Re: indy cylinder valve covers [Re: ZIPPY] #2836356
10/23/20 04:55 AM
10/23/20 04:55 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Originally Posted by ZIPPY
Pardon my dust, I have the front sheetmetal off for bodywork and the shop is pretty dusty right now.
I just used OE 1970 style breathers, stock Mopar grommets and Bolted in homemade baffles.
Button head screws would have worked better but this is functional.
You can weld in the baffles for a cleaner appearance.
I wasn't sure I would like this, but it has
been fine for years. I started out with a breather puke tank and hoses which also worked
but I got tired of the clutter + there was never any oil in the tank so it clearly didn't need any of that.
I have never seen the roll pin retainer on a steering coupler. Is that a factory part? Sorry for hijack!
Yes, it is a factory type repair part that I believe originated from a TSB.
It holds the stamped steel part on the back of the coupler more securely.
Over the last 30 years or so two sources that I know of in Metro Detroit have sold them.
Mike Randall had them for many years, but when he ran out Jim Fillmore started selling them.
I got this one from Jim.
Thanks Rich! I will give Detroit Muscle Technologies a call today.
Re: indy cylinder valve covers [Re: JERICOGTX] #2836358
10/23/20 04:58 AM
10/23/20 04:58 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Mike I welded baffles into my INDY valve covers, and then have the Moroso screw in breathers. As for changing oil? use a funnel when you adjust valves, and have the covers off.
That car is so sick. Jeff, what brand of paint did you use on the engine. My last batch of VHT did not seem be as green as previous batches
Dupli-color DE1619. You can get it at OReilly’s
Thanks for the info amigo. One of these days I need to see that 68 in person.
Re: indy cylinder valve covers [Re: Jeremiah] #2836513
10/23/20 02:13 PM
10/23/20 02:13 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
A friends dad made these for me. I drill and tap the bosses for a 10-32 machine screw. Did not go through the covers.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
