7/16 wheel studs.
#2839687
10/31/20 11:32 AM
10/31/20 11:32 AM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
Does anyone know where to find longer 7/16 wheel studs, or know the knurl on factory stuff? Now, jumping back a bit, I found a set of small bolt Centerline wheels for my '69 GTS Dart. Neither the front or the rear studs will reach to the front side of the lug hole in the wheels. I don't like the idea of running them with the lug/stud engagement the current studs provide. I can't seem to find a longer stud to make the wheels work. Has anyone upgraded their studs, and if so, who did you go through? Thanks in advance.
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
Re: 7/16 wheel studs.
[Re: GODSCOUNTRY340]
#2839714
10/31/20 12:08 PM
10/31/20 12:08 PM
OhioMopar
Mt.Gilead, Ohio
Moroso 46160. Knurl is .560" Will those work on the front and rear? Thank you!
[Re: OhioMopar]
#2839717
10/31/20 12:12 PM
10/31/20 12:12 PM
Posts: 2,525 God's Country Maryland
GODSCOUNTRY340
I know they work on the front, not sure about the rear. You may have to shorten them for proper fitment if you're running closed end lug nuts. They are made 2 7/8" long to pass drag car tech inspection.
#2839742
10/31/20 01:14 PM
10/31/20 01:14 PM
OhioMopar
Mt.Gilead, Ohio
I used an open end nut on the longer studs on my Super Bee. I'll look into them. Thank you.
[Re: OhioMopar]
#2840817
11/02/20 05:15 PM
11/02/20 05:15 PM
Posts: 1,812 Portsmouth, VA
DusterW2
Portsmouth, VA
MOROSO long studs for the rear axles - 7/16" -20 x 2-7/8", .480" dia. knurl, P/N 46150 I used these on my stock A-body 8-3/4 axles with centerline auto drag rims https://www.moroso.com/press-in-wheel-stud46150/I used open end lug nuts. The front 15 x 3-1/2 centerlines are thicker in the center and I used the lug nuts for the old cragar SST rims FRONT - Lug Nuts 7/16" Open End XL Mag Chrome, Part Number: 555-65244 (JEGS) REAR - Lug Nuts 7/16" Open End Medium Mag Chrome, Part Number: 555-65260 (JEGS)
