Difference between X and O Heads? #2835965
10/22/20 08:32 AM
10/22/20 08:32 AM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Interested to learn more about the difference between "X" and "O" 340 heads (thought there maybe "U" heads too?). I know "J" Heads are a later model head (71+).
Re: Difference between X and O Heads? [Re: vinnyd76] #2835991
10/22/20 09:46 AM
10/22/20 09:46 AM
CA
crackedback Offline
crackedback  Offline
CA
o j u z are all the same.
x has value to the restorer, got to have that letter crowd.
They are all basically the same except for minor differences in the ports which are usually not noticeable in performance on any engine. I have a 70 car that came with an x on one side and a J on the other.
Re: Difference between X and O Heads? [Re: crackedback] #2836010
10/22/20 10:37 AM
10/22/20 10:37 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
In my testing X heads flow the best ootb.
They have a better shape to the intake port SSR, and as a result I also find them to be the easiest to get the flow numbers into the 250-260-270+ range.
On a totally stock 340 package, I can see where there would be essentially no performance difference.
The main difference between them is, the X head intake port was designed around using only a 2.02” valve.
The J head intake port was revised(primarily in the bowl and SSR area) so it could facilitate the use of either a 2.02” valve....... or a 1.88” valve.
Re: Difference between X and O Heads? [Re: fast68plymouth] #2836352
10/23/20 03:34 AM
10/23/20 03:34 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
This is what I have heard from some old mopar stocker racers.
Re: Difference between X and O Heads? [Re: fastmark] #2836761
10/23/20 10:25 PM
10/23/20 10:25 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
There are also some physical differences below the exhaust ports where the head bolts go. The footprint is wider on the later heads than on the X heads. J followed by X heads. Note the area of the exposed head bolts.
