Flickering Lights #2828581
10/04/20 12:02 PM
10/04/20 12:02 PM
Mesa, Arizona
dart4forte Offline OP
Mesa, Arizona
1974 D100, lights flicker at idle. Also dash lights. New Powermaster alternator, fresh voltage regulator, starter relay etc. Did the ampmeter bypass. I’m thinking it’s a ground issue. I have ground strap frame to engine and frame to body. Also have the relays and harness from Crackedback.
Abe Lincoln
Re: Flickering Lights [Re: dart4forte] #2828596
10/04/20 01:06 PM
10/04/20 01:06 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Have you done the basic voltage checks to see what the system is doing?
Re: Flickering Lights [Re: stumpy] #2828620
10/04/20 03:04 PM
10/04/20 03:04 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
check the loom where it goes through the firewall--there is a connector post that corrodes....
Re: Flickering Lights [Re: savoy64] #2828634
10/04/20 04:26 PM
10/04/20 04:26 PM
Mesa, Arizona
Mesa, Arizona
I eliminated that connection. The wire goes through the bulkhead and out
Abe Lincoln
