Rocker Moulding Clip - 69 Coronet R/T #2839914
10/31/20 08:59 PM
10/31/20 08:59 PM
Missouri
3
3_RTs Offline OP
3_RTs  Offline OP
Missouri
Does anyone have a photo of a correct plastic clip for holding the rocker trim onto a 69 Coronet R/T? I have looked at some of the vendors products, but their photos don't show enough detail. I would like to be sure before I buy.
Re: Rocker Moulding Clip - 69 Coronet R/T [Re: 3_RTs] #2841003
11/02/20 10:44 PM
11/02/20 10:44 PM
Missouri
3
3_RTs Offline OP
3_RTs  Offline OP
Missouri
This clip was supplied when I bought the rocker moldings. The little ends of the clip are what actually holds the moulding on. It doesn't look strong enough to me.
Re: Rocker Moulding Clip - 69 Coronet R/T [Re: 3_RTs] #2841135
11/03/20 09:55 AM
11/03/20 09:55 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Looks very similar to the clips on our 70 Charger.
They do look flimsy, but after 5 years, no problems.
Joe
Re: Rocker Moulding Clip - 69 Coronet R/T [Re: jlatessa] #2841141
11/03/20 10:21 AM
11/03/20 10:21 AM
Georgia
69bfan Offline
69bfan  Offline
Georgia
The small nylon tabs are actually to protect the paint of the rocker as the trim will actually sit on top of the tabs. The heavier rounded radius of the clip is what fits into the edges of the trim to hold them in place. The Charger clip is similar but is different in both material characteristics and size.
www.restorationpartsandmaterials.com
Correct Mopar weatherstripping is our specialty, but we stock and supply a wide assortment for all of your restoration needs.
www.dalescudashop.com
Correct style exhaust tips and hardware, fresh air seals, go wings, Cuda & Challenger rear window louvers, hood pin kits
Re: Rocker Moulding Clip - 69 Coronet R/T [Re: 69bfan] #2841162
11/03/20 10:55 AM
11/03/20 10:55 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
I forgot to mention about the thin tabs protecting the paint,
remembered it after the post....thanks, Joe
PS, What's with the 4 hour post time difference??
