clearly I’m missing something. Will let everyone know when I figure it out.
Re: 727 band strut install [Re: coro500net] #2841480
11/03/20 10:38 PM
11/03/20 10:38 PM
AndyF Offline
AndyF  Offline
If it was fine before you changed the servo then that is most likely the problem. Maybe it isn't seated all the way or it went together wrong.
Re: 727 band strut install [Re: AndyF] #2842415
11/06/20 03:23 AM
11/06/20 03:23 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
if you had the anchor pin out, the hinged anchor struts should have the shallow cut out part towards the case, and the deep cutouts towards the drum.
If using a thick front band strut, the thicker part goes to the inside, and the flatter part towards the valve body. With some, if flipped around the thick part will hit the valve body.
