Small block intake..M-1 or Torquer? #2839996
11/01/20 01:25 AM
11/01/20 01:25 AM
Wisconsin
Medlock51 Offline OP
Wisconsin
I have an M-1 intake ported to match my W-2 heads on my 388 oval track engine. I have a 2” four hole spacer. What kind of power would a Torquer make compared to the M-1.
This is a rebuild I'm doing... dirt late model... 388 ci... 14-1 on alky... 850 carb... locked dizzy... 1 3/4 long tube headers... ported W-2 heads... Jones Cam flat tappet solid lifter.
In it’s original livery with a modest Purple Shaft cam and 750 Holley it did 575hp on a stingey dyno.
Re: Small block intake..M-1 or Torquer? [Re: Medlock51] #2840000
11/01/20 01:45 AM
11/01/20 01:45 AM
Cab_Burge Online work
Cab_Burge  Online Work
I would look at using the Eddy W2 Victor intake or the Mopar brand, same intake with no eddy I.D on them, for your deal, if your heads still have the oval intake ports up scope
Re: Small block intake..M-1 or Torquer? [Re: Cab_Burge] #2840011
11/01/20 04:04 AM
11/01/20 04:04 AM
Wisconsin
Wisconsin
Still has the oval ports.
I have heard that flow may increase a bit over 300 cfm intake if you square off the intakes. Mine flow 294@.600. I doubt that I will mess with the porting right now.
I'lll check out the Victor intake.
Re: Small block intake..M-1 or Torquer? [Re: Medlock51] #2840075
11/01/20 11:20 AM
11/01/20 11:20 AM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
I agree with Cab , years ago we did a dyno test on my W2 head motor with an out of the box Victor W2 over my Strip Dominator which was gasket matched , the Victor was 12-15 hp better . The Indy 360-1 intake is also very good.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: Small block intake..M-1 or Torquer? [Re: 11secdart] #2840311
11/01/20 05:53 PM
11/01/20 05:53 PM
Wisconsin
Wisconsin
I'm also running an HVH 2" carb spacer...
Re: Small block intake..M-1 or Torquer? [Re: Medlock51] #2840444
11/01/20 11:47 PM
11/01/20 11:47 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
I'd imagine that the Torker will hurt power, the Victor Jnr or the Indy would be what I would be looking at.
Alan Jones
Re: Small block intake..M-1 or Torquer? [Re: Medlock51] #2840605
11/02/20 11:14 AM
11/02/20 11:14 AM
The Great State of PA
tabletop390 Offline
tabletop390  Offline
On my W2 motor, the Indy was the winner, but I'm drag racing not oval. I did try a Batten ported M-1 with a Wilson Manifold tapered spacer and got the same results as the Indy. ET and MPH was identical with both set-ups. I also tried both Holley Street and Strip Dominator intakes. They were OK, but not close to the Indy or my ported M-1. My motor looks to be pretty similar to yours, but not the compression ratio
Re: Small block intake..M-1 or Torquer? [Re: tabletop390] #2840722
11/02/20 02:32 PM
11/02/20 02:32 PM
Wisconsin
Wisconsin
Thanks all...
