Re: Tool steel lifters
[Re: cudaman1969]
#2830441
10/08/20 03:39 PM
10/08/20 03:39 PM
Posts: 693 Dunnellon, FL
longram60
Dunnellon, FL
Simple question, Can they be used on a regular cam and both live? I use them (PPP brand) on my AMC stock eliminator car with no problems. Has a Bullet racing cam. My spring pressures are not very high. About 60 runs on them.
1979 AMC Spirit, NHRA Q/SA
[Re: cudaman1969]
#2830442
10/08/20 03:39 PM
10/08/20 03:39 PM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
Simple question, Can they be used on a regular cam and both live? The non coated ones are for a regular cast iron cam, will they live ??? they did not live for me,.
[Re: cudaman1969]
#2830456
10/08/20 04:12 PM
10/08/20 04:12 PM
Posts: 287 PA
Harry's Taxi 2
PA
Simple question, Can they be used on a regular cam and both live? Yes they can. I have one set that I am currently using on the fifth different cam in two different engines......and still going currently @ 170# seat and 400# open. I do have bushed lifter bores.....I think one thing that gets people in trouble with current .904 lobes (and corresponding rates of lift) is not correcting lifter bore locations. In the old days of .842 and maybe a .875 lobe, one could get away with a slightly off lifter bore location combined with the lower spring pressures required with a slower rate of lift.
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
[Re: moparx]
#2830470
10/08/20 04:48 PM
10/08/20 04:48 PM
Posts: 287 PA
Harry's Taxi 2
PA
should they have those tiny[EDM] holes if pushrod oiling is used ? mine don't have the holes and I don't have pushrod oiling.....no experience with pushrod oiling combined with flat tappet other than stock stuff.
[Re: cudaman1969]
#2830500
10/08/20 06:22 PM
10/08/20 06:22 PM
CSK
Pattison Texas
What does the coating look like? The ones I have look normal but used and all were turning nice. Looking to use in a street Hemi engine, cams around .500 lift (cams never been run). Maybe dual spring with damper Not sure what the coating looks like BUT you would be able to tell if it had the coating, Trend is where I got mine, you better REALLY think about using those on a street car, TRUST ME !!!! LINK TO MY STORY https://board.moparts.org/ubbthreads/ubbthreads.php/topics/2402051/flat-cam.html#Post2402051
[Re: moparx]
#2830584
10/08/20 10:13 PM
10/08/20 10:13 PM
longram60
Dunnellon, FL
should they have those tiny[EDM] holes if pushrod oiling is used ? Mine has the EDM oil hole. AMC's are pushrod oiled normally. They are uncoated but highly polished to an almost mirror finish.
[Re: DaveRS23]
#2830742
10/09/20 12:22 PM
10/09/20 12:22 PM
CSK
Pattison Texas
Maybe I've been lucky, but I have ran them in 2 street cars for several years now. A 500" wedge and a 540" Hemi. So far, so good. Thats great, Have you actually looked at the cam lobes lately , I had NO lash change, just the nose of the cam was going away
