Stuck Oil pressure relief valve?? #2828462
10/03/20 10:36 PM
10/03/20 10:36 PM
Wi
Scat Offline OP
Scat  Offline OP
Wi
So what are the odds of it happening. Went to fire motor tonight and it’s blew out the filter gasket with 2 filters pressure ran to 120psi then boom.
Thoughts or ideas?
73 Duster 340 a518 6pack
Re: Stuck Oil pressure relief valve?? [Re: Scat] #2828518
10/04/20 08:29 AM
10/04/20 08:29 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Factory filter mount or remote?
Re: Stuck Oil pressure relief valve?? [Re: fbs63] #2828531
10/04/20 09:20 AM
10/04/20 09:20 AM
Wi
Scat Offline OP
Scat  Offline OP
Wi
Remote. Verified all line routing on everything just to be sure it wasn’t it first
Re: Stuck Oil pressure relief valve?? [Re: fbs63] #2829214
10/06/20 10:03 AM
10/06/20 10:03 AM
Wi
Scat Offline OP
Scat  Offline OP
Wi
Ended up pulling the oil pump and swapping it and everything is back in order. 65 psi cold idle.
Re: Stuck Oil pressure relief valve?? [Re: Scat] #2842249
11/05/20 06:32 PM
11/05/20 06:32 PM
NY
X
XXHEMI Offline
XXHEMI  Offline
X
NY
What brand pump was it?
