Re: What Size DIY Headers??
[Re: mopowers]
#2834933
10/20/20 10:13 AM
10/20/20 10:13 AM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
I got all my pipe from summit,3/8" flange,6 j bends and maybe 4 u bends.I formed the pipe to the flange with a bench vise so ya mine are diy headers but i had someone do the welding after tacking all the pieces.No back purging while welding.I used 16g pipe.[fender exit]
[Re: Clanton]
#2834981
10/20/20 11:48 AM
10/20/20 11:48 AM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
Try Stahl ............. they might have something left over for a kit. I'm not sure who took the business over , but I am under the impression that there was a good bit of inventory left over and someone is still making headers there. I built the headers for my '65 Dart with a W-9 headed small block using a Stahl kit , SPD flanges and no small amount of head scratching and creative use of the English language. There isn't a ton of room , and it wasn't particularly cheap either. I would not be afraid to farm the job out if I had to do it again , and especially if I still had factory inner fenders and shock towers. Stahl headers
[Re: mopowers]
#2835379
10/20/20 11:58 PM
10/20/20 11:58 PM
Posts: 31,052 Oregon
AndyF
Thanks for the ideas guys. As far as length goes, do you guys simply put the collector where you want it and connect the dots netting whatever length it takes (obviously within reason).
Are 2" primaries adequate for 600hp? Depends if you're building dyno headers or car headers. For an early A body header you'll be lucky just to get four tubes into a collector regardless of length, size and number of bends. Those cars are horrible for headers. If you were building a set of dyno headers then 2 inch would be too big for 600 hp and the length is a critical dimension. For an early A body car all the theory goes out the window and you are just left with what you can fit into the car.
[Re: AndyF]
#2835390
10/21/20 12:28 AM
10/21/20 12:28 AM
tubtar
St. Paul , Mn.
Are 2" primaries adequate for 600hp? Depends if you're building dyno headers or car headers. For an early A body header you'll be lucky just to get four tubes into a collector regardless of length, size and number of bends. Those cars are horrible for headers. If you were building a set of dyno headers then 2 inch would be too big for 600 hp and the length is a critical dimension. For an early A body car all the theory goes out the window and you are just left with what you can fit into the car. Absolute truth. These are 1 7/8 " primaries , but I took a dull axe to the inner fenders to make room , and it still got really tight on the driver's side. I did get a nice straight shot before the first bend , and they will go on and off without too much trouble. Still had to run one tube on each side outside the frame rail and wound up with longer primaries than optimum to get them into the collector.............33 " to 34 " long was as close to equal length as I got , but since I am running mufflers and an X pipe , I don't think it cost me too much in the way of power. But with the kit , the flanges and coating , I was into them for somewhere around 700.00 And well north of 40 hours............maybe 48 ? This was my first , and hopefully last time building my own. If someone could do up a set for 1200.00 , I'd throw in a case of beer and my sincere thanks.
[Re: AndyF]
#2835392
10/21/20 12:29 AM
10/21/20 12:29 AM
Posts: 3,011 Sac, CA
mopowers
Sac, CA
Are 2" primaries adequate for 600hp? Depends if you're building dyno headers or car headers. For an early A body header you'll be lucky just to get four tubes into a collector regardless of length, size and number of bends. Those cars are horrible for headers. If you were building a set of dyno headers then 2 inch would be too big for 600 hp and the length is a critical dimension. For an early A body car all the theory goes out the window and you are just left with what you can fit into the car. That's kinda what I was thinking. Space is definitely the limiting factor. With the inner fenders and torsion bars out of the way, it'll be a tad easier though. Do you think I'd be better off going with 1-7/8" primaries? I'm not going for every last hp. Combo will likely be a pump gas 470 w/ standard port window Edelbrock RPM heads cnc'd by Modern cyl head, ~260-ish * @ .050" solid flat tappet. I assumed 2" primaries would be an appropriate size. What do you think?
[Re: jwb123]
#2835393
10/21/20 12:30 AM
10/21/20 12:30 AM
mopowers
Sac, CA
Buy yourself a program called pipemax, input your engine specs, and it will calculate the best tube diameter and length, as well as collector length, it will do single diameter or step diameter headers. It also is a good engine performance program, and does tons of other engine calculations. I have built several sets of headers using the program. http://www.maxracesoftware.com/ Thanks! I'll definitely look into that.
[Re: tubtar]
#2835394
10/21/20 12:36 AM
10/21/20 12:36 AM
mopowers
Sac, CA
Are 2" primaries adequate for 600hp? Depends if you're building dyno headers or car headers. For an early A body header you'll be lucky just to get four tubes into a collector regardless of length, size and number of bends. Those cars are horrible for headers. If you were building a set of dyno headers then 2 inch would be too big for 600 hp and the length is a critical dimension. For an early A body car all the theory goes out the window and you are just left with what you can fit into the car. Absolute truth. These are 1 7/8 " primaries , but I took a dull axe to the inner fenders to make room , and it still got really tight on the driver's side. I did get a nice straight shot before the first bend , and they will go on and off without too much trouble. Still had to run one tube on each side outside the frame rail and wound up with longer primaries than optimum to get them into the collector.............33 " to 34 " long was as close to equal length as I got , but since I am running mufflers and an X pipe , I don't think it cost me too much in the way of power. But with the kit , the flanges and coating , I was into them for somewhere around 700.00 And well north of 40 hours............maybe 48 ? This was my first , and hopefully last time building my own. If someone could do up a set for 1200.00 , I'd throw in a case of beer and my sincere thanks. Man, those look awesome!!! I take it you're not volunteering to come do mine? haha! Those photos help a lot! Good thing my time is free, I guess. Who did the coating on yours? This is what I'm working with. You know what they say - "where there's a will, there's a way."
[Re: mopowers]
#2835461
10/21/20 08:57 AM
10/21/20 08:57 AM
Posts: 10,039 MN
JERICOGTX
MN
www.stainlessheaders.comThey have everything you need, and you can choose either stainless, or mild steel.
69 GTX
68 Road Runner
[Re: mopowers]
#2835545
10/21/20 11:31 AM
10/21/20 11:31 AM
AndyF
Are 2" primaries adequate for 600hp? Depends if you're building dyno headers or car headers. For an early A body header you'll be lucky just to get four tubes into a collector regardless of length, size and number of bends. Those cars are horrible for headers. If you were building a set of dyno headers then 2 inch would be too big for 600 hp and the length is a critical dimension. For an early A body car all the theory goes out the window and you are just left with what you can fit into the car. That's kinda what I was thinking. Space is definitely the limiting factor. With the inner fenders and torsion bars out of the way, it'll be a tad easier though. Do you think I'd be better off going with 1-7/8" primaries? I'm not going for every last hp. Combo will likely be a pump gas 470 w/ standard port window Edelbrock RPM heads cnc'd by Modern cyl head, ~260-ish * @ .050" solid flat tappet. I assumed 2" primaries would be an appropriate size. What do you think? Measure the area of your exhaust port and go from there. I bet 1 3/4 will be big enough for that combo.
[Re: mopowers]
#2835640
10/21/20 01:45 PM
10/21/20 01:45 PM
tubtar
St. Paul , Mn.
I had a local guy do the coating..........Race Coatings in Forest lake , Mn. They came highly recommended by a couple local racers , and I was more than happy with their work. Race CoatingsYou will have as much room as you can get without going to a strut front. Make sure everything that the tubes will need to clear is in place , and get started on your 3-D jig saw puzzle. I used some .125 " aluminum wire to mock up the tube routing and give me an idea of how they should be shaped. Go slowly and try to minimize cuts and welds. If I could do it , it isn't rocket surgery.
[Re: tubtar]
#2835667
10/21/20 02:25 PM
10/21/20 02:25 PM
Posts: 2,256 IL
furious70
IL
engine masters has done a number of tests recently on header type, size, and exhaust length. It's a good watch in my book and great background info to have before building your own IMO.
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: AndyF]
#2835706
10/21/20 04:21 PM
10/21/20 04:21 PM
mopowers
Sac, CA
I just measured the exhaust ports and they're are 1.310" x 1.775" (2.325 in^2). You think 1-3/4" would be best? All the exhaust component companies I've contacted seem to think 2" primaries are best for 600 hp. Also, I may not stick with the heads I have and I'd like to leave room for growth in the future. engine masters has done a number of tests recently on header type, size, and exhaust length. It's a good watch in my book and great background info to have before building your own IMO. Thanks for the reminder. I'll have to go back and re-watch those.
