Poly-Loc motor mounts #2829424
10/06/20 05:42 PM
10/06/20 05:42 PM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
Where to get them? Would like to go to them and ditch my solid mounts, but can't find them.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: Poly-Loc motor mounts [Re: 68LAR] #2829473
10/06/20 06:52 PM
10/06/20 06:52 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Schumaker did them . I had a set for years , ultimatelly they melted/collapsed
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Poly-Loc motor mounts [Re: tex013] #2829506
10/06/20 07:49 PM
10/06/20 07:49 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Tex
That's what they do. They couldn't take the heat from headers.
I believe Schumacher is all done too.
Kevin
Re: Poly-Loc motor mounts [Re: Twostick] #2829529
10/06/20 08:32 PM
10/06/20 08:32 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
there is a mount with bolt through the centre . I have those style now plus a solid mount torque strap
Tex
New best MPH 130.32
Re: Poly-Loc motor mounts [Re: 68LAR] #2829531
10/06/20 08:35 PM
10/06/20 08:35 PM
Santa Rosa, Calif
angleiron2 Offline
angleiron2  Offline
Santa Rosa, Calif
I just recently purchased a set of Myte Mounts from Dynatech Engineering. They look pretty good, I haven’t installed them yet.
Re: Poly-Loc motor mounts [Re: angleiron2] #2829623
10/07/20 04:37 AM
10/07/20 04:37 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Those are what i bought
Tex
New best MPH 130.32
Re: Poly-Loc motor mounts [Re: angleiron2] #2829633
10/07/20 07:33 AM
10/07/20 07:33 AM
San Jose,CA
migsBIG Offline
YouTube is my go-to news source
migsBIG  Offline
San Jose,CA
Re: Poly-Loc motor mounts [Re: migsBIG] #2829657
10/07/20 09:10 AM
10/07/20 09:10 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
mount
Member farmboy whittled these out for me out of aluminum. I only used the drivers side.
'63 Dodge 330
11.19 @ 121 mph
Re: Poly-Loc motor mounts [Re: GY3] #2831433
10/11/20 09:19 AM
10/11/20 09:19 AM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
I use the Schumacher poly mounts on my 62. Purchased back in 2007 or 8 but not much run time since then, and also havnt raced it yet.
So far they’re holding up smile . I use their torque strap as well.
2 kids and a dog
Re: Poly-Loc motor mounts [Re: TonyS451] #2831437
10/11/20 09:33 AM
10/11/20 09:33 AM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
I purchased the Mity Mounts. The disclaimer says life time warranty but not for racing applications. I'm going to give them a try at this point. Driver side is the only side with the the countersunk screws. Passenger side looks pretty much like a stock mount.
Re: Poly-Loc motor mounts [Re: 68LAR] #2831479
10/11/20 11:36 AM
10/11/20 11:36 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I tried the poly mounts on my A-Body and found they transmitted too much vibration into the car and were very stiff. I swapped them out for a set of stock rubber mounts and the Schumaker torque strut. The vibration was gone and I have not had any issues since.
I have Mity Mounts on my Shaker hood E-Body, so the Shaker can do it's thing. After a few years of use, I found the driver's side mount had nearly pulled the cap stud through the plate of the mount. I replaced it with another Mity Mount and installed a short length of chain to keep the engine from lifting up too far any more. THere is a lot of strain on the driver's side motor mounts in high hp/torque applications especially with drag radials.
I learned that it's a good idea to combine a strut, strap or chain to help limit overall lift of the motor on acceleration especially when you have high torque and horsepower.
