Ebody 1970 resonator #2828425
10/03/20 08:48 PM
10/03/20 08:48 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Is the arrow on the resonator really suppose to be facing forward?
Re: Ebody 1970 resonator [Re: Sammy] #2828558
10/04/20 11:05 AM
10/04/20 11:05 AM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
arrow is for direction of flow
Re: Ebody 1970 resonator [Re: gtx6970] #2828564
10/04/20 11:25 AM
10/04/20 11:25 AM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Thats what I thought but the car i just acquired has the arrows facing forward and looked at pictures on the net and they are showing arrows pointing forward as well.
I'm confused.
Re: Ebody 1970 resonator [Re: Sammy] #2828570
10/04/20 11:38 AM
10/04/20 11:38 AM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Is there going to be a problem since the arrows are facing forward now.
I dint think ill be able to reverse them since I cinched the clamps down tight yesterday.
Don't want to ruin the new resonators and over the axle pipe now.
Haven't installed the passenger side yet.
Re: Ebody 1970 resonator [Re: Sammy] #2828589
10/04/20 12:33 PM
10/04/20 12:33 PM
WV
Little Detroit Offline
WV
all yuou have to do is remove clamp heat the cinched area red hot ,move the resonater gentely around while still red hot and should strechout the cinched area to remove,repeat if necessary , i woud use NAP gas torch intead of torches.
Re: Ebody 1970 resonator [Re: Little Detroit] #2828616
10/04/20 02:46 PM
10/04/20 02:46 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Well,I looked at the old muffler again and the arrow points to front because it says INLET on it.
Unless I'm missing something here.
