Re: Jeep GC front axle turned it's self into a locker.
[Re: 74RALLYE]
#2832319
10/13/20 02:13 PM
10/13/20 02:13 PM
Posts: 32,977 Grand Prairie,Texas
stumpy
Grand Prairie,Texas
You most likely will get away with rebuilding the one you have. Dr diff could give you a better answer.
[Re: NITROUSN]
#2832392
10/13/20 05:33 PM
10/13/20 05:33 PM
Posts: 8,035 Tulsa OK
Bad340fish
Tulsa OK
What transfer case? My bets the viscous coupler is bad. This
68 Barracuda Formula S 340
[Re: Bad340fish]
#2832415
10/13/20 06:36 PM
10/13/20 06:36 PM
Posts: 1,643 A certified culture free zone.
74RALLYE
I don't know which transfer case it has other than stock. I get it, like leaving my manual trans truck in 4WD on pavement. How would I test it's coupling?
[Re: 74RALLYE]
#2832731
10/14/20 02:11 PM
10/14/20 02:11 PM
74RALLYE
Here's a pic of the tag. It's a 249 case. I just noticed some yellow paint in the corner of the pic. Might be a junk yard swap from the previous owner. How can I test the viscous coupling? It looks like a $500 part so swapping the whole thing will be cheaper if that's the problem.
[Re: 74RALLYE]
#2832770
10/14/20 04:24 PM
10/14/20 04:24 PM
Posts: 18,426 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
There is no real test that I am aware of that conclusively pinpoints it to the viscous coupler. For the most part it is the symptoms. The hotter it gets the worse it gets. Binding on turns especially if you drive in figure 8's at a parking lot. The tires will bind and chirp. Depending on miles a used one may not be much better. For sure these type transfer cases need 4 tires identical in make and size.
[Re: Pacnorthcuda]
#2833024
10/15/20 01:16 PM
10/15/20 01:16 PM
Posts: 19,591 north of coder
moparx
We need Scott Smith to ID that cocoon thing. kinda looks like a mud wasp nest.
[Re: moparx]
#2833320
10/16/20 09:31 AM
10/16/20 09:31 AM
Bad340fish
Tulsa OK
You can pull the front shaft, if that fixes the problem then you can count on it being the t-case.
I don't think its good for them but they can be driven without the front shaft. I know when I used to follow the jeep stuff closer the 5.9L grand Cherokee guys would do this so they could do burnouts lol.
