What do you guys that race regularly consider a good light? #2830078
10/07/20 06:46 PM
10/07/20 06:46 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
Talking about a Sportsman tree here.
Where do you consistently try to be?
I played with the online one quite a bit over the last few months and if I try to get my average below .06 in 10 tries I start going red.
Interestingly enough, .06 was about where I averaged this weekend racing with a couple of reds.
'63 Dodge 330
11.19 @ 121 mph
Re: What do you guys that race regularly consider a good light? [Re: GY3] #2830081
10/07/20 07:00 PM
10/07/20 07:00 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Anything with a zero or 1 next to the 5......
Re: What do you guys that race regularly consider a good light? [Re: GY3] #2830085
10/07/20 07:09 PM
10/07/20 07:09 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
.020 or better off the bottom bulb.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: What do you guys that race regularly consider a good light? [Re: GY3] #2830086
10/07/20 07:11 PM
10/07/20 07:11 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
You say sportsman tree, I'm assuming that is a full tree? If I am .020 or better, I'm happy. But, I've won a lot of rounds being .060 on the tree, -.001 red, not so many.
I think that you are on the right path though. You MUST be consistant (what ever it is, .05, .06, .09 whatever), before you can work on being better.
And just because you average a .020 or better, doesn't mean you going to win. At Bristol one weekend this season (sat & Sun), the worst light I had was a .040 (had two of them, both in time trials, and .039 in elim), had a bunch of .01X and a couple of .00X to boot. All I had to show for it Sunday on afternoon was a empty fuel jug. Also, a few years ago, I won a Super Pro race, with my best light was a.03x, and that was in the finals. I got away with a .05 & a .07, when the dragsters beside me had .07 & .09 respectively. But the car was dead on my dial in with a .004 or .002 six of the seven rounds that day. Got lucky!
Brian
Re: What do you guys that race regularly consider a good light? [Re: '72CudaRacer] #2830089
10/07/20 07:24 PM
10/07/20 07:24 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Brian
Im with this BUT it will also be whether a .400 or .500 tree . Now it seems most of you guys run a .500 tree . We run .400 full tree , occassionaly .400 pro tree DYO for fun . If i can keep under 0.040 i am happy if 0.030 or under its great . I run bottom bulb no box and that also changes stuff up . And knowing your car can help a soft light , holding/consistant .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: What do you guys that race regularly consider a good light? [Re: tex013] #2830134
10/07/20 08:37 PM
10/07/20 08:37 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
.02x will usually get you to the next round if the car is close. But not every time. Stay in that area and you will find the winners circle more often than most.
Doug
Re: What do you guys that race regularly consider a good light? [Re: GY3] #2830146
10/07/20 09:10 PM
10/07/20 09:10 PM
Guitar Jones Offline
A good light? .01X or better. A great light? .000X. However none of those will guarantee a win if the car is off the dial. I've lost with a .004 light and .006 off the dial. I've also won with a .168 light and shut the car off at 1000'. You have to be able to race the finish line as well as the starting line. Most times the finish line is more important than the starting line. I kept meticulous records on engine temp, oil pressure and weather and was usually able to dial my car to within .006. Of course that didn't happen overnight either. I also prefer to be the faster car as you have the whole race in front of you so I built my cars to run at the bottom of the class and slow it down if necessary.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: What do you guys that race regularly consider a good light? [Re: Guitar Jones] #2830161
10/07/20 10:02 PM
10/07/20 10:02 PM
gregsdart Offline
gregsdart  Offline
For "box" racing .010 or better. Footbrake, .020 or better. BUT some of the hotshots are cosistantly better by a bunch!
Re: What do you guys that race regularly consider a good light? [Re: gregsdart] #2830164
10/07/20 10:07 PM
10/07/20 10:07 PM
Dragula Offline
Dragula  Offline
The box class by me is brutal. If you are not cutting '0' lights, you are done......I am a foot braker, and when my brakes would not hold for the last race at Lancaster, I switched to the T-brake. I think I am more consistent off the T-brake than the foot brake. My reaction times were over all better.
Re: What do you guys that race regularly consider a good light? [Re: Dragula] #2830176
10/07/20 10:44 PM
10/07/20 10:44 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
anything better then the guy in the next lane........
Tony
70 AARCuda Vitamin C
Re: What do you guys that race regularly consider a good light? [Re: 70AARcuda] #2830178
10/07/20 11:05 PM
10/07/20 11:05 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I ran a buddy of mine earlier this year. I was .026 and was dead late. He went .006. No box.
Re: What do you guys that race regularly consider a good light? [Re: 70AARcuda] #2830179
10/07/20 11:17 PM
10/07/20 11:17 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Thats it in a nutshell. I got beat last year going trip zip on the tree on a points night at US131
Brokeout by 2 thou racing a very fast bike I wasnt going to lift against. He was 012
Got a 9 thou package put on me one night this year. It happens
But i have had 5-6 round nights footbraking against nobox points guys with brakes and had only a couple lights 20 or better and gotten a paycheck.
Big thing is... you have to be green, and have a car that runs the number that you trust.. If you can do that, it forces the guy In the other lane to make decisions at the finish line. Sometimes they make bad decisions.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: What do you guys that race regularly consider a good light? [Re: 70AARcuda] #2830180
10/07/20 11:25 PM
10/07/20 11:25 PM
PA
moparacer Offline
moparacer  Offline
PA
Best light for me is always the win light.... beer
I have always tried to set up for a .010 bulb no matter if I am footbraking or button racing. The button racing I am starting to put myself in the mid .00 range lately. You start giving the guy in the other lane too much, and they are good at driving the stripe, they will eat you alive.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: What do you guys that race regularly consider a good light? [Re: moparacer] #2830190
10/08/20 12:03 AM
10/08/20 12:03 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Depends. You won't win a race with .020 lights all day in a dot 90 class. Or a serious bracket race. Maybe a few early rounds.
Maybe some of the other classes I won't name so I don't get accused of talking bad about them.
Practice to be consistent. Get a practice tree. Set it up to use it while in your car with the switches you will use. Or a foot switch if foot braking. Look the same place every time. Try different things. If you can stay within .015 - .020, range, then you can adjust the car to you.
Re: What do you guys that race regularly consider a good light? [Re: CMcAllister] #2830219
10/08/20 07:55 AM
10/08/20 07:55 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
A win light never has to be pretty, it just has to turn on.
69 GTX 68 Road Runner
Re: What do you guys that race regularly consider a good light? [Re: JERICOGTX] #2830229
10/08/20 08:46 AM
10/08/20 08:46 AM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
I run .500 full tree bracket racing and .500 pro tree index racing, I really like the pro tree, I would say 020 or better on either … foot braking. I've lost with better and Won with worse.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: What do you guys that race regularly consider a good light? [Re: JERICOGTX] #2830232
10/08/20 08:52 AM
10/08/20 08:52 AM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
Quote of the year right there!
'63 Dodge 330
11.19 @ 121 mph
Re: What do you guys that race regularly consider a good light? [Re: GY3] #2830252
10/08/20 09:53 AM
10/08/20 09:53 AM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Go to YouTube, and watch the live stream from the Memphis million. Lots of everything.
Re: What do you guys that race regularly consider a good light? [Re: Leigh] #2830274
10/08/20 10:34 AM
10/08/20 10:34 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
im happy when its not red. drive
Re: What do you guys that race regularly consider a good light? [Re: bonefish] #2830298
10/08/20 11:01 AM
10/08/20 11:01 AM
Alberta, Canada
451Guy Offline
451Guy  Offline
Alberta, Canada
I mainly delay box race. I try to set up for a .007 - .009. Hopefully if I miss it I am better than .020 and if I am pumped up and crush it I am low .00. However my plan does occasionally not work out exactly as hoped!!!!!! LOL
Thanx 451 Guy
512 cu in 71 Demon Super Street Car - NO LONGER - Broke Crank
Best ET 9.57 @ 139.96
451 cu in Pump Gas - 71 Demon Super Street Car
Best ET 9.99 @ 136.80
512 cu in 69 Charger R/T
Best ET 11.39 @ 118.11
