2nd Gen Hemi mounts #2830345
10/08/20 12:37 PM
10/08/20 12:37 PM
MB,CAN
PC-CHARGER Offline OP
MB,CAN
Does anyone have a drawing showing the location of the engine mount holes on a 2nd Gen Hemi.The ones I need are the three bolt holes that hold the mount bracket to the side of the engine.
Re: 2nd Gen Hemi mounts [Re: PC-CHARGER] #2830704
10/09/20 11:10 AM
10/09/20 11:10 AM
Arizona
410mopar Offline
410mopar  Offline
Arizona
Do you want a real official drawing, or can I just measure my 65 brackets and give you the measurement?
Re: 2nd Gen Hemi mounts [Re: 410mopar] #2831021
10/10/20 07:52 AM
10/10/20 07:52 AM
VA
dragon slayer Offline
VA
I am confused. Your talking 426 hemi correct? Left and Right brackets are different, B and E are different. Also some changes over the years. Yes the block studs are the same and if that is the pattern you need, you can pull it from a block,
Re: 2nd Gen Hemi mounts [Re: dragon slayer] #2831025
10/10/20 08:02 AM
10/10/20 08:02 AM
USA
Suregrip391 Offline
Suregrip391  Offline
USA
He probably has one of those earlier blocks with the 440 mounts and needs to drill and tap for original Hemi mounts on the pad because they were not done when the block was machined. I had one of those once.
Re: 2nd Gen Hemi mounts [Re: dragon slayer] #2831026
10/10/20 08:03 AM
10/10/20 08:03 AM
A727Tflite Offline
A727Tflite  Offline
Brackets also differ between the 64-65 and the 66-71.
Re: 2nd Gen Hemi mounts [Re: A727Tflite] #2831148
10/10/20 01:43 PM
10/10/20 01:43 PM
Arizona
410mopar Offline
410mopar  Offline
Arizona
PC-Charger
Please clarify. What exactly do you want? I'm willing to help.
Re: 2nd Gen Hemi mounts [Re: 410mopar] #2832056
10/12/20 07:52 PM
10/12/20 07:52 PM
Stuttgart, Arkansas
rickseeman Online content
rickseeman  Online Content
Stuttgart, Arkansas
The diagram is in the Mopar engine manual
2011 Drag Pak Challenger
Re: 2nd Gen Hemi mounts [Re: A727Tflite] #2832107
10/12/20 09:26 PM
10/12/20 09:26 PM
iagree
Street hemi versus race steel block hemi mounts also shruggy
