Re: Difference between X and O Heads?
[Re: crackedback]
#2836010
10/22/20 10:37 AM
10/22/20 10:37 AM
fast68plymouth
So. Burlington, Vt.
In my testing X heads flow the best ootb. They have a better shape to the intake port SSR, and as a result I also find them to be the easiest to get the flow numbers into the 250-260-270+ range.
On a totally stock 340 package, I can see where there would be essentially no performance difference.
The main difference between them is, the X head intake port was designed around using only a 2.02” valve.
The J head intake port was revised(primarily in the bowl and SSR area) so it could facilitate the use of either a 2.02” valve....... or a 1.88” valve.
[Re: fast68plymouth]
#2836352
10/23/20 03:34 AM
10/23/20 03:34 AM
Posts: 6,435 Abilene, Texas
fastmark
Abilene, Texas
The J head intake port was revised(primarily in the bowl and SSR area) so it could facilitate the use of either a 2.02” valve....... or a 1.88” valve. This is what I have heard from some old mopar stocker racers.
[Re: fastmark]
#2836761
10/23/20 10:25 PM
10/23/20 10:25 PM
Posts: 18,679 Fresno, CA
Jim_Lusk
Fresno, CA
There are also some physical differences below the exhaust ports where the head bolts go. The footprint is wider on the later heads than on the X heads. J followed by X heads. Note the area of the exposed head bolts.
