Re: Rear Driveshaft Loop
[Re: LimeliteAero]
#283174
04/10/09 01:08 AM
04/10/09 01:08 AM
Posts: 3,106 Ridgeland Wi
mopars_1
Ridgeland Wi
id go in the typical spot in the front becuas thats where you the driver is, and if by some chance it goes threw the floor, it wont take your leg off either
1971 Plymouth Duster 340 auto 1937 Plymouth PT50 1969 Dodge Dart Swinger 340 4 speed 2013 Ram laramie 2500 hemi 2008 Harley FLSTSB springer
[Re: moparonly]
#283180
04/10/09 02:07 AM
04/10/09 02:07 AM
Posts: 4,247 Newfoundland
codfish
Newfoundland
Front loop is to protect driver. I doubt a driveshaft is strong enough to catapult a vehicle. It would bend like a pretzel first.
codfish
[Re: moparonly]
#283181
04/10/09 08:33 AM
04/10/09 08:33 AM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
Myth Busters did a show with the pole vaulting drive shaft.They used a Fury.It didnt happen no matter what they tried.Not saying it cant happen but they tried a lot of different scenarios.My front is bolted to the trans.Yeah the shaft makes a ton of noise when the rear breaks.My loop helps hold the shaft up if the rear brakes.Rocky
Chrysler Firepower
[Re: moparonly]
#283183
04/10/09 08:48 AM
04/10/09 08:48 AM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
Forward located loops are the most important ones, but a guy wouldn't have to place a second loop very far back from the mid-point of the shaft to restrain the rear end of the driveshaft should a rear joint let go. If you mount anything on the rear end, it is going to move up and down when you accelerate and decelerate, so be sure you have clearance. It's also going to add to the unsprung weight.
Sometimes all kinds of nasty things can and do happen when u-joints let go, including the mythically rare instance of pole vaulting the car/truck, breaking the output shaft of the trans/transfer case, and beating the hell out of anything in the way on the bottom of the vehicle. Driveshafts are strong enough to partially lift and redirect the rear of the car suddenly potentially causing a loss of control or worse, rip through the floor and cause general mayhem.
Loops are good insurance, but so is using appropriately rated driveshafts, u-joints and properly set-up driveline angles.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#283184
04/10/09 10:01 AM
04/10/09 10:01 AM
it will very rarely launch your car in the air but the rear end and the frame will be ruined
[Re: Dart 340]
#283188
04/10/09 11:31 AM
04/10/09 11:31 AM
or you could put your engine in the rear of the car and run it like a front wheel drive with no driveshafts sticking out. probably would wheelie like hell and get some pretty good grip
