Re: To port or not to port?
[Re: justinp61]
#2838126
10/27/20 09:03 PM
10/27/20 09:03 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I wouldn't pay Hughes a dime, but I would talk to Dwayne Porter. I spoke to him about the cam choice and porting. The biggest reason I went to Hughes for the info is that they've flowed a bunch of different heads and have the numbers on their site. I like that better than looking at heads that were tested on a hundred different machines all over the world. I'm a data guy and a single source makes for a better A/B comparison in this situation. As for the fondness (or lack thereof) for the company, that's one of the biggest things that drove me away from racing. There's a non-stop hate fest going on. Racers piss on one guy and put another on a pedestal while the next racer does just the opposite. It's as hypocritical as the 350 lb driver spending thousands to build a light weight race car while refusing to go on a diet himself.
[Re: feets]
#2838129
10/27/20 09:24 PM
10/27/20 09:24 PM
Posts: 2,864 Pattison Texas
CSK
Pattison Texas
At the very least get a good valve job, Back cut on the intake valve, bowl blend & you will be good to go.
[Re: feets]
#2838130
10/27/20 09:26 PM
10/27/20 09:26 PM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I am betting bowl work, biggest valves, what ever gives you excellent flow numbers up to your max lift will be your best choice. A wide 110 lsa on a motor like yours sounds all wrong to me. Small heads, HUGE motor! Likes overlap. The question is how much overlap can be used and not screw up the manners down real low? Vizzards book on power has a chart that says a 540 with those heads could do best with a 100 degree LSA! But obviously it might have a pretty ratty idle. Some Harley cams have a similar situation, and aftermarket grinds can be had with 98 LSAs! Something to think about. Time to consider a REAL custom cam!
[Re: gregsdart]
#2838148
10/27/20 10:13 PM
10/27/20 10:13 PM
Posts: 4,209 New York
polyspheric
New York
This^^^
Boffin Emeritus
[Re: feets]
#2838160
10/27/20 10:42 PM
10/27/20 10:42 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
I wouldn't pay Hughes a dime, but I would talk to Dwayne Porter. I spoke to him about the cam choice and porting. The biggest reason I went to Hughes for the info is that they've flowed a bunch of different heads and have the numbers on their site. I like that better than looking at heads that were tested on a hundred different machines all over the world. I'm a data guy and a single source makes for a better A/B comparison in this situation. As for the fondness (or lack thereof) for the company, that's one of the biggest things that drove me away from racing. There's a non-stop hate fest going on. Racers piss on one guy and put another on a pedestal while the next racer does just the opposite. It's as hypocritical as the 350 lb driver spending thousands to build a light weight race car while refusing to go on a diet himself. No hate here, I've ran two of his cams, both made good power but neither held up well. As far as their flow numbers go, I'll let that dog lie.
[Re: AndyF]
#2838247
10/28/20 09:49 AM
10/28/20 09:49 AM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
While I agree porting the heads would def be worth power on that combo........Spending $1600 to port some RPM heads wouldn’t be a viable option for me.
If you already own the heads, you could sell them for as little as $600, add that to the $1600 the porting would cost...... and buy TF240’s...... and be money ahead.
[Re: feets]
#2838312
10/28/20 12:38 PM
10/28/20 12:38 PM
Posts: 11,718 Portage,michigan
B3422W5
Portage,michigan
I wouldn't pay Hughes a dime, but I would talk to Dwayne Porter. I spoke to him about the cam choice and porting. The biggest reason I went to Hughes for the info is that they've flowed a bunch of different heads and have the numbers on their site. I like that better than looking at heads that were tested on a hundred different machines all over the world. I'm a data guy and a single source makes for a better A/B comparison in this situation. As for the fondness (or lack thereof) for the company, that's one of the biggest things that drove me away from racing. There's a non-stop hate fest going on. Racers piss on one guy and put another on a pedestal while the next racer does just the opposite. It's as hypocritical as the 350 lb driver spending thousands to build a light weight race car while refusing to go on a diet himself. The numbers they have on the site are “ optimistic” at best Would wager 95% of people on here would agree. I would get your Eddies CNC’ed at Modern and be done with it. I doubt they anywhere close to 1600
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: feets]
#2838667
10/29/20 09:52 AM
10/29/20 09:52 AM
Posts: 12,153 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
No one has mentioned that 3,300 is the dividing point. The porting offers no help below that point, either in torque or horsepower but does pick up a good amount above that. Where do you plan to spend the most time? Above or below 3,300? And how important is that extra power above 3,300 to your planned usage since there is no gain (actually a little loss) below that. That much low end grunt trying to push that heavy boat will be a major tire-fryer anyway, so would more of the same even be usable?
Why not just try the heads you have as they are to see how you like it? Would it be that big a deal for you to throw the extra coin at them later if you just had to have more? Also, if you wait and still wanted more, you would have a better feel whether you would want to just port the Eddies or move on to bigger, better heads.
Master, again and still
[Re: jwb123]
#2838692
10/29/20 11:05 AM
10/29/20 11:05 AM
gregsdart
I would have to agree, trying to feed a 540 with the Eddy heads even with some porting is not going to be money well spent. My best guess, that on the drag strip, porting those heads on a 540 maybe a tenth in ET. Spend the money for a CNC job on a better set of heads. You have a point if the OP is wanting a lot of power above about 5,000. But up to that point a small port head on a 540 will be superior in torque output where this deal will want it- 2800 to 4000 maybe? Having run a 535 with ported 906 heads, i can vouch for the torque!
[Re: gregsdart]
#2838723
10/29/20 12:05 PM
10/29/20 12:05 PM
justinp61
W. Kentucky
Has anyone ever seen a street type stroker with a reasonable cam not have tons of torque? I've built two small block street/strip strokers, one with a 4" crank, a 408 and my current one with a 4.125" crank, 434". The 408 had Curtis Boggs ported Edelbrocks with a 260/264° @ .050, .628/.633" flat solid. The 434 has ported Indy 360-1's with a Comp 263/271° @ .050, .711/.719" solid roller. Neither of these engines have been soft on the bottom end, anywhere on the bottom. I understand I'm running a lighter car with more gear, but I find it hard to believe that unless something is way out of kilter in the combo that you're going to make a street type big block stroker soft on the bottom. I guess if you put a set of old pro stock wedge heads on a very low compression build with a huge roller and a 2.76 gear in a dump truck you could muck it up. There is always that guy, but I don't see feets as being him.
[Re: AndyF]
#2838799
10/29/20 02:10 PM
10/29/20 02:10 PM
Posts: 4,684 Wichita
GY3
Wichita
Yes, the 1.46 valve spring TF240 heads are only $962 each from Summit (free shipping) so that is around $1900 for new heads. Not sure if the $1600 includes shipping back and forth to Hughes. If it doesn't then you'll need to add another $200 to the bill since 50 lbs heads are going to be expensive to ship. The existing Edelbrock heads should be fairly easy to sell locally for a few hundred each. Modern Cylinder Head ported my Stealths ~4 years ago for $750.
[Re: GY3]
#2838817
10/29/20 02:40 PM
10/29/20 02:40 PM
gregsdart
I should havé mentioned this before--- how much flow can be gained with some basic mods? Like bowl porting, backcut valves, whatever will improve flow down low on the cheap? Much less costly and might meet your needs real well. That certainly would raise the torque up above 3200, probably give you 75 percent of the power gains a full port job would?
[Re: GY3]
#2838829
10/29/20 03:03 PM
10/29/20 03:03 PM
feets
Senior Management
Senior Management
Irving, TX
I sent an email to MCH to get their opinion on porting vs replacing.
