Re: 440/HEMI 'The Block' by Bulldog Performance.
[Re: migsBIG]
#2834714
10/19/20 05:38 PM
10/19/20 05:38 PM
Posts: 4,210 New York
polyspheric
New York
Who wrote this: "priority oiling that supplied oil to the main and rod bearings prior to the lifters, ensuring lifter failure won’t happen as a result of total loss of main bearing oil pressure"?
Actually, priority oiling that supplied oil to the main and rod bearings prior to the lifters, ensuring lifter failure WILL happen as a result of total loss of main bearing oil pressure Using the high school shop class again...
Boffin Emeritus
[Re: migsBIG]
#2834750
10/19/20 07:33 PM
10/19/20 07:33 PM
Posts: 715 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
I have one it's a 400 block, it's at the machine shop getting the cylinders finished, the pistons are on the brown truck, 55mm cam should be shipped next week. The b1 MC heads are waiting. So far it looks good, Should have no issue with 1000HP
Joe .
Without Data, you’re just another guy with an opinion.
[Re: polyspheric]
#2834752
10/19/20 07:35 PM
10/19/20 07:35 PM
Posts: 11,645 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Actually, priority oiling that supplied oil to the main and rod bearings prior to the lifters, ensuring lifter failure WILL happen as a result of total loss of main bearing oil pressure Using the high school shop class again... Total loss of main bearing oil pressure is bad. M'kay? Story is a year and a half old. Bulldog is a moving target. I don't know the status at this moment. Maybe someone else does. The one I saw at PRI 2 years ago was pretty. And the word was, all the issues were resolved and they'd be cranking them out.
[Re: CMcAllister]
#2834782
10/19/20 09:01 PM
10/19/20 09:01 PM
Posts: 6,148 Melbourne , Australia
LA360
A friend bought a 400 B based block for a clients build. He mentioned having to tweak a few things, but the casting looks pretty solid. It's a twin turbo (a pair of 76mm turbos from memory), Trickflow 270 headed deal for a 68-69 Charger. Not sure how they're going with it, the guy that the client got to do all of plumbing, intake and oil pan produced a bunch of grossly overpriced rubbish.
Alan Jones
[Re: Lee446]
#2834855
10/20/20 02:42 AM
10/20/20 02:42 AM
Posts: 43,259 Bend,OR USA
Cab_Burge
I hope to have one of his wedge 4.500 RB blocks home before turkey day, I'll post pictures and my thoughts on what I get it after that It's being finish machine at a shop he recommended to use near his shop, bore, deck, lifter bores and main bearing bores
[Re: Cab_Burge]
#2835087
10/20/20 02:32 PM
10/20/20 02:32 PM
Posts: 4,287 Morrow, OH
markz528
Morrow, OH
I do not believe that the Bulldog and The Block are the same blocks. I have one of the first The Blocks that came from Muscle Motors - came from the first casting run of 10 blocks.
[Re: AndyF]
#2835145
10/20/20 04:19 PM
10/20/20 04:19 PM
Posts: 14,513 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I’m not getting a warm & fuzzy feeling from Rays post.
[Re: fast68plymouth]
#2835148
10/20/20 04:26 PM
10/20/20 04:26 PM
Posts: 713 Lake Villa Il
INTMD8
Lake Villa Il
Wow that sounds horrible. Stop leak? Ahhh, hell no.
[Re: INTMD8]
#2835167
10/20/20 05:09 PM
10/20/20 05:09 PM
Posts: 6,426 Abilene, Texas
fastmark
Abilene, Texas
WOW! This is why I would not want to be a test mule for a new block. I think I will keep my world block. And check it very thoroughly!
[Re: AndyF]
#2835199
10/20/20 06:02 PM
10/20/20 06:02 PM
Posts: 131 Conroe , Texas
iapco103
Conroe , Texas
I guess I should count myself fairly lucky with my Bulldog block.
Known issues: ( 1 ) needed to be align honed , this was stated on the paper work with the block, ( 2 ) needed cylinders honed , no big deal
Discovered issues: ( 1 ) one mechanical fuel pump bolt hole not tapped at all. ( 2 ) no clearance machined for mech fuel pump body, more of an annoyance than a problem. ( 3 ) Had to fabricate my own oil pickup adapter because of the problem stated by Barton. ( 4 ) fuel pump pushrod hole too small, had to be reamed to size. ( 5 ) one main bearing tang located wrong. ( 6 ) oil dipstick hole too small, had to be reamed to size. ( 7 ) lifter valley cylinder head studs are a special length, don't ask me how I know,LOL. ( 8 ) rodding from the casting process left in the water jacket, you must look carefully in there and pick it out. ( 9 ) small pit in one cylinder, this was characterized by Nickens Bros. as a sand pit from the casting process. We both agreed that for a street engine it was no big deal.
This block passed a pressure test with flying colors, this should be your first step with any block of unknown quality. Paul
[Re: migsBIG]
#2835442
10/21/20 07:53 AM
10/21/20 07:53 AM
Posts: 10,013 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Thanks for the info. Can't see spending that much money and being told to use block filler to fix problem that shouldn't be there to begin with. Will pass and see what other options come along for blocks. Give MARSH PERFORMANCE a call. Todd from Marsh has a good reputation on here and knows whats available. I have my name on a new aluminum block that he gas prepaid for. He didn't ask for anything down.
[Re: gregsdart]
#2835465
10/21/20 09:06 AM
10/21/20 09:06 AM
Posts: 965 Odessa, Fl
blowndart
Odessa, Fl
Thanks for the info. Can't see spending that much money and being told to use block filler to fix problem that shouldn't be there to begin with. Will pass and see what other options come along for blocks. Give MARSH PERFORMANCE a call. Todd from Marsh has a good reputation on here and knows whats available. I have my name on a new aluminum block that he gas prepaid for. He didn't ask for anything down. How long is the current wait on the BME aluminum block?
