Re: Lubricating non-running engines
[Re: stumpy]
#2840166
11/01/20 01:42 PM
11/01/20 01:42 PM
Posts: 19,406 north of coder
moparx
i have used transmission fluid as well as diesel fuel [or a mix of both] to squirt into spark plug holes [several times] on engines i don't know anything about a few days prior to seeing if they are free. they smoke like crazy on start up, but that seems to have prevented breaking any rings. just my experience. your mileage will vary.
[Re: Dabee]
#2840371
11/01/20 08:19 PM
11/01/20 08:19 PM
Posts: 4,755 Star Idaho
67vertman
Star Idaho
I just did this on a motor sitting for 31 years. Pulled the spark plugs and shot a liberal amount of MMO in each cylinder, let is sit for a week, then turn it over with a wrench.
My Monster are real!
Living within your means makes life pretty easy.
[Re: 5thAve]
#2840604
11/02/20 11:12 AM
11/02/20 11:12 AM
RWG75
RWG75
A breaker bar on the crank bolt with the plugs out will tell ya pretty fast how stuck it is. If it's been sitting for a while, I'd suggest some lube regardless of how stiff it is. General thought being no such thing as too much lubrication. I also think putting something in there is more important than exactly what you use. I've had good results with ATF and I like to pour some down the intake to at least dampen the valves.
After making sure it's at least free, my biggest thing is to pre lube the engine. As in yank the distributor, put the priming rod in and run the oil pump before trying to light it off.
[Re: ]
#2840685
11/02/20 01:28 PM
11/02/20 01:28 PM
RapidRobert
& when you preoil get #6 & #8 TDC compression on a (big block) and 20 degrees ATDC #6 compression (use the timing tab as a ruler) & 90 degrees (1/4 turn) BTDC #1 compression on a (Small Block). SB may have partial slits in the dampener at each quarter turn to help you.
[Re: 330Scott]
#2840973
11/02/20 09:54 PM
11/02/20 09:54 PM
RapidRobert
Yes, on each eng type you preoil with the hex shaft at 2 different points. one "point" lubes one sides valvetrain & the other point lubes the other side valve train cuz they ain't being fed continuously, only when everything lines up at those 2 points
