Poly-Loc motor mounts
#2829424
10/06/20 05:42 PM
10/06/20 05:42 PM
Posts: 4,006 South Park, Pa.
68LAR
South Park, Pa.
Where to get them? Would like to go to them and ditch my solid mounts, but can't find them.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: Poly-Loc motor mounts
[Re: 68LAR]
#2829473
10/06/20 06:52 PM
10/06/20 06:52 PM
Posts: 2,457 Sydney,Australia
tex013
Sydney,Australia
Schumaker did them . I had a set for years , ultimatelly they melted/collapsed
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#2829506
10/06/20 07:49 PM
10/06/20 07:49 PM
Posts: 6,558 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Tex That's what they do. They couldn't take the heat from headers. I believe Schumacher is all done too. Kevin
[Re: Twostick]
#2829529
10/06/20 08:32 PM
10/06/20 08:32 PM
tex013
Sydney,Australia
there is a mount with bolt through the centre . I have those style now plus a solid mount torque strap
Tex
[Re: 68LAR]
#2829531
10/06/20 08:35 PM
10/06/20 08:35 PM
Posts: 25 Santa Rosa, Calif
angleiron2
Santa Rosa, Calif
I just recently purchased a set of Myte Mounts from Dynatech Engineering. They look pretty good, I haven’t installed them yet.
[Re: angleiron2]
#2829623
10/07/20 04:37 AM
10/07/20 04:37 AM
tex013
Sydney,Australia
I just recently purchased a set of Myte Mounts from Dynatech Engineering. They look pretty good, I haven’t installed them yet. Those are what i bought Tex
[Re: migsBIG]
#2829657
10/07/20 09:10 AM
10/07/20 09:10 AM
Posts: 4,663 Wichita
GY3
Wichita
mountMember farmboy whittled these out for me out of aluminum. I only used the drivers side.
[Re: GY3]
#2831433
10/11/20 09:19 AM
10/11/20 09:19 AM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
I use the Schumacher poly mounts on my 62. Purchased back in 2007 or 8 but not much run time since then, and also havnt raced it yet. So far they’re holding up . I use their torque strap as well.
2 kids and a dog
[Re: TonyS451]
#2831437
10/11/20 09:33 AM
10/11/20 09:33 AM
68LAR
South Park, Pa.
I purchased the Mity Mounts. The disclaimer says life time warranty but not for racing applications. I'm going to give them a try at this point. Driver side is the only side with the the countersunk screws. Passenger side looks pretty much like a stock mount.
[Re: 68LAR]
#2831479
10/11/20 11:36 AM
10/11/20 11:36 AM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
I tried the poly mounts on my A-Body and found they transmitted too much vibration into the car and were very stiff. I swapped them out for a set of stock rubber mounts and the Schumaker torque strut. The vibration was gone and I have not had any issues since.
I have Mity Mounts on my Shaker hood E-Body, so the Shaker can do it's thing. After a few years of use, I found the driver's side mount had nearly pulled the cap stud through the plate of the mount. I replaced it with another Mity Mount and installed a short length of chain to keep the engine from lifting up too far any more. THere is a lot of strain on the driver's side motor mounts in high hp/torque applications especially with drag radials.
I learned that it's a good idea to combine a strut, strap or chain to help limit overall lift of the motor on acceleration especially when you have high torque and horsepower.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
