CalTrac or Ladder bars ?? Post your 60' and info #2833331
10/16/20 09:57 AM
10/16/20 09:57 AM
On the parachute mount
N
n20mstr Offline OP
n20mstr  Offline OP
N
Me i have ladder bars, but come on now, Ron Rhodes went 1.01 with cal tracs and a 275 radial.
Post up your suspension, 60' and tire (shocks too if you want )
ladder bar, 1.16, Et Street R 275 radial. Santhuffs NOT radial valved
....BAD A$$ STREET CAR.....
Re: CalTrac or Ladder bars ?? Post your 60' and info [Re: n20mstr] #2833332
10/16/20 10:00 AM
10/16/20 10:00 AM
bronx n.y
O
one bad fish Offline
O
bronx n.y
i like caltracs
Re: CalTrac or Ladder bars ?? Post your 60' and info [Re: n20mstr] #2833385
10/16/20 11:15 AM
10/16/20 11:15 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Split mono Cal-trac leaf springs A-body length. The Cal-Trac bars are set nickel width gap between spring and pivot with me out of the car, bar set in lower hole and Rancho/Calvert 9 way single adjustables shocks.
1.37 60 ft. on a 275/60/15 M/T drag radial with 18 psi tire pressure. Heavy 3,600 lbs. street car.
'63 Dodge 330
11.19 @ 121 mph
Re: CalTrac or Ladder bars ?? Post your 60' and info [Re: one bad fish] #2833392
10/16/20 11:23 AM
10/16/20 11:23 AM
Post falls, Idaho
rgreule Offline
rgreule  Offline
Post falls, Idaho
No times yet. But tried to buy the best of the best parts. Hoping to get down in the 1.0x to 1.1x times on a good track
Menscers all the way around, sliders assassin bars, Calvert springs, ARB, and wishbone to keep it all straight. Might modify my sliders to put them on a downward angle forward to help get more separation.
Re: CalTrac or Ladder bars ?? Post your 60' and info [Re: rgreule] #2833412
10/16/20 11:44 AM
10/16/20 11:44 AM
Cleveland Ohio
10secGTX Offline
10secGTX  Offline
Cleveland Ohio
The best was 1.36 at Bowling Green at # 3855 lbs with Cal Tracs and Rancho's set at 9 on a 9" Drag Radial Pro. This photo was taken at Dragway 42 1.39
Re: CalTrac or Ladder bars ?? Post your 60' and info [Re: 10secGTX] #2833460
10/16/20 01:28 PM
10/16/20 01:28 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Rear: Menscer valved Afco .ARB, Caltracs, shackles. 29.5 x 10 M/T Pro Drag Radial. and a 4;10 Dana. Front is pretty much QA1 with Heims on the UCA and Santhuff shocks. We've been 1.34 and 1.37 with the rears. As below, not the best way to go forward but it seems to work. This is with the "little" 580 motor. We're hoping to get into the 8.99s with the big motor (N/A) smile
Re: CalTrac or Ladder bars ?? Post your 60' and info [Re: rgreule] #2833476
10/16/20 01:55 PM
10/16/20 01:55 PM
Ct
W
Wirenut Offline
Wirenut  Offline
W
Ct
Good god.
Qualifies as a superstructure!!
Re: CalTrac or Ladder bars ?? Post your 60' and info [Re: Wirenut] #2833478
10/16/20 01:58 PM
10/16/20 01:58 PM
Ct
W
Wirenut Offline
Wirenut  Offline
W
Ct
I think something helpful to know is not just how fast but truly how consistent and how adaptable to track conditions.
Whos winning bracket and index races ?
Re: CalTrac or Ladder bars ?? Post your 60' and info [Re: Wirenut] #2833480
10/16/20 02:01 PM
10/16/20 02:01 PM
Ct
W
Wirenut Offline
Wirenut  Offline
W
Ct
It also seems like a lot of the CT users are running radials .
Is that the tire that works best with them?
Re: CalTrac or Ladder bars ?? Post your 60' and info [Re: Wirenut] #2833490
10/16/20 02:19 PM
10/16/20 02:19 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
We improved a LOT switching to radials, so much so it caught me out blush
Re: CalTrac or Ladder bars ?? Post your 60' and info [Re: n20mstr] #2833687
10/16/20 10:49 PM
10/16/20 10:49 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Ladder bars,29.10.5,chassis engineering single adj rear shocks, usually 1.30-32 60' with a best of 1.27.
Re: CalTrac or Ladder bars ?? Post your 60' and info [Re: racerx] #2833703
10/16/20 11:49 PM
10/16/20 11:49 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
1.21 on rear tire . Mencsers on all 4 corners, 275 pro . Car is 3280 with me in it .
Re: CalTrac or Ladder bars ?? Post your 60' and info [Re: Wirenut] #2833749
10/17/20 07:31 AM
10/17/20 07:31 AM
UK
rb446 Offline
rb446  Offline
UK
3800lb RR as posted in other thread, Mono's/bars, bottom hole, 2 flats preload either side, 90/10's>9-ways rear set on 7 stiff, 10x29 C07 Hoosiers@16psi, 720ftlb Motor@4400, 4200 stall, 4.10's low first gear 727, SLR of 11+, it Dead Hooks, but slow 1.43 60's compared to you guys, best to date and 10.35's through mufflers. have run 1.43/1.43/1.44 60's when track has heat, when things get cold it needs a bit more thought on shock settings....we are still tuning as only around 11 runs on new combo. Our NSS brkt class we run here (leaf susp only) has a majority of Mopars, many A-bodies in the 9's, including a Petty Superbird tribute with a 572 Hemi, 99.9% of them run caltracs/mono's and are very consistent with them, one of our members ('65 Belvedere) who double entered (NSS and Pro-ET) won both classes, caltrac car. Ladder bars would work better for us though I believe and it would be easier to tune and change ride height which we really need to do.
1969 'Cuda 446ci, best 9.96@133.9 in 1990
1971 340 'Cuda, best 11.01@122.8 in 1987
Re: CalTrac or Ladder bars ?? Post your 60' and info [Re: rb446] #2833752
10/17/20 08:08 AM
10/17/20 08:08 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Power, weight and, SLR also are a big factors here. Mine has a 36"ladder bar, Koni doubles, 130lb spring, 4.10, fresh 10.5x31 M/T bias, 2.45 1st, 3350lbs, aprox 900hp. Best 1.240. Upgraded to Afco Big Gun, 120lb spring, 4.30. Still chasing the set up. Now been 1.261 best on 120 pass tires. These are off the foot brake. Both of these numbers were at local tracks with no special prep.
Doug
Re: CalTrac or Ladder bars ?? Post your 60' and info [Re: dvw] #2834480
10/19/20 08:46 AM
10/19/20 08:46 AM
an8sec70cuda Offline
One thing to consider is that most of these super fast leaf spring radial cars (like Rhodes') have to be on a flypaper track to run these numbers. I don't mean decent prep, I mean fall down and you can't get back up prep.
Take two cars, equally set up but one on ladder bars and one on leaf springs...now put them on a marginally prepped typical test and tune track. My money is on the ladder bar car.
Dave Dudek has been 9.80s on polyglas GT tires...does that mean everyone slower than 9.80s is a fool for running sticky tires?
Look, I'm not saying Cal-Tracs aren't great...I run them on 2 of my own cars and I've been sorta fast (mid 5s in the 1/8 at 3900 lbs), but the simple truth is that ladder bars are superior. You really think any of these leaf spring guys wouldn't jump ship and weld in ladder bars if their class allowed it?
CHIP
'06 GMC 2500HD LBZ Duramax
Re: CalTrac or Ladder bars ?? Post your 60' and info [Re: an8sec70cuda] #2834841
10/20/20 01:15 AM
10/20/20 01:15 AM
Red Deer, Alberta
Greenwood Offline
Greenwood  Offline
Red Deer, Alberta
My best 1/4 mile ET was 11.28 @ 119.6 on a 1.59 60 ft. My best 60 ft. is 1.52 on a 7.41 in the 1/8th. I run a 4-link with leafs.
Re: CalTrac or Ladder bars ?? Post your 60' and info [Re: an8sec70cuda] #2834863
10/20/20 06:05 AM
10/20/20 06:05 AM
Ct
W
Wirenut Offline
Wirenut  Offline
W
Ct
Very good points.
I keep hearing about classes that don’t allow ladder bar? I’m assuming these are stock classes that I probably wouldn’t run anyway?
I have only tried bracket racing in pro and some Gamblers races
Thanks for insight
Re: CalTrac or Ladder bars ?? Post your 60' and info [Re: Wirenut] #2834874
10/20/20 07:14 AM
10/20/20 07:14 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
With my Caltrac's its been the front suspension changes that helped the most. I have a best of 1.33 so far, but its still spinning and crushes the tire. My goal this year is to switch to a drag radial, gawd I can't believe I just said that, and maybe see if I can jam a set of double adjustable Vikings on the rear......The shorter height and stiffer side wall should allow it to get down the track quicker, if it hooks....
Re: CalTrac or Ladder bars ?? Post your 60' and info [Re: an8sec70cuda] #2834879
10/20/20 07:48 AM
10/20/20 07:48 AM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
Couldn't agree more. For bracket racing where consistency is key its hard to beat a ladder bar suspension esp when the track prep may not always be top notch. My car used to be superstock springs, and than we backhalved it with ladder bar, night and day difference. More consistent and smoother driving. My car is a turd compared to most guys with only 1.46 60ft (3150 lbs runs mid/high 10s) does have a 30x13 slick, but the 60ft is deadly consistent. I do think Cal-Tracs are great if you have car that you just want bolt ons and don't want to modify alot. They will work with the right shocks and if you know how to set them up, but for the basic bracket racer ladder bars is the easy choice.
Re: CalTrac or Ladder bars ?? Post your 60' and info [Re: Wirenut] #2834882
10/20/20 07:53 AM
10/20/20 07:53 AM
Very good points.
Thanks for insight
These are specific stock suspension classes...usually of the "street car" or radial tire variety.
CHIP
