indy cylinder valve covers #2835498
10/21/20 10:18 AM
10/21/20 10:18 AM
indy
70moparmike Offline OP
indy
what are you guys doing for pcv and oil fill on these valve covers? they tell you to use the moroso kit but i don't want screws sticking out of my valve covers? any pics of baffles and top sides would be appreciated. thanks moparts
Re: indy cylinder valve covers [Re: 70moparmike] #2835574
10/21/20 12:15 PM
10/21/20 12:15 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Mike I welded baffles into my INDY valve covers, and then have the Moroso screw in breathers. As for changing oil? use a funnel when you adjust valves, and have the covers off.
69 GTX 68 Road Runner
Re: indy cylinder valve covers [Re: JERICOGTX] #2835584
10/21/20 12:24 PM
10/21/20 12:24 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Here's what I ran initially: push in breathers.
Problem is they have a tight 0-ringseal, so I collapsed the rt side during an oil change.
I then adapted a PCV there, using a grommet.
Re: indy cylinder valve covers [Re: 70moparmike] #2835585
10/21/20 12:26 PM
10/21/20 12:26 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
This is my set up.
Re: indy cylinder valve covers [Re: 70moparmike] #2835625
10/21/20 01:28 PM
10/21/20 01:28 PM
AndyF Offline
AndyF  Offline
Indy messed up on those covers when they forgot to add a little extra material for screw in fittings. All they need to do is thicken the casting in a couple of spots on the cover so a person can drill and tap for a #12 o-ring type fitting. They should also add a few cast in bosses on the underside that can be drilled and tapped for screws to hold baffle plates. You can add all of that stuff but it requires some work.
Re: indy cylinder valve covers [Re: AndyF] #2835636
10/21/20 01:39 PM
10/21/20 01:39 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Andy, mine are drilled and tapped for the Moroso breathers. I do not run the nut that Moroso sends with, and can turn them out. The breathers have a O ring to seal them up.
Re: indy cylinder valve covers [Re: 70moparmike] #2835649
10/21/20 02:01 PM
10/21/20 02:01 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Pardon my dust, I have the front sheetmetal off for bodywork and the shop is pretty dusty right now.
I just used OE 1970 style breathers, stock Mopar grommets and Bolted in homemade baffles.
Button head screws would have worked better but this is functional.
You can weld in the baffles for a cleaner appearance.
I wasn't sure I would like this, but it has
been fine for years. I started out with a breather puke tank and hoses which also worked
but I got tired of the clutter + there was never any oil in the tank so it clearly didn't need any of that.
Rich H.
Esse Quam Videri
Re: indy cylinder valve covers [Re: ZIPPY] #2835690
10/21/20 03:37 PM
10/21/20 03:37 PM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
Right side cover is the same but no oil fill. I added the baffles because it was sucking a little oil. The baffle totally eliminated that problem.
Re: indy cylinder valve covers [Re: cl440] #2835702
10/21/20 04:08 PM
10/21/20 04:08 PM
lancaster,california
johnnycuda Offline
johnnycuda  Offline
I had baffled tubes welded on to each valve cover for a clamp style breather, welded a #20 AN male fitting onto the front section valley plate with a AN cap to pour the oil in.
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT!
1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air,
New daily driver-2003 Ram 2500 Cummins 5.9
'69 Valiant 2-dr, sleeper!
New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
Re: indy cylinder valve covers [Re: JERICOGTX] #2835791
10/21/20 07:12 PM
10/21/20 07:12 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
That car is so sick. Jeff, what brand of paint did you use on the engine. My last batch of VHT did not seem be as green as previous batches
Re: indy cylinder valve covers [Re: ZIPPY] #2835795
10/21/20 07:15 PM
10/21/20 07:15 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I have never seen the roll pin retainer on a steering coupler. Is that a factory part? Sorry for hijack!
Re: indy cylinder valve covers [Re: Jeremiah] #2835799
10/21/20 07:26 PM
10/21/20 07:26 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Dupli-color DE1619. You can get it at OReilly’s
Re: indy cylinder valve covers [Re: JERICOGTX] #2835941
10/22/20 05:47 AM
10/22/20 05:47 AM
indy
indy
thanks for all the pics. i like the stud welded in pic the best, did you have any clearance problems with the roller rockers? thanks
Re: indy cylinder valve covers [Re: Jeremiah] #2835956
10/22/20 07:42 AM
10/22/20 07:42 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Yes, it is a factory type repair part that I believe originated from a TSB.
It holds the stamped steel part on the back of the coupler more securely.
Over the last 30 years or so two sources that I know of in Metro Detroit have sold them.
Mike Randall had them for many years, but when he ran out Jim Fillmore started selling them.
I got this one from Jim.
Rich H.
Esse Quam Videri
Re: indy cylinder valve covers [Re: 70moparmike] #2835957
10/22/20 08:10 AM
10/22/20 08:10 AM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
Are you referring to mine with the threaded standoffs welded in?
Re: indy cylinder valve covers [Re: mopar dave] #2835961
10/22/20 08:14 AM
10/22/20 08:14 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I use a rubber grommit on the driver side with a pushin style breather on a tube extended a couple inches above the valve cover. I have a filter sock on the pushin breather. On the pass side i have a -12 hose connected to valve cover with AN fittings. I now get 0 oil leaks on top of my motor. Before this, after a spirted drive i would have oil running out valve covers and all over the valley tray. You need a way to vent the crankcase pressure and this set up works. Next option would have been a vacuum pump. No baffles in covers and rattle can caliper paint.
Re: indy cylinder valve covers [Re: mopar dave] #2835987
10/22/20 09:37 AM
10/22/20 09:37 AM
an8sec70cuda Offline
I welded a pair of male -10 AN fittings onto mine.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: indy cylinder valve covers [Re: an8sec70cuda] #2835989
10/22/20 09:39 AM
10/22/20 09:39 AM
On the hemi I welded in a -12 male fitting on the driver's side cover for the vacuum pump. Passenger's side got a welded in fill cap.
CHIP
Re: indy cylinder valve covers [Re: cl440] #2836067
10/22/20 12:36 PM
10/22/20 12:36 PM
indy
indy
yes
Re: indy cylinder valve covers [Re: 70moparmike] #2836241
10/22/20 08:07 PM
10/22/20 08:07 PM
In The Hills
jughed Offline
jughed  Offline
In The Hills
Weld everything ....
End those annoying Infolink ads with AdBlockPlus
https://adblockplus.org/
