To stroke or not to stroke? #2828359
10/03/20 05:24 PM
10/03/20 05:24 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
We found two bores that won't clean up enough to run standard bore pistons on the Imperial's 440. It's time to bore it.
I made the mistake of buying pistons based on the opinions of the last shop that had the block. They're hanging on the rods already.
Now, I get to buy pistons again.
Knowing that I want as much torque as possible but want to keep some sort of mpg, I'm fighting the question of going with a long arm on the 440.
Again, 5300 lb car built for road trips. 3.23 gears, 28.5" tall tires, and a 727. I do have a 518 and Ultrabell for an ID swap.
So, what do you folks think?
- Stu Harmon
Re: To stroke or not to stroke? [Re: feets] #2828367
10/03/20 05:45 PM
10/03/20 05:45 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
1/2" stroker, 505. Road Runner type cam might keep some semblance of mileage. The 518 might be worth a MPG on the highway?
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: To stroke or not to stroke? [Re: feets] #2828369
10/03/20 05:57 PM
10/03/20 05:57 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Fewer cubic inches requires less fuel regardless of how efficient the rest of the build is. If you can keep the cid down while increasing the efficiency of the burn, that is the best answer.
440 in my one ton crew cab did just fine with torque in reserve and mileage that was most often seen in much lighter cars. 4:11 gears with 33" tires and a 727. I'd guess its weight to have been around the 5k range, give or take a couple hundred.
Re: To stroke or not to stroke? [Re: feets] #2828393
10/03/20 07:32 PM
10/03/20 07:32 PM
Andrewh Offline
Andrewh  Offline
would sleeving to standard bore be cheaper than new pistons?
Re: To stroke or not to stroke? [Re: Andrewh] #2828397
10/03/20 07:40 PM
10/03/20 07:40 PM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
Exactly what I was wondering, too. It's about $125 a hole to sleeve here.
Master, again and still
Re: To stroke or not to stroke? [Re: DaveRS23] #2828447
10/03/20 09:54 PM
10/03/20 09:54 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Do you know for sure what size the bores would clean up at?
Has the block been sonic checked (which may be paranoia, but I always do it just to know) ?
More stroke will of course build more low-mid torque, all else being equal.
I would think a 505 would use more fuel than a 440, all else being equal, but I have no personal data on that.
That said, 440CI moves even an Imperial along pretty well on the highway.
So you might not want/need to reinvent the wheel, so to speak, let your wallet decide the sleeve/piston issue.
If that trans is a 30% reduction in RPM, that amount of OD on my 5500-5800 lb Dually (depending on what's in the bed) is worth 2-3 MPG.
Re: To stroke or not to stroke? [Re: topside] #2828475
10/03/20 11:31 PM
10/03/20 11:31 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Stroke it. That bigger cube will work less to move that car. Not hard to put together a big displacement/mild build these days. Idle at 800 rpm and pull like a freight train......can look stock as well! My buddy has a 540" Hemi in his Coronet....has a bit of a lumpy idle but looks stock as hell. Runs like a mother when he leans on it!!
Re: To stroke or not to stroke? [Re: Dcuda69] #2828482
10/04/20 12:16 AM
10/04/20 12:16 AM
Downtown Roebuck Ont
Twostick Online content
Still wishing...
Twostick  Online Content
Still wishing...
One word. Boost!!!
Orrr... 9:1 4.25 stroke 505.
500 hp and 600 ft/lbs all in by 5000 rpm on 87 regular.
Orrr... 505 cubes AND boost!!!
Kevin
Re: To stroke or not to stroke? [Re: Twostick] #2828487
10/04/20 12:58 AM
10/04/20 12:58 AM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
I understand the desire and appeal to keep the 440, but the Imperial is a big ol' CRUISER not a drag car. Drop a modern Hemi in it and be done.
twocents
John
Re: To stroke or not to stroke? [Re: SattyNoCar] #2828506
10/04/20 07:18 AM
10/04/20 07:18 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
While I'm all about torque, you do still have to have the traction to use it. It's great bragging rights to have 600 ftlbs but if you can only use 400 what's the point?
So, with the stock 440, if you could blow off the tires, why stroke it?
Maybe just sleeve the block and find some 276 gears for the freeway?
Angry white pureblood male
Re: To stroke or not to stroke? [Re: ruderunner] #2828524
10/04/20 08:56 AM
10/04/20 08:56 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Had this years ago,3.23 rear,8x20 15 tires,changed the cam,did a few other mods,saw hardly any difference in mileage and performance,5500 lbs and low compression killed it,waste of time and money. It would do 15/16 mpg hauling my 24" travel trailer as it was,that should have told me something before I started fooling with it.. shruggy
Re: To stroke or not to stroke? [Re: feets] #2828550
10/04/20 10:33 AM
10/04/20 10:33 AM
Benton, IL.
Special needs idiot
Special needs idiot
Benton, IL.
I have a 518 behind my 540 Hemi with 3.91s. I love it and am glad I went to all the effort to put it in my Cuda. And that experience causes me to ask some questions about putting a 518 behind a 440 to do that particular job.
First, someone check my math here, but isn't the final drive ratio of 3.23s with the .69 OD of the 518 something like 2.23? And I get that a 440/518/3.23 would RPM about 1,900 @ 70mph. If that's ballpark, I think there are some additional things to consider.
Is the 5,300 lb loaded or empty weight? Are you going to use a lock-up 518? If not, are you concerned that the RPM at hiway speed may allow a lot of converter slip with that much weight and pushing a lot of air? Would there be a concern that the 440's RPM would be low enough at hiway speed that it wouldn't have enough torque to pull the weight and push the air without eating a bunch of gas?
I am not saying that this combo won't work. I am only asking if it would be as efficient as the OP wants.
Re: To stroke or not to stroke? [Re: DaveRS23] #2828617
10/04/20 02:49 PM
10/04/20 02:49 PM
Still wishing...
Still wishing...
My 9:1 493 with an MP509 way wrong cam choice for bottom end torque, made 500 ft/lbs by 1500 rpm. It wasn't happy doing it but that's where no replacement for displacement pays dividends. A better choice in cam specs is all mine would need to make it tractor rpm friendly.
500 cubes will never be short on torque. Short on traction perhaps but never torque.
Kevin
Re: To stroke or not to stroke? [Re: Twostick] #2828639
10/04/20 05:10 PM
10/04/20 05:10 PM
Benton, IL.
Special needs idiot
Special needs idiot
Benton, IL.
He'll need some carb and converter work at the very least to cruise at that low an RPM. Unless he under carbs it, he will be trying to cruise on the idle circuit. And that causes some serious compromises to be made. And the converter will not even be close to fully engaged at that RPM pushing all that. Been there, done that. The OP desires economy which calls for a different set of priorities than are usually discussed here. Especially when it comes to strokers and tall gears.
I'm not saying it can't be done. Just sayin' that there will be additional things to consider with that kind of combo. Having torque to spare just moves the issues around, it doesn't necessarily cure 'em.
Re: To stroke or not to stroke? [Re: SattyNoCar] #2828724
10/04/20 09:16 PM
10/04/20 09:16 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
twocents
That was an early consideration. However, the Gen III suffers from the same issue as the earlier variants. There's nobody home down low. You have to get the revs up to find any torque. It would be a fun motor but similar to driving around a pickup.
As for my OD swap, I do have the lockup trans and converter.
Turbos have been calling me, especially since I still have them but that would be an even bigger distraction than what I've already got in front of me with the Imp and the roadster to follow.
- Stu Harmon
Re: To stroke or not to stroke? [Re: feets] #2828778
10/05/20 06:21 AM
10/05/20 06:21 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
If budget is tight then sleeve the 2 bad cylinders. If budget is not "Uncle Tony" tight then indulge in the hobby and stroke it. (If you didnt know Tony Defeo builds engines on an EXTREME budget.)
Keep old mopars alive.
Re: To stroke or not to stroke? [Re: 2boltmain] #2828794
10/05/20 08:28 AM
10/05/20 08:28 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
You mean the ones that eat themselves on the dyno like the one they tried to dyno at Nicks Garage?
Tony was a great writer for the rags and has some good ideas but his execution is lacking.
As for a mild stroker for the street, that's exactly what I built. Our 505" RB uses an 11" converter and 3.54 gear. It is a great street toy and pulls down 11 mpg on the highway with an old school carb.
We used it yesterday to beat up on full on race cars at the track and win the 11.50 index. A shot of spray has propelled it to 10.33 @ 130.
'63 Dodge 330
11.19 @ 121 mph
Re: To stroke or not to stroke? [Re: GY3] #2828878
10/05/20 11:31 AM
10/05/20 11:31 AM
Still wishing...
Still wishing...
Quote
Gotta love adding insult to injury. laugh2
Kevin
Re: To stroke or not to stroke? [Re: Twostick] #2828887
10/05/20 11:45 AM
10/05/20 11:45 AM
Richmond, Indiana
19swinger70 Offline
19swinger70  Offline
Richmond, Indiana
I think a very mild, big cubic inch engine would be a great fit for the car.
I have an Old's 455 in a '79 Trans Am that is like that. Extremely mild build, purrs like a kitten, but lays down some serious torque to get the car moving. I have highway gears in the car, and it is still a blast to drive.
1970 340 swinger. sublime
1967 barracuda fastback BB
55 Plymouth Project
Re: To stroke or not to stroke? [Re: feets] #2828897
10/05/20 12:11 PM
10/05/20 12:11 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
twocents
Sounds like you're between a rock and a hard spot. You've got a land yacht you want to accelerate like a mid-size sedan and still knock back decent MPG.
Either big block stroke it and get the down low torque, but with crap mileage, or G3 Hemi it and get the mileage, but no torque.
Have you thought about a G3 swap with a trans that has more forward gears than a 518 (my knowledge of what is available is nil)? Could make up for the lack of torque if you can slide an eight speed in. Bonus, stick as close to OEM as possible and get OEM reliability since you plan on using it as a daily driver.
