Re: CalTrac or Ladder bars ?? Post your 60' and info [Re: an8sec70cuda] #2835152
10/20/20 04:32 PM
10/20/20 04:32 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
mines not as fast as some .
Best of 1.42 mostly 1.44 range . Caltrac with XHD springs . Yes i would like to go split mono but budget isnt there yet and its working fine .
Yes i run radials and bracket race only so track not normally "radial prepped " . Car is very consistant good enough to win a track championship .
I believe choice is about what you want as an end result . Both can give the same result . Shocks are probably more important with Caltracs and more so with radials .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: CalTrac or Ladder bars ?? Post your 60' and info [Re: an8sec70cuda] #2835467
10/21/20 09:10 AM
10/21/20 09:10 AM
On the parachute mount
N
n20mstr Offline OP
n20mstr  Offline OP
N
Originally Posted by an8sec70cuda
One thing to consider is that most of these super fast leaf spring radial cars (like Rhodes') have to be on a flypaper track to run these numbers. I don't mean decent prep, I mean fall down and you can't get back up prep.
Take two cars, equally set up but one on ladder bars and one on leaf springs...now put them on a marginally prepped typical test and tune track. My money is on the ladder bar car.
Dave Dudek has been 9.80s on polyglas GT tires...does that mean everyone slower than 9.80s is a fool for running sticky tires?
Look, I'm not saying Cal-Tracs aren't great...I run them on 2 of my own cars and I've been sorta fast (mid 5s in the 1/8 at 3900 lbs), but the simple truth is that ladder bars are superior. You really think any of these leaf spring guys wouldn't jump ship and weld in ladder bars if their class allowed it?
FLYPAPER is correct, look at the pics from Oct streetcar shootout, and the next day "Radial Prep" rental, there is a BUNCH of people that lost shoes !! LMAO
....BAD A$$ STREET CAR.....
Re: CalTrac or Ladder bars ?? Post your 60' and info [Re: n20mstr] #2835529
10/21/20 11:02 AM
10/21/20 11:02 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
3200lbs 1969 Barracuda 347ci, Caltracs with mono springs, old Koni SA on front, equally old Rancho 5 way SA on back.
Best 60 to date is 1.387.
Re: CalTrac or Ladder bars ?? Post your 60' and info [Re: n20mstr] #2835539
10/21/20 11:18 AM
10/21/20 11:18 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Yes, and these tracks are usually prepped the full 1/8 mile.
Several years ago when I had the 408 in my Dart it ran a bunch of 1.38 60' before it killed the converter. Street/strip deal, 3260#, Cal-Tracs, monos, CE three ways on the front and Rancho nine ways on the rear.
Re: CalTrac or Ladder bars ?? Post your 60' and info [Re: n20mstr] #2835587
10/21/20 12:28 PM
10/21/20 12:28 PM
Indy
FlyFish Offline
FlyFish  Offline
Indy
67 Barracuda street/race car with 408, Caltracs, monos, Calvert 90/10's up front and their 9 way adjustables out back set on 6. The bars are in the bottom hole, 1 flat preload driver side, 2 flats preload on the passenger side. Tire is a 275/60/r15 Hoosier drag radial. Best is 1.38 60'.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: CalTrac or Ladder bars ?? Post your 60' and info [Re: n20mstr] #2835788
10/21/20 07:09 PM
10/21/20 07:09 PM
Minnesota, USA
humpty Offline
humpty  Offline
Minnesota, USA
Hi everyone,
It's been a while. This is the first year with the new motor. Still stock length Cal-trac split-monos and bars in the stock location, Mencser DA's all around on 275 drag radials, best 60' so far is 1.31. Cheers!
Re: CalTrac or Ladder bars ?? Post your 60' and info [Re: humpty] #2837220
10/25/20 10:59 AM
10/25/20 10:59 AM
Windsor ,Ca.
K
Keith Richards Offline
K
Windsor ,Ca.
3800lb RR with me, Cal Trac Mono's/bars, bottom hole, 2 flats preload either side with me in the car which leaves a nickel gap on drivers side when out, Strange double adjustable shocks on back, single adjustable front, 30x9-15 C07 Hoosiers @18psi, pump gas 505" with max wedge ported Indy EZ heads by Dwayne Porter, .670 ish Comp roller cam, 4.10 Dana 1.43 - 1.46 60's depending on track/heat conditions, best to date with current set up is 10.34 @ 130.70 in 90 degree heat. Important to note I am taking 14* of timing out at the hit and ramping it back in for 2 seconds with MSD grid to act as traction control for the 9" radials which works very well and consistent 60'.
Re: CalTrac or Ladder bars ?? Post your 60' and info [Re: Keith Richards] #2837236
10/25/20 11:42 AM
10/25/20 11:42 AM
UK
rb446 Offline
rb446  Offline
UK
Almost exactly the same performance as our '69RR, ET/60fts/chassis set up re caltrac settings apart from the size of our motor and we run through mufflers up
1969 'Cuda 446ci, best 9.96@133.9 in 1990
1971 340 'Cuda, best 11.01@122.8 in 1987
Re: CalTrac or Ladder bars ?? Post your 60' and info [Re: rb446] #2837245
10/25/20 12:14 PM
10/25/20 12:14 PM
Windsor ,Ca.
K
K
Windsor ,Ca.
Yes RB446 I noticed that, beautiful car you have. I had a full 3" exhaust out the back with Flowmasters and it was 10.40's @ 130 that made it able to go on the street for close car shows/ hamburger stands ect. Thinking of putting that all back on soon. Here is an on car video of it with it's former paint job and full exhaust run.
https://youtu.be/kSmqJXyN0OE
Re: CalTrac or Ladder bars ?? Post your 60' and info [Re: Keith Richards] #2837276
10/25/20 01:48 PM
10/25/20 01:48 PM
UK
rb446 Offline
rb446  Offline
UK
Thanks, I would much prefer to have your attitude on the launch though, need to really get the 1" lower set of rear leaf segments and maybe sliders or get some 28" front runners much the same as you have over our heavy 26" street tyres, its already front heavy with the Mega Block and stock 11" drums and metal bumpers.
Re: CalTrac or Ladder bars ?? Post your 60' and info [Re: Keith Richards] #2837305
10/25/20 02:42 PM
10/25/20 02:42 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Man, that's a cool car! Have you considered getting your rear shocks in a more vertical position?
'63 Dodge 330
11.19 @ 121 mph
Re: CalTrac or Ladder bars ?? Post your 60' and info [Re: GY3] #2837478
10/26/20 07:36 AM
10/26/20 07:36 AM
NE Ohio
DoubleD Online content
DoubleD  Online Content
NE Ohio
64 Dodge - 572 HEMI - 3850lbs at the line - CalTracs with split mono leaf's in the factory mounts - set on bottom hole - using strange double adjustable shocks at all four corners - all with a 9' x 30" radial CO-7 compound Hoosiers - been 9.65 at 142.5MPH - 60' is usually 1.40 -1.42 - Thinking of changing up to ladder bars this winter to get a 10.5 tire under it - the CalTracs hook perfectly on a prepped track - but on a marginal track it can be an adventure to get it to leave consistent.
Re: CalTrac or Ladder bars ?? Post your 60' and info [Re: n20mstr] #2837488
10/26/20 08:39 AM
10/26/20 08:39 AM
an8sec70cuda Offline
FWIW...I've been 1.320 to the 60' on motor only footbraking my car. Cal-Tracs, mono springs, Rancho 9 way rear shocks, old Lakewood 90/10s up front I slightly modified by changing the oil in them. 295-65 drag radials at 20 psi. Best of 9.54 at 140.4 mph. No pulling timing or anything, just flatfooting it w/ all it's got.
I've been 1.30 to the 60' on nitrous. I've been quicker, but the 60' beam got tripped w/ the back tires...should have been a 1.28-1.29 sixty foot if the frontend was down. Now w/ Viking DA shocks at all 4 corners and 1" less front travel. The shocks made a big difference getting the car to hook on the nitrous.
Same otherwise...295-65 drag radials, Cal-Tracs, etc.
I've been a best 1/4 of 8.91 so far, but my current 1/8 mile times are a couple tenths quicker. Should get a new 1/4 timeslip soon.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: CalTrac or Ladder bars ?? Post your 60' and info [Re: an8sec70cuda] #2837521
10/26/20 11:31 AM
10/26/20 11:31 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I hear that Shiloh guy runs pretty well on Caltracs with an NA SB
Re: CalTrac or Ladder bars ?? Post your 60' and info [Re: Al_Alguire] #2837889
10/27/20 09:09 AM
10/27/20 09:09 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
1.24-.26 60 on ladder bars.... until it goes 1.35 and you lose the round laugh2. 3 speed 10.5 tire because nobody ever properly explained bracket racing to me
Re: CalTrac or Ladder bars ?? Post your 60' and info [Re: J_BODY] #2838919
10/29/20 06:01 PM
10/29/20 06:01 PM
VA Beach, VA
Runnoft Offline
Runnoft  Offline
VA Beach, VA
I'm not sure being on a "Flypaper" track is required for a fast Caltrac/Leafspring car. I've been 1.09 60' with Assasin bars (almost the same) at Cecil county on an August test day when people were struggling to go down. I normally run 1.06-1.07 on flypaper tracks.
Cruiser: 66 Dodge Coronet 500, Indy SR 440, Gen 7 Accel EFI = 11.38 @ 116.
Racing: Brand X, X275 Procharged Smallblock on M1, Leafsprings, Holley EFI = 4.30 @ 168
Re: CalTrac or Ladder bars ?? Post your 60' and info [Re: J_BODY] #2838938
10/29/20 06:42 PM
10/29/20 06:42 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Ah, I’m not alone
Doug
Re: CalTrac or Ladder bars ?? Post your 60' and info [Re: dvw] #2839176
10/30/20 09:15 AM
10/30/20 09:15 AM
new jersey usa
11secdart Online content
11secdart  Online Content
new jersey usa
Cal- Tracs ..bottom hole, monoleafs, Rancho shocks, drag radials @18lbs. leaving at 2,000 1.49-1.54 60 ft. depending on track ..has been 1.48.. the past 2 weekends in 12 runs 1.62-1.64 ( deep staging ) on throttle stop to run 11.50s
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
