Re: CalTrac or Ladder bars ?? Post your 60' and info
[Re: an8sec70cuda]
#2835152
10/20/20 04:32 PM
10/20/20 04:32 PM
Posts: 2,471 Sydney,Australia
tex013
Sydney,Australia
mines not as fast as some . Best of 1.42 mostly 1.44 range . Caltrac with XHD springs . Yes i would like to go split mono but budget isnt there yet and its working fine . Yes i run radials and bracket race only so track not normally "radial prepped " . Car is very consistant good enough to win a track championship . I believe choice is about what you want as an end result . Both can give the same result . Shocks are probably more important with Caltracs and more so with radials .
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: an8sec70cuda]
#2835467
10/21/20 09:10 AM
10/21/20 09:10 AM
Posts: 4,696 On the parachute mount
n20mstr
One thing to consider is that most of these super fast leaf spring radial cars (like Rhodes') have to be on a flypaper track to run these numbers. I don't mean decent prep, I mean fall down and you can't get back up prep.
Take two cars, equally set up but one on ladder bars and one on leaf springs...now put them on a marginally prepped typical test and tune track. My money is on the ladder bar car. Dave Dudek has been 9.80s on polyglas GT tires...does that mean everyone slower than 9.80s is a fool for running sticky tires?
Look, I'm not saying Cal-Tracs aren't great...I run them on 2 of my own cars and I've been sorta fast (mid 5s in the 1/8 at 3900 lbs), but the simple truth is that ladder bars are superior. You really think any of these leaf spring guys wouldn't jump ship and weld in ladder bars if their class allowed it? FLYPAPER is correct, look at the pics from Oct streetcar shootout, and the next day "Radial Prep" rental, there is a BUNCH of people that lost shoes !! LMAO
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#2835529
10/21/20 11:02 AM
10/21/20 11:02 AM
Posts: 3,527 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
3200lbs 1969 Barracuda 347ci, Caltracs with mono springs, old Koni SA on front, equally old Rancho 5 way SA on back.
Best 60 to date is 1.387.
[Re: n20mstr]
#2835539
10/21/20 11:18 AM
10/21/20 11:18 AM
Posts: 11,686 W. Kentucky
justinp61
W. Kentucky
Look, I'm not saying Cal-Tracs aren't great...I run them on 2 of my own cars and I've been sorta fast (mid 5s in the 1/8 at 3900 lbs), but the simple truth is that ladder bars are superior. You really think any of these leaf spring guys wouldn't jump ship and weld in ladder bars if their class allowed it? FLYPAPER is correct, look at the pics from Oct streetcar shootout, and the next day "Radial Prep" rental, there is a BUNCH of people that lost shoes !! LMAO Yes, and these tracks are usually prepped the full 1/8 mile. Several years ago when I had the 408 in my Dart it ran a bunch of 1.38 60' before it killed the converter. Street/strip deal, 3260#, Cal-Tracs, monos, CE three ways on the front and Rancho nine ways on the rear.
[Re: n20mstr]
#2835587
10/21/20 12:28 PM
10/21/20 12:28 PM
Posts: 1,178 Indy
FlyFish
Indy
67 Barracuda street/race car with 408, Caltracs, monos, Calvert 90/10's up front and their 9 way adjustables out back set on 6. The bars are in the bottom hole, 1 flat preload driver side, 2 flats preload on the passenger side. Tire is a 275/60/r15 Hoosier drag radial. Best is 1.38 60'.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
[Re: humpty]
#2837220
10/25/20 10:59 AM
10/25/20 10:59 AM
Posts: 2,946 Windsor ,Ca.
Keith Richards
Windsor ,Ca.
3800lb RR with me, Cal Trac Mono's/bars, bottom hole, 2 flats preload either side with me in the car which leaves a nickel gap on drivers side when out, Strange double adjustable shocks on back, single adjustable front, 30x9-15 C07 Hoosiers @18psi, pump gas 505" with max wedge ported Indy EZ heads by Dwayne Porter, .670 ish Comp roller cam, 4.10 Dana 1.43 - 1.46 60's depending on track/heat conditions, best to date with current set up is 10.34 @ 130.70 in 90 degree heat. Important to note I am taking 14* of timing out at the hit and ramping it back in for 2 seconds with MSD grid to act as traction control for the 9" radials which works very well and consistent 60'.
[Re: Keith Richards]
#2837236
10/25/20 11:42 AM
10/25/20 11:42 AM
Posts: 570 UK
rb446
UK
Almost exactly the same performance as our '69RR, ET/60fts/chassis set up re caltrac settings apart from the size of our motor and we run through mufflers
1969 'Cuda 446ci, best 9.96@133.9 in 1990 1971 340 'Cuda, best 11.01@122.8 in 1987
#2837276
10/25/20 01:48 PM
10/25/20 01:48 PM
Posts: 570 UK
rb446
UK
Thanks, I would much prefer to have your attitude on the launch though, need to really get the 1" lower set of rear leaf segments and maybe sliders or get some 28" front runners much the same as you have over our heavy 26" street tyres, its already front heavy with the Mega Block and stock 11" drums and metal bumpers.
#2837305
10/25/20 02:42 PM
10/25/20 02:42 PM
Posts: 4,701 Wichita
GY3
Wichita
Man, that's a cool car! Have you considered getting your rear shocks in a more vertical position?
[Re: n20mstr]
#2837488
10/26/20 08:39 AM
10/26/20 08:39 AM
Posts: 13,387 Marion, South Carolina [><]
an8sec70cuda
FWIW...I've been 1.320 to the 60' on motor only footbraking my car. Cal-Tracs, mono springs, Rancho 9 way rear shocks, old Lakewood 90/10s up front I slightly modified by changing the oil in them. 295-65 drag radials at 20 psi. Best of 9.54 at 140.4 mph. No pulling timing or anything, just flatfooting it w/ all it's got.
I've been 1.30 to the 60' on nitrous. I've been quicker, but the 60' beam got tripped w/ the back tires...should have been a 1.28-1.29 sixty foot if the frontend was down. Now w/ Viking DA shocks at all 4 corners and 1" less front travel. The shocks made a big difference getting the car to hook on the nitrous. Same otherwise...295-65 drag radials, Cal-Tracs, etc. I've been a best 1/4 of 8.91 so far, but my current 1/8 mile times are a couple tenths quicker. Should get a new 1/4 timeslip soon.
[Re: an8sec70cuda]
#2837521
10/26/20 11:31 AM
10/26/20 11:31 AM
Posts: 19,384 Las Vegas
Al_Alguire
Las Vegas
I hear that Shiloh guy runs pretty well on Caltracs with an NA SB
[Re: J_BODY]
#2838919
10/29/20 06:01 PM
10/29/20 06:01 PM
Posts: 54 VA Beach, VA
Runnoft
VA Beach, VA
I'm not sure being on a "Flypaper" track is required for a fast Caltrac/Leafspring car. I've been 1.09 60' with Assasin bars (almost the same) at Cecil county on an August test day when people were struggling to go down. I normally run 1.06-1.07 on flypaper tracks.
Cruiser: 66 Dodge Coronet 500, Indy SR 440, Gen 7 Accel EFI = 11.38 @ 116. Racing: Brand X, X275 Procharged Smallblock on M1, Leafsprings, Holley EFI = 4.30 @ 168
[Re: J_BODY]
#2838938
10/29/20 06:42 PM
10/29/20 06:42 PM
Posts: 9,874 MI, usa
dvw
MI, usa
1.24-.26 60 on ladder bars.... until it goes 1.35 and you lose the round . 3 speed 10.5 tire because nobody ever properly explained bracket racing to me Ah, I’m not alone Doug
[Re: dvw]
#2839176
10/30/20 09:15 AM
10/30/20 09:15 AM
Posts: 4,991 new jersey usa
11secdart
new jersey usa
Cal- Tracs ..bottom hole, monoleafs, Rancho shocks, drag radials @18lbs. leaving at 2,000 1.49-1.54 60 ft. depending on track ..has been 1.48.. the past 2 weekends in 12 runs 1.62-1.64 ( deep staging ) on throttle stop to run 11.50s
