Re: shifter
[Re: Cab_Burge]
#2838550
10/28/20 10:41 PM
10/28/20 10:41 PM
Posts: 13,202 aZLiViN
J_BODY
aZLiViN
Winters, Fairbanks and Turbo Action are the same basic shifter for Mopar 727 trannies, all 3 are good units that work well I’ll object..... Perhaps when I make my “pinion snubbers and purple shafts” moparguy t-shirts I’ll include this fine piece of mopar-lore to it. Errant 1-3 shifts... mine started making the 1-2 shift all by itself when we started launching hard. It relies on the rooster comb detents on the valve body to retain shift position. We haven’t had a rousing shifter debate in awhile so let’s get this party started!
Re: shifter
[Re: cudaman1969]
#2838564
10/28/20 11:22 PM
10/28/20 11:22 PM
J_BODY
aZLiViN
You need to learn how to adjust one properly, best shifter ever made 45 years and counting for me and never had that problem Thankfully there were enough on this old bandwagon to garner me a decent sell price. PPP FOR THE WIN!
Re: shifter
[Re: J_BODY]
#2838599
10/29/20 01:09 AM
10/29/20 01:09 AM
Posts: 20,212 Park Forest, IL
slantzilla
Park Forest, IL
I have a T/A and am also less than in love with it. IIRC, J-Body gave me the secret to not making a 1-3 shift.
I have a PPP I have never mounted in anything yet. I ordered it off of PPP's own website and it is a mess. The cable exits the rear of the shifter, but goes in the front of the trans. It also has a backwards shift pattern. Park is all the way back and you push forward to shift. I tried to trade it in at PPP and they refused.
Re: shifter
[Re: J_BODY]
#2838699
10/29/20 11:26 AM
10/29/20 11:26 AM
Posts: 11,728 Portage,michigan
B3422W5
Portage,michigan
I had Hurst qsticks in everything for years and really like them. I have had a TA shifter in my current car for 4 years now. Have never missed a shift with it. That said, i do take a little extra care with it. I just put my finger tips on it after i stage and keep them there, and when i make the 1/2 shift just tap it. Then grab it to make the 2/3 shift. Its just falling into a habit and repeating it every time is the key. I have come to actually like it. The command center is nice for my switches and make for a tidy, unclustered area around the shifter.
Re: shifter
[Re: B3422W5]
#2838701
10/29/20 11:31 AM
10/29/20 11:31 AM
Posts: 4,991 new jersey usa
11secdart
new jersey usa
Turbo Action here ( have their reverse pattern valve body also and converter was originally theirs been redone by Ultimate ) ... been in the car over 30 years never a problem still has the original cable as a matter of fact
Re: shifter
[Re: J_BODY]
#2838713
10/29/20 11:51 AM
10/29/20 11:51 AM
Posts: 19,384 Las Vegas
Al_Alguire
Las Vegas
PPP is the best way to go especially if its a hard leaving fast car.
Re: shifter
[Re: Sammy]
#2838944
10/29/20 06:54 PM
10/29/20 06:54 PM
slantzilla
Park Forest, IL
I tried Holt, unfortunately since I didn't buy it there they couldn't help. This one will probably end up in my Valiant. I am sure it will be fine once I get used to it.
Re: shifter
[Re: dvw]
#2839096
10/29/20 11:55 PM
10/29/20 11:55 PM
Posts: 8,346 fredericksburg,va
cudaman1969
fredericksburg,va
I want to understand this going from first to third thingy. Are you saying the shifter goes from 1-2 but the lever on trans is going from 1-3? Or is it driver error and you’re just pulling it over past the detent
Re: shifter
[Re: cudaman1969]
#2839102
10/30/20 12:24 AM
10/30/20 12:24 AM
J_BODY
aZLiViN
What I “learned” in my TA days was that if you launched and went to make the 1-2 by “pulling” the lever.... you could drag it past the detent and end up in 3rd.... pretty common actually. I found it best to “slap” on the 1-2 as the lever would move over to the right in prep for the 2-3. I had both gates for my shifter as I used it with my clean N t-brake briefly. The deal breaker was after we put the W8 in and on the test passes it would go 1-2 on the hit.... now when your shaking down a new combo your mind is in a million different directions I didn’t figure out what the H was going on until the 3rd pass when I watched the dang thing go 1-2 when I let go of the t-brake . I actually took my valve body out and shimmed the ball and filed on the rooster comb to make it harder to move between the detents..... but the PPP fell into my lap so we ran with it.
Re: shifter
[Re: DusterKid]
#2839191
10/30/20 09:50 AM
10/30/20 09:50 AM
Posts: 1,178 Indy
FlyFish
Indy
I have a B&M ratchet shifter on mine (the mega shifter I believe) and it does what you are looking for (rear entry)
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: shifter
[Re: J_BODY]
#2839203
10/30/20 10:34 AM
10/30/20 10:34 AM
cudaman1969
fredericksburg,va
What I “learned” in my TA days was that if you launched and went to make the 1-2 by “pulling” the lever.... you could drag it past the detent and end up in 3rd.... pretty common actually. I found it best to “slap” on the 1-2 as the lever would move over to the right in prep for the 2-3. I had both gates for my shifter as I used it with my clean N t-brake briefly. The deal breaker was after we put the W8 in and on the test passes it would go 1-2 on the hit.... now when your shaking down a new combo your mind is in a million different directions I didn’t figure out what the H was going on until the 3rd pass when I watched the dang thing go 1-2 when I let go of the t-brake . I actually took my valve body out and shimmed the ball and filed on the rooster comb to make it harder to move between the detents..... but the PPP fell into my lap so we ran with it. I see, my car never left that hard for that to happen. I had an electric shift, fist to second went fine, had to hold the lever over to shift third
