'68 B-Body Window Regulator Rivets #2833680
10/16/20 10:37 PM
10/16/20 10:37 PM
San Angelo, Texas, U.S.A.
1968RR Offline OP
1968RR  Offline OP
Does anybody happen to know where I can buy the metal rivets that attach the gear to the rest of the window regulator for a '68 B-body? There are several holes in the gear that the rivet can go into for different models, and the used regulator that I bought has the rivet through the wrong hole for a '68 Road Runner. This is for the front window, not the rear one.
Thanks in advance for any help.
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
Re: '68 B-Body Window Regulator Rivets [Re: 1968RR] #2833712
10/17/20 12:18 AM
10/17/20 12:18 AM
1968RR Offline OP
1968RR  Offline OP
I really just need to know the size of the rivet. It looks to be either 1/4" or 3/16" diameter and either 3/8" or 1/2" long.
Re: '68 B-Body Window Regulator Rivets [Re: 1968RR] #2834023
10/17/20 08:37 PM
10/17/20 08:37 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
shruggy bump
you can use a drill bit to estalish the hise size, length ?? buy a couple of different ones, they're cheap wink I'd go with Steel or Stainless steel if your rivet gun can handle it twocents beer
Re: '68 B-Body Window Regulator Rivets [Re: TJP] #2834158
10/18/20 10:29 AM
10/18/20 10:29 AM
1968RR Offline OP
1968RR  Offline OP
That's what I ended up doing. A 1/4"-diameter, 1/2"-long rivet proved to be the right size. up
