Re: A/C Blower Motor Ground Wire Question
[Re: vinnyd76]
#2838251
10/28/20 09:50 AM
10/28/20 09:50 AM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
I can't talk on A bodies, but 71/74 B bodies uses one of the A/C-heater box studs with the nut to the firewall. I think the eyelet terminal get somehow a star washer shape to cut into the paint? can't recall.
[Re: NachoRT74]
#2838625
10/29/20 07:09 AM
10/29/20 07:09 AM
Posts: 2,592 None
71rm23
None
I can't talk on A bodies, but 71/74 B bodies uses one of the A/C-heater box studs with the nut to the firewall. I think the eyelet terminal get somehow a star washer shape to cut into the paint? can't recall. Correct but I don't have a picture and pretty sure A bodies are the same as well
[Re: 71rm23]
#2838743
10/29/20 12:41 PM
10/29/20 12:41 PM
Posts: 1,563 Macomb, MI
vinnyd76
Macomb, MI
Thank you for the feedback. I was trying to find some old pics before the 70 Dart was torn down, Here is a pic that I initially thought it went over to the wiper motor stud. But the wire that was spliced may be the blower motor wire, it's difficult to tell.
Unfortunately, I do not have a photo depicting the right side of the engine compartment (up close). I only have the pic from the online ad, but it's too difficult to make out the actual routing with all the pluming going on.
[Re: burdar]
#2838767
10/29/20 01:05 PM
10/29/20 01:05 PM
Posts: 1,331 Clinton, NJ
njmopar
Clinton, NJ
Yah, my 68 non A/C blower motor attaches behind the PS kick panel. A/C cars might be different. Motor is in same location for both, so I am guessing ground is same spot. They may choose that location to move further from radio or something (AM noise). I would take the harness and lay it out to see how it fits. I am also remembering it went under the carpet to get to the side kick panel. Wasn't what I expected, but I saved old carpet and could see where the wire was laying and imprinted on back.
