Preferences for external oil pick up?
#2835217
10/20/20 06:37 PM
10/20/20 06:37 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I've got to run an external oil pick up for the Imperial's 543. Being big fat street car it'll never see any real Gs on launch or braking, and you can forget cornering. I'm sure that 99% of the users have accereration in mind but what did you use and how do you like it?
I'm not sure if I'd rather weld a flange to the pan, use an O-ring bulkhead fitting, or what.
Re: Preferences for external oil pick up?
[Re: feets]
#2835227
10/20/20 07:15 PM
10/20/20 07:15 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
440source offers a couple options
[Re: feets]
#2835231
10/20/20 07:19 PM
10/20/20 07:19 PM
Posts: 5,618 long island NY
Ari440
long island NY
Im using the Indy/ melling oilpump with a single oil line #12 and a O ring static milidon oil pickup
1.39 9.85 - 137 mph
[Re: pittsburghracer]
#2835238
10/20/20 07:27 PM
10/20/20 07:27 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Hmmmm I don’t see it listed on their site now.
[Re: AndyF]
#2835250
10/20/20 07:44 PM
10/20/20 07:44 PM
Posts: 653 Fredericksburg Va
plycuda
Fredericksburg Va
The external stuff usually leaks so for a street car you should spend some extra time and make sure it is leak proof. You'll have to re-engineer the stuff that is on the market since it is all designed for drag racing and tends to leak. i have 2 cars sitting in the garage and both have dual line milodon systems and neither one leaks and amazing the one just sat for 7 months getting painted and fired up with 80 pounds instantly. that is a street car with no issues at all.
[Re: Cab_Burge]
#2835446
10/21/20 08:05 AM
10/21/20 08:05 AM
feets
Senior Management
Senior Management
Irving, TX
Likely the stock pan. I haven't found any aftermarket pieces that have the extra notch in the front corner for the C bodies.
[Re: AndyF]
#2835447
10/21/20 08:06 AM
10/21/20 08:06 AM
feets
Senior Management
Senior Management
Irving, TX
The external stuff usually leaks so for a street car you should spend some extra time and make sure it is leak proof. You'll have to re-engineer the stuff that is on the market since it is all designed for drag racing and tends to leak. Leaking is my primary concern.
[Re: feets]
#2835677
10/21/20 02:42 PM
10/21/20 02:42 PM
Posts: 13,374 Marion, South Carolina [><]
an8sec70cuda
I have the DMI washers/seals on two different engines using Milodon single line external oiling w/ static pickups. One seeped a little oil from day one. A thin coating of silicone b/t the washers and around the fittings stopped it and has been leak free ever since. The other required no sealer, just the supplied O-rings, and has been leak free.
[Re: an8sec70cuda]
#2835839
10/21/20 08:24 PM
10/21/20 08:24 PM
Posts: 4,275 Morrow, OH
markz528
Morrow, OH
I have the DMI washers/seals on two different engines using Milodon single line external oiling w/ static pickups. One seeped a little oil from day one. A thin coating of silicone b/t the washers and around the fittings stopped it and has been leak free ever since. The other required no sealer, just the supplied O-rings, and has been leak free. The DMI washers/seals did not work without mods on my Milodon pan because the hole in the pan was too big. I modified it to work. I am an o-ring junkie, and everything that I can o-ring I do. I had zero leaks on the race motor while on the dyno.
