Page 3 of 3 1 2 3
Re: A727TF kickdown adjustment [Re: John_Kunkel] #2830587
10/08/20 10:16 PM
10/08/20 10:16 PM
SW CO
HemiSportFury Offline
SW CO
And if you haven't matched the throw at the carb to the travel at the trans you will still have the problem you started with.
'64 Sport Fury, 528 Hemi, FiTech EFI, 4-speed, 4.10 Dana 60
'57 Belvedere 2dr sedan, current project in process
'19 Cherokee Trail Hawk Elite
'03 Ram 2500 CTD HO, 6-speed 214,000 miles and still going strong
Re: A727TF kickdown adjustment [Re: HemiSportFury] #2830774
10/09/20 12:44 PM
10/09/20 12:44 PM
moparx Offline
moparx  Offline
OP, pictures of your transmission hook up would help, as others have said.
beer
Re: A727TF kickdown adjustment [Re: moparx] #2831057
10/10/20 09:48 AM
10/10/20 09:48 AM
Halifax, VA.
moparjack44 Offline OP
Halifax, VA.
beer
Will try to post some pictures, I hope today? I am not good at posting pictures. Kinda computer challenged frown
Speaking of pictures, would someone post a picture using the Buchillon kit?
K.I.S.S.
Re: A727TF kickdown adjustment [Re: John_Kunkel] #2831058
10/10/20 09:55 AM
10/10/20 09:55 AM
Halifax, VA.
Halifax, VA.
Originally Posted by John_Kunkel
The gear it's has no bearing on the TP linkage operation. If flooring the throttle moves the trans lever forward, the linkage is hooked up to the wrong side of the throttle lever. Time for some pics.
Took me a while, but I figured that out. Lever know goes in right direction. On test drive, still would not kickdown (didn't think it would, lever moved in correct direction, but far from full back). Also on test drive, shift points worse. (1-2, 8mph, 2-3 15mph, and slipping.)
K.I.S.S.
Re: A727TF kickdown adjustment [Re: moparjack44] #2831076
10/10/20 10:55 AM
10/10/20 10:55 AM
SW CO
SW CO
Therein is your problem. Until you correct this your tranny is not going to function correctly. Driving it just increases your chances of damaging it. Hopefully you haven't already. Change the mounting point on the carb to a position further away from the shaft (more movement) or move the attaching point on the trans to a position closer to the shaft (less movement) or a combination of both.
Re: A727TF kickdown adjustment [Re: moparjack44] #2831146
10/10/20 01:37 PM
10/10/20 01:37 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
For light throttle, those speeds aren't far off factory spec but is the slipping during the shift or after the shift is completed?
Re: A727TF kickdown adjustment [Re: John_Kunkel] #2831156
10/10/20 02:17 PM
10/10/20 02:17 PM
Halifax, VA.
Halifax, VA.
During.
K.I.S.S.
Re: A727TF kickdown adjustment [Re: moparjack44] #2831168
10/10/20 02:59 PM
10/10/20 02:59 PM
Halifax, VA.
Halifax, VA.
beer
OK.Got some pictures, need instructions how to post. My camera skills no better than my computer skills
K.I.S.S.
Re: A727TF kickdown adjustment [Re: moparjack44] #2831817
10/12/20 09:19 AM
10/12/20 09:19 AM
Halifax, VA.
Halifax, VA.
beer
Pictures on my Andriod cell phone. I have been able to email my pictures, but unable to find instructions on sending to this site? I checked the Help page, but didn't help.
K.I.S.S.
Re: A727TF kickdown adjustment [Re: moparjack44] #2831860
10/12/20 11:48 AM
10/12/20 11:48 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Re: A727TF kickdown adjustment [Re: stumpy] #2832226
10/13/20 09:37 AM
10/13/20 09:37 AM
Halifax, VA.
Halifax, VA.
I see changing your page appearance?, staying logged in?, no reference to posting a picture?
K.I.S.S.
Re: A727TF kickdown adjustment [Re: moparjack44] #2832264
10/13/20 12:04 PM
10/13/20 12:04 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Look at the big grey boxes. The instructions are very clearly there. "To add pictures to a post, you can now ad 2 per post, the limit in the parts ads. They need to be smaller than 2megs in size.
Click on File Manager, Load from you hard drive, Will show in your post".
Re: A727TF kickdown adjustment [Re: moparjack44] #2832323
10/13/20 02:27 PM
10/13/20 02:27 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Here's what the reply page looks like (on my computer), click at the red arrow to get the next box.
Page 3 of 3 1 2 3
