Re: 15x7 & 15x 8 wheels How big a tire ?
[Re: Fire In The Sky]
#283907
04/10/09 05:26 PM
04/10/09 05:26 PM
Posts: 3,663 st louis mo
Q5Bee B5ScatPack
st louis mo
i run 275 60 15 in rear 235 60 or 70 15 in front
1969 SUPERBEE 383 Q5 RED STRIPE WHITE INT. 2015 CHALLENGER SCAT PACK B5 BLUE 1996 INDY RAM PACE TRUCK
[Re: Q5Bee B5ScatPack]
#283910
04/10/09 07:04 PM
04/10/09 07:04 PM
Posts: 9,065 Milwaukee, WI
In_The_Pink
Milwaukee, WI
I use a 235/60R15 on 15x7s and 255/60R15 on 15x8s, but 275s will work and I've heard of others using a 295/50R15 on the 15x8s, too. That's a bit too much tire for my taste, though.
#283911
04/10/09 07:39 PM
04/10/09 07:39 PM
Posts: 3,131 across the river from Portland...
472 R/T SE
I'm running 235 on the front & 275 on the rear. My rear wheels are 8.5" with a 3.75" backspacing as well and there was no way 295's were gonna fit w/o moving something. I'm happy I went with the 275's as they're a little taller and give the car a little bit of rake that I wanted.
[color:"purple"] HELP SUPPORT THE REGISTRIES.All cars matter. 1970 Charger Registry I like to sleep For I'm walking in my dreams. Live life like every DAY is your last! Chrysler R/T Club[/color]
[Re: moparcanuk]
#283914
04/10/09 11:29 PM
04/10/09 11:29 PM
Posts: 153 VA
Fire In The Sky
VA
Thanks to all of you for your input & pictures. I like the idea of a fatter back set of wheels & if 275 is as big as I can go I will go with the 275/60/15 set. I have 70's on it now with the Magnum 500's & I wanted a rougher look for a while since I cannot get the body redone for a while (have another Mopar in the body shop now). So this one got some new wheels & tires until the major facelift can be had. L J Neal in Richmond, VA
