Re: Speedometer RPM to Speed ratio?
[Re: AndyF]
#2836951
10/24/20 03:03 PM
10/24/20 03:03 PM
Posts: 25,750 Rio Linda, CA
John_Kunkel
Rio Linda, CA
1000 rpm = 60 mph. 1000 turns = one mile on the odometer.
[Re: DrCharles]
#2837317
10/25/20 03:05 PM
10/25/20 03:05 PM
John_Kunkel
Rio Linda, CA
Remember that the tire diameter * pi is not exactly the same as the rolling diameter. This is probably the most important part of speedo calibration, advertised diameter varies. My most recent experience was with a tire that had an advertised diameter of 28" but was actually 26 3/4" computed from the rollout.
[Re: John_Kunkel]
#2837386
10/25/20 07:23 PM
10/25/20 07:23 PM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
You can get a more accurate measurement from a road force tire balancer as it applies force to the tire while it measures the actual diameter. I've measured slicks before on our balancer at the shop and it works very well Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
