Re: A727TF Kickdown, Part 2 [Re: moparjack44] #2841213
11/03/20 12:05 PM
11/03/20 12:05 PM
None
71rm23 Offline
71rm23  Offline
None
I think I got my pictures to resize right. Anyway, this is my set up
Re: A727TF Kickdown, Part 2 [Re: 71rm23] #2843929
11/09/20 11:27 AM
11/09/20 11:27 AM
Halifax, VA.
moparjack44 Offline OP
Halifax, VA.
Thank You 71rm23. Good clear picture, I am sure I can use. My kit came with the "special carb bracket" they say I need. I see that same bracket on you set up.
Well keep you posted. Again, Thanks.
Jack
K.I.S.S.
Re: A727TF Kickdown, Part 2 [Re: 71rm23] #2843933
11/09/20 11:32 AM
11/09/20 11:32 AM
Halifax, VA.
Halifax, VA.
71rm23, I am a little confused about your return spring set up? Is that because you are using Quick Fuel carb? Springs also look strong??
Jack
K.I.S.S.
Re: A727TF Kickdown, Part 2 [Re: moparjack44] #2845152
11/11/20 11:40 PM
11/11/20 11:40 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
Hmm...everyone it seems beats up on the Lokar (or the knock-off) setups, yet I cannot for the life of me understand why?
It has a practially never-ending ability to be adjusted to how you need it in order to mesh-up to your particular setup/configuration.
Here are a couple of pics of my setup: yes the 9800 TQ is the aftermarket one, so the throttle hookup did NOT require me to run the Mopar adapter (but if you need that, well, oh boy, there is about a $10 part that does that for you), and the transmission level needed a bit of an adjustment (measured the stock center-to-center lengths and replicated with some additional provisions for adjusting it my way).
Anyways, the Buchillon setup is certainly ore stock-appearing, but it uses the very same principle the Lokar stuff does. There is no denying it is well thought out and gives you the additional adjustability that the Lokar kit as-supplied brackets do not...however, it's really just a different shape of the same animal...so what am I missing here? Sorry, I never understood this whole difficulty.
Re: A727TF Kickdown, Part 2 [Re: Diplomat360] #2845244
11/12/20 11:15 AM
11/12/20 11:15 AM
Houston, Texas
racerx20 Offline
Standard but OK
racerx20  Offline
Standard but OK
Houston, Texas
I agree, I used both setups on my 408 Dart. I preferred the Lokar setup and it performed better for me.
1972 Road Runner
1988 Shelby CSX-T
Re: A727TF Kickdown, Part 2 [Re: Diplomat360] #2845317
11/12/20 01:29 PM
11/12/20 01:29 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Because the Lokar instructions only work correctly with a certain combo of carb/trans lever. In many combos the trans shifts late at light throttle or not at all at WOT. Yes, lots of people are satisfied with the Lokar because they matched the components correctly or, even if they didn't, the final result is fine with them.
Quote
Anyways, the Buchillon setup is certainly more stock-appearing, but it uses the very same principle the Lokar stuff does.
Yes the same principle but not the same function. The Bouchillon matches the components for precise operation and the components are more stout.
Re: A727TF Kickdown, Part 2 [Re: moparjack44] #2845645
11/13/20 10:05 AM
11/13/20 10:05 AM
None
71rm23 Offline
71rm23  Offline
None
Jack
If my memory is correct, I think yes to both of your questions. It looks strong but I don't notice it much, if any, compared to others. The bracketry that comes with it works with it all and no issues
