What do you guys that race regularly consider a good light?
#2830078
10/07/20 06:46 PM
10/07/20 06:46 PM
Posts: 4,684 Wichita
GY3
Wichita
Talking about a Sportsman tree here.
Where do you consistently try to be?
I played with the online one quite a bit over the last few months and if I try to get my average below .06 in 10 tries I start going red.
Interestingly enough, .06 was about where I averaged this weekend racing with a couple of reds.
Re: What do you guys that race regularly consider a good light?
[Re: GY3]
#2830081
10/07/20 07:00 PM
10/07/20 07:00 PM
Posts: 12,396 Taxes & Virus's R-US, NY
Dragula
Anything with a zero or 1 next to the 5......
[Re: GY3]
#2830086
10/07/20 07:11 PM
10/07/20 07:11 PM
Posts: 2,049 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
You say sportsman tree, I'm assuming that is a full tree? If I am .020 or better, I'm happy. But, I've won a lot of rounds being .060 on the tree, -.001 red, not so many. I think that you are on the right path though. You MUST be consistant (what ever it is, .05, .06, .09 whatever), before you can work on being better. And just because you average a .020 or better, doesn't mean you going to win. At Bristol one weekend this season (sat & Sun), the worst light I had was a .040 (had two of them, both in time trials, and .039 in elim), had a bunch of .01X and a couple of .00X to boot. All I had to show for it Sunday on afternoon was a empty fuel jug. Also, a few years ago, I won a Super Pro race, with my best light was a.03x, and that was in the finals. I got away with a .05 & a .07, when the dragsters beside me had .07 & .09 respectively. But the car was dead on my dial in with a .004 or .002 six of the seven rounds that day. Got lucky!
Brian
[Re: '72CudaRacer]
#2830089
10/07/20 07:24 PM
10/07/20 07:24 PM
Posts: 2,465 Sydney,Australia
tex013
Sydney,Australia
Brian Im with this BUT it will also be whether a .400 or .500 tree . Now it seems most of you guys run a .500 tree . We run .400 full tree , occassionaly .400 pro tree DYO for fun . If i can keep under 0.040 i am happy if 0.030 or under its great . I run bottom bulb no box and that also changes stuff up . And knowing your car can help a soft light , holding/consistant . Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: GY3]
#2830146
10/07/20 09:10 PM
10/07/20 09:10 PM
Guitar Jones
A good light? .01X or better. A great light? .000X. However none of those will guarantee a win if the car is off the dial. I've lost with a .004 light and .006 off the dial. I've also won with a .168 light and shut the car off at 1000'. You have to be able to race the finish line as well as the starting line. Most times the finish line is more important than the starting line. I kept meticulous records on engine temp, oil pressure and weather and was usually able to dial my car to within .006. Of course that didn't happen overnight either. I also prefer to be the faster car as you have the whole race in front of you so I built my cars to run at the bottom of the class and slow it down if necessary.
[Re: Dragula]
#2830176
10/07/20 10:44 PM
10/07/20 10:44 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
anything better then the guy in the next lane........
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 70AARcuda]
#2830178
10/07/20 11:05 PM
10/07/20 11:05 PM
Posts: 20,185 Park Forest, IL
slantzilla
Park Forest, IL
I ran a buddy of mine earlier this year. I was .026 and was dead late. He went .006. No box.
[Re: 70AARcuda]
#2830179
10/07/20 11:17 PM
10/07/20 11:17 PM
Posts: 11,718 Portage,michigan
B3422W5
Portage,michigan
anything better then the guy in the next lane........ Thats it in a nutshell. I got beat last year going trip zip on the tree on a points night at US131 Brokeout by 2 thou racing a very fast bike I wasnt going to lift against. He was 012 Got a 9 thou package put on me one night this year. It happens But i have had 5-6 round nights footbraking against nobox points guys with brakes and had only a couple lights 20 or better and gotten a paycheck. Big thing is... you have to be green, and have a car that runs the number that you trust.. If you can do that, it forces the guy In the other lane to make decisions at the finish line. Sometimes they make bad decisions.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: 70AARcuda]
#2830180
10/07/20 11:25 PM
10/07/20 11:25 PM
Posts: 2,513 PA
moparacer
PA
Best light for me is always the win light.... I have always tried to set up for a .010 bulb no matter if I am footbraking or button racing. The button racing I am starting to put myself in the mid .00 range lately. You start giving the guy in the other lane too much, and they are good at driving the stripe, they will eat you alive.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: moparacer]
#2830190
10/08/20 12:03 AM
10/08/20 12:03 AM
Posts: 11,611 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Depends. You won't win a race with .020 lights all day in a dot 90 class. Or a serious bracket race. Maybe a few early rounds.
Maybe some of the other classes I won't name so I don't get accused of talking bad about them.
Practice to be consistent. Get a practice tree. Set it up to use it while in your car with the switches you will use. Or a foot switch if foot braking. Look the same place every time. Try different things. If you can stay within .015 - .020, range, then you can adjust the car to you.
[Re: CMcAllister]
#2830219
10/08/20 07:55 AM
10/08/20 07:55 AM
Posts: 10,032 MN
JERICOGTX
MN
A win light never has to be pretty, it just has to turn on.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2830229
10/08/20 08:46 AM
10/08/20 08:46 AM
Posts: 4,987 new jersey usa
11secdart
new jersey usa
I run .500 full tree bracket racing and .500 pro tree index racing, I really like the pro tree, I would say 020 or better on either … foot braking. I've lost with better and Won with worse.
[Re: JERICOGTX]
#2830232
10/08/20 08:52 AM
10/08/20 08:52 AM
GY3
Wichita
A win light never has to be pretty, it just has to turn on. Quote of the year right there!
[Re: bonefish]
#2830298
10/08/20 11:01 AM
10/08/20 11:01 AM
Posts: 474 Alberta, Canada
451Guy
Alberta, Canada
I mainly delay box race. I try to set up for a .007 - .009. Hopefully if I miss it I am better than .020 and if I am pumped up and crush it I am low .00. However my plan does occasionally not work out exactly as hoped!!!!!! LOL
Thanx 451 Guy
512 cu in 71 Demon Super Street Car - NO LONGER - Broke Crank Best ET 9.57 @ 139.96
451 cu in Pump Gas - 71 Demon Super Street Car Best ET 9.99 @ 136.80
512 cu in 69 Charger R/T Best ET 11.39 @ 118.11
