SHIFT KIT RECOMMENDATIONS #2834818
10/19/20 10:56 PM
10/19/20 10:56 PM
S.E.Ohio
Magnumguy Offline OP
S.E.Ohio
I want to install a shift inprover kit in one of my Magnums. Bone stock 318, 998 trans.
I want one that retains the lockup but raises the engagement speed (45 or so), and will also firm up the shifts.
What would I need to buy?
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: KIT RECOMMENDATIONS [Re: Magnumguy] #2835295
10/20/20 09:01 PM
10/20/20 09:01 PM
S.E.Ohio
S.E.Ohio
Nobody?
Re: KIT RECOMMENDATIONS [Re: Magnumguy] #2835298
10/20/20 09:05 PM
10/20/20 09:05 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
I have one and I don't like it because it keeps you in 2nd gear until 80 mph when you get on it whether you want it or not even when you let ff the gas.
Re: KIT RECOMMENDATIONS [Re: moparpollack] #2835675
10/21/20 02:39 PM
10/21/20 02:39 PM
moparx Offline
moparx  Offline
see what trans-go offers in their "no yo-yo" series of kits.
i haven't had much of a chance to search those, due to stuff here.
beer
Re: KIT RECOMMENDATIONS [Re: moparx] #2836957
10/24/20 03:12 PM
10/24/20 03:12 PM
S.E.Ohio
S.E.Ohio
So, are there other brands of kits to be had?
Re: KIT RECOMMENDATIONS [Re: Magnumguy] #2836961
10/24/20 03:28 PM
10/24/20 03:28 PM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
I have a trans go in my 46RE. I like it, but I don't think it does what you're wanting.
Do a search here for "shift kits." You'll gain some insight into what it takes to raise shift points, and probably figure out a direction to head in. Maybe changing the title of your thread to "Shift Kit Recommendations" would get the transmission guru's to chime in also.
Re: KIT RECOMMENDATIONS [Re: Magnumguy] #2837068
10/24/20 07:52 PM
10/24/20 07:52 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
I don't know much about the "newer" stuff {my stuff is all 73 or older) but I had a friend with an 80s something truck and he had his lockup rigged up to be controlled by a toggle switch. Maybe that would be something to consider.
Re: KIT RECOMMENDATIONS [Re: Fat_Mike] #2837118
10/24/20 10:52 PM
10/24/20 10:52 PM
S.E.Ohio
S.E.Ohio
Took your advice, done wink
RE; SHIFT KIT RECOMMENDATIONS [Re: Magnumguy] #2837139
10/25/20 12:15 AM
10/25/20 12:15 AM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Changed it here too. smile
Re: SHIFT KIT RECOMMENDATIONS [Re: Magnumguy] #2837157
10/25/20 02:24 AM
10/25/20 02:24 AM
A727Tflite Offline
A727Tflite  Offline
What year trans ?
Re: SHIFT KIT RECOMMENDATIONS [Re: A727Tflite] #2873667
01/13/21 11:45 AM
01/13/21 11:45 AM
S.E.Ohio
S.E.Ohio
Originally Posted by Transman
[quote=Magnumguy]
What year trans ?
It's a 78 a998
