A12 Hood Pin Lanyards ? #2839705
10/31/20 11:56 AM
10/31/20 11:56 AM
Land of 10,000 Lakes
44D6PAKCUDA Offline OP
I had a guy drop off this bundle of lanyards saying they were left over from his early 80's A12 restoration project.They measure 6 1/4" long when laid out flat and are rubber,dipped coated.Do they look correct or original? I know little about original A12 stuff,so looking for some info.Thanks
Re: A12 Hood Pin Lanyards ? [Re: 44D6PAKCUDA] #2839708
10/31/20 12:00 PM
10/31/20 12:00 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Im not an A12 guru by any means . But I dont think they used a black rubber coated lanyards.
Re: A12 Hood Pin Lanyards ? [Re: gtx6970] #2839715
10/31/20 12:09 PM
10/31/20 12:09 PM
moparx Offline
moparx  Offline
i'm no expert either, but i believe they had a clear vynal coating, the eyelets were plated, and they were longer [?].
beer
Re: A12 Hood Pin Lanyards ? [Re: 44D6PAKCUDA] #2839782
10/31/20 03:01 PM
10/31/20 03:01 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Re: A12 Hood Pin Lanyards ? [Re: A12] #2839784
10/31/20 03:18 PM
10/31/20 03:18 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
My original A12 RR hood pin lanyard to show that over time the (completely) black coated lanyard goes away. Also to note there are two different hole size and length eyelets on the ends. Small eyelet longer length for the rivet and larger hole and shorter length for the hood pin clip. ****BTW they are listed on original factory documentation as "A-body glove box door lanyards" which I don't know if they were coated or not. I'm sure if the A-body glove box lanyards were not coated they were completely coated for the A12 hood lanyard use to keep from marring or scuffing the fiberglass hood finish from movement from wind at speed. I would coat bare lanyards for that reason even if it is found the originals were not........but I feel they were originally fully coated for the reason mentioned.
Re: A12 Hood Pin Lanyards ? [Re: A12] #2839796
10/31/20 03:48 PM
10/31/20 03:48 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
My '69 Dart (M-Code) glove box lanyard......looks similar if not the same as my A12 hood pin clip lanyard both without coating. But as I think the original A12 hood pin clip lanyards were completely coated in black.
Mike
Re: A12 Hood Pin Lanyards ? [Re: A12] #2839800
10/31/20 03:55 PM
10/31/20 03:55 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Quote
****BTW they are listed on original factory documentation as "A-body glove box door cables (lanyards)"
SEE #24
Re: A12 Hood Pin Lanyards ? [Re: A12] #2839844
10/31/20 06:18 PM
10/31/20 06:18 PM
The reference to the A body glove box lanyard is exactly what the guy that gave them to me said.As they do have two different size eyelets as mentioned also.I better go grab them out of the scrap box.Thanks for the info
Re: A12 Hood Pin Lanyards ? [Re: 44D6PAKCUDA] #2839874
10/31/20 07:54 PM
10/31/20 07:54 PM
Wisconsin
Big D A12 Offline
Big D A12  Offline
Wisconsin
They look correct. What are you asking for a set of 4?
Seeking 1969 Lynch Road fender tags/Build Sheets/Window Stickers/VIN - Over 2300 so far thanks to you!!
2018 Demon Challenger PY4 A8 Black Hood
2017 Jeep Trail Hawk
2016 Hellcat Challenger PCP A8
1969.5 A12 Super Bee WM21 V1H F6 D21
1969 Coronet RT B5 D32 M46 N96
Re: A12 Hood Pin Lanyards ? [Re: Big D A12] #2839926
10/31/20 09:20 PM
10/31/20 09:20 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Likewise for me too..........as one can clearly (pun) see the black coating is gone from my original set and I surely ("don't call me Shirly" wink ) need a set of 4 for my A12. They would go to a good home and real A12 up beer
Mike
(please PM me if you decide to let a set go)
Re: A12 Hood Pin Lanyards ? [Re: A12] #2840037
11/01/20 08:56 AM
11/01/20 08:56 AM
A727Tflite Offline
A727Tflite  Offline
I could use a set too for my A12, PM me if interested in selling a set.
Re: A12 Hood Pin Lanyards ? [Re: A727Tflite] #2840060
11/01/20 10:42 AM
11/01/20 10:42 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Count me in too. Please send me a PM with price.
Re: A12 Hood Pin Lanyards ? [Re: 6PakBee] #2840087
11/01/20 11:51 AM
11/01/20 11:51 AM
Thanks for all the replies and info.I got 4 sets of these for free so I am sending them out for free to the first 4 guys that asked about them.The first 3 here on the post and 1 thru a PM.(Sorry 6 PakBee).I've been helped out a ton on Moparts over the years and just want to give a little back when I can
Re: A12 Hood Pin Lanyards ? [Re: 44D6PAKCUDA] #2840145
11/01/20 01:16 PM
11/01/20 01:16 PM
moparx Offline
moparx  Offline
i learned something from this post. up [now, if i can just remember it !]
and kudos to you sir, for "giving" back to the community ! bow
beer
Re: A12 Hood Pin Lanyards ? [Re: 44D6PAKCUDA] #2840158
11/01/20 01:31 PM
11/01/20 01:31 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Not a problem, when you come late to a party, don't be surprised if the beer is all gone! grin
Re: A12 Hood Pin Lanyards ? [Re: 44D6PAKCUDA] #2840520
11/02/20 07:09 AM
11/02/20 07:09 AM
Port Huron, Michigan
MI_Custumz Offline
MI_Custumz  Offline
That is AWESOME!!!
Re: A12 Hood Pin Lanyards ? [Re: MI_Custumz] #2842267
11/05/20 07:33 PM
11/05/20 07:33 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Got my lanyards today Jim. Thanks a lot. This is why I come to Moparts, not to call each other names in the political forum! 👍 Good guy alert here.
Re: A12 Hood Pin Lanyards ? [Re: fastmark] #2842317
11/05/20 09:45 PM
11/05/20 09:45 PM
I'm glad to help out a few guys with these lanyards that I knew I would never use.I must admit,it does feel good smile
Re: A12 Hood Pin Lanyards ? [Re: 44D6PAKCUDA] #2842384
11/06/20 12:29 AM
11/06/20 12:29 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Jim I got the lanyards today also beer beer beer THANK YOU !! I will be sure to pay it forward, you need to feel good as you stated that is most kind of you, can't thank you enough up Love this kind of thing as it adds character to the hobby and project and it is something that I will always remember and mention when out and about with the car. "and the car has Special O.E. good guy hood pin lanyards" grin up
Thanks again,
MikeR
Re: A12 Hood Pin Lanyards ? [Re: A12] #2845140
11/11/20 11:19 PM
11/11/20 11:19 PM
A727Tflite Offline
A727Tflite  Offline
Received my lanyards today, really appreciate your generosity. Please check for a PM from me.
Thanks again.
