Re: 144.00 mph in FAST
[Re: TonyS451]
#2838087
10/27/20 06:35 PM
10/27/20 06:35 PM
Posts: 419 NY
F1Scamp
NY
And how about that Duster! You can somewhat understand how a hemi can make big hp w huge heads, big cubic inch potential, dual quads, etc, but 127mph out of the small block mopar head, intake, carb combo is pretty darn impressive too. The duster is a 71. In 71 you get a better flowing intake manifold, and a higher cfm carb (thermoquad), but you have a much worse flowing passenger exhaust manifold when compared to a 70. It also is all cast iron and heavy. Congrats Dave and Rick, the cuda is stunning!
Work In Progress- 71' Duster F.A.S.T.- 10.36@130 Smallblock Record Holder.
[Re: BSB67]
#2838132
10/27/20 09:28 PM
10/27/20 09:28 PM
Posts: 2,855 Pattison Texas
CSK
Pattison Texas
I didnt realize that the regular hp exhaust manifold cars (A12's) were now on the sunny side of 130 mph. These FAST cars are VERY impressive to me !!!!
[Re: Grizzly]
#2838175
10/27/20 11:45 PM
10/27/20 11:45 PM
Posts: 8,240 fredericksburg,va
cudaman1969
fredericksburg,va
And how about that Duster! You can somewhat understand how a hemi can make big hp w huge heads, big cubic inch potential, dual quads, etc, but 127mph out of the small block mopar head, intake, carb combo is pretty darn impressive too. Yes, and look at the cars that are below it. Would like to know more about this car. I feel the pain of trying to explain F.A.S.T. cars to "car people"..............it's like talking to a brick wall. A D/SA Duster at 3125 pounds stock intake carb no porting stock stroke with a .451 lift cam went 9,96. No telling how many cubes that Duster has
[Re: RapidusMaximus]
#2838230
10/28/20 09:05 AM
10/28/20 09:05 AM
Posts: 21,819 Kirkland, Washington
Pacnorthcuda
Ok FAST experts, non Mopar question, wonder why there isn't a 70 model LS6 Chevelle on that list somewhere? Weight. They were heavy...3900-4000 lbs. The LS6 doesn’t get you anything visually over any any other big block Chevy. The L88 vette is tops cause that allows you to use aluminum heads. Now a ZL1 clone would net you another 100ish pound savings over other chevies!
#2838240
10/28/20 09:30 AM
10/28/20 09:30 AM
Posts: 14,493 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Ok FAST experts, non Mopar question, wonder why there isn't a 70 model LS6 Chevelle on that list somewhere? It’s really simple. No one running that combo has put forth the $$$$ and effort to make it happen. I highly doubt that combo would be a contender for the top spot, but I have no doubt one of those could be on the top 30 list with a high effort build.
[Re: fast68plymouth]
#2838243
10/28/20 09:41 AM
10/28/20 09:41 AM
Posts: 2,410 Weatherford, Texas
RapidusMaximus
Weatherford, Texas
Shows my non Mopar ignorance, I thought the LS6 was an aluminum head engine...
1968 Plymouth GTX 1974 Dodge P/U Long Bed Stepside 318 2019 Ram 2500 6.4, auto, 4WD
#2838245
10/28/20 09:46 AM
10/28/20 09:46 AM
CSK
Pattison Texas
I am in NO WAY comparing how my junk ran to the FAST cars, just giving info In 1985 I had a LS6 crate 454 I rebuilt in my 72 SS Chevelle , stock rec port heads, & a small hydro flat tap cam,, 230 @ .050 , 4050 lbs, , 12.70 @ 107 in the Southeast Texas heat, open headers
[Re: NANKET]
#2838620
10/29/20 05:29 AM
10/29/20 05:29 AM
Posts: 4,669 Wichita
GY3
Wichita
When I told him mine does 2.12 0-60mph he was blown away. Especially since it was sitting in the parking lot. Where do you get the 2.12 0-60 MPH number from? Wallace has a calculator that you enter your 1/8th mile time and mph and it calculates 0-60.
#2838762
10/29/20 01:00 PM
10/29/20 01:00 PM
Posts: 9,827 MI, usa
dvw
MI, usa
Ok FAST experts, non Mopar question, wonder why there isn't a 70 model LS6 Chevelle on that list somewhere? Same basic engine combo in the 67 Chevelle that’s on the list. Doug
[Re: DonnyBrass]
#2838814
10/29/20 02:39 PM
10/29/20 02:39 PM
Posts: 1,619 MA
ragtop
MA
Here is where we stand..........
Donny, Do you have a list like this for your Pure Stock class?
[Re: DonnyBrass]
#2838911
10/29/20 05:55 PM
10/29/20 05:55 PM
CSK
Pattison Texas
Thanks for posting this information DonnyBrass !!! very cool
[Re: ragtop]
#2839336
10/30/20 02:50 PM
10/30/20 02:50 PM
Posts: 55 CT
roadrunner2
CT
I watched the video of the Hemi Cuda and noticed the rear chassis rising after staging the car before the launch. Does that mean that the pinion snubber is being used and is adjusted close to the chassis? I was told that Dave was not using the snubber on his Road Runner. That’s just the engine pushing against the converter. Mine does the same thing but worse. Bill
1968 Road Runner 383 727 3.91 8 3/4 3520 with driver 11.04 @ 124.26 with 1.67 60’ Done on G70-14 redlines thru factory manifolds New quickest ever 383 build in FAST. 10:1 451” replaced with 14:1 499”.
[Re: roadrunner2]
#2839345
10/30/20 03:15 PM
10/30/20 03:15 PM
Pacnorthcuda
I watched the video of the Hemi Cuda and noticed the rear chassis rising after staging the car before the launch. Does that mean that the pinion snubber is being used and is adjusted close to the chassis? I was told that Dave was not using the snubber on his Road Runner. That’s just the engine pushing against the converter. Mine does the same thing but worse. Bill No. The differential pinion is moving up, trying to flip the diff over backwards, the opposite direction of the wheels trying to rotate forward. (...for every action there is an equal and opposite reaction.). This tries to wrap up the leaf springs into an S, and plants the rear down towards the ground, which lifts the body. A snubber, once it contacts the floorboard takes advantage of this further and plants the rear even harder and further cause the rear of the body to rise even more.
