Need a thin-wall 13/16" deep socket #2828053
10/02/20 08:05 PM
10/02/20 08:05 PM
West Plains, MO
DrCharles Offline OP
West Plains, MO
I have a set of Hedman 78030 B-body headers on my low-deck, and the issues with #6 plug access are well known. I made a hole in my inner fender so at least I can get a socket on it. Since I don't have a thin forearm with two wrist joints, using a wrench from underneath is not practical. whistling
The problem is that the tube for #6 is very close to the spark plug base - and my 13/16" spark plug socket binds on the tube.
I've been googling for a 13/16" thin-wall, but almost all of them are thin-wall impact sockets which end up being the same OD. There are some wheel sockets which might work, but even with the plastic wheel protector sleeve removed, the OD is not really much thinner.
Any recommendations (even $nap-On if necessary)? Thanks. wrench
Re: Need a thin-wall 13/16" deep socket [Re: DrCharles] #2828056
10/02/20 08:16 PM
10/02/20 08:16 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Not exactly sure of the problem area but having the OD of the socket turned down would be a quick and dirty approach. or possibly even making a "special" socket might be another approach. Can you post a few pic's ?? beer
Re: Need a thin-wall 13/16" deep socket [Re: TJP] #2828065
10/02/20 08:30 PM
10/02/20 08:30 PM
New York
64 Sportfury Offline
New York
I just ran into this issue with a new set of wheels and lug nuts. I was using 1/2" drive HF deep socket and had to switch to 3/8" drive HF deep socket and it fit. It may work. Take a set of calipers and measure their sockets.
Re: Need a thin-wall 13/16" deep socket [Re: TJP] #2828086
10/02/20 09:07 PM
10/02/20 09:07 PM
Brisvegas, Australia
Alchemi Offline
Alchemi  Offline
+1
Tighten a long bolt through the middle of it, mount in in a drill (bench preferably, or grab a helper) and have at it with a angle grinder with the drill set at a very low rpm
Re: Need a thin-wall 13/16" deep socket [Re: TJP] #2828094
10/02/20 09:30 PM
10/02/20 09:30 PM
West Plains, MO
West Plains, MO
It'd be next to impossible to get a pic of that area... maybe through the hole in the fender if I took the wheel off! scope
But the description should cover it - the OD of the socket is too big and it hits the header tube, preventing it from going on fully and straight...
On FABO someone suggested these: https://www.summitracing.com/parts/pow-pow301155
But $68 for two sockets! Although it looks like it would do the job whistling
I think I'll try a friend with a lathe first smile
Re: Need a thin-wall 13/16" deep socket [Re: DrCharles] #2828107
10/02/20 10:01 PM
10/02/20 10:01 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
I don't know if it's the same problem I had years ago, but I solved it by using a
box wrench on the plug from below.
See if that's a solution.
Joe
Re: Need a thin-wall 13/16" deep socket [Re: jlatessa] #2828116
10/02/20 10:27 PM
10/02/20 10:27 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I think I'd massage the tube for a bit more clearance.
Re: Need a thin-wall 13/16" deep socket [Re: 6PakBee] #2828132
10/02/20 11:16 PM
10/02/20 11:16 PM
Guitar Jones Offline
This is my thought as well.
Re: Need a thin-wall 13/16" deep socket [Re: DrCharles] #2828133
10/02/20 11:17 PM
10/02/20 11:17 PM
If you don't want to pay $68 for two sockets then you don't want to buy a single socket from Snap On either. laugh2
Re: Need a thin-wall 13/16" deep socket [Re: Guitar Jones] #2828140
10/02/20 11:46 PM
10/02/20 11:46 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I can't really visualize the situation here, but:
Many years back I found a short plug socket that has a wrench hex on it. Has come in handy many times. Has a hollow center.
Another approach is a box wrench with the right bend.
Can you use 5/8-hex spark plugs ?
Re: Need a thin-wall 13/16" deep socket [Re: topside] #2828144
10/02/20 11:57 PM
10/02/20 11:57 PM
West Plains, MO
West Plains, MO
A smaller diameter spark plug would work - if there is one with the proper reach, seat, and heat range. Will have to look into that, thanks.
I tried clearancing the tube but I'm not going to take the header off to do it. No way to swing a ball-peen or keep the end of a bar where it needs to go while hitting the end.
Believe me, I tried.
For those recommending wrenches, when I said:
Quote
I meant that it is so difficult to reach that way that I used a hole saw on the inner fender to make an access. All the solid objects(header, motor plate, K-frame, block, etc.) are a perfect storm of getting in the way.
(Well, it can be done, I did it once, scraped up my arm and took as much time as the other 7 plugs, and decided there had to be a better approach).
Last time I bought a Snap-On socket was in the early 90's. I had a car that the shop manual even warned that a thin wall, deep, 10mm, 12 point socket is required. And they were not kidding. I think it cost me $10, nearly 30 years ago...
I'm going on a cruise with the local car club tomorrow morning, but I'll take a pic if I get a chance.
Re: Need a thin-wall 13/16" deep socket [Re: topside] #2828157
10/03/20 02:00 AM
10/03/20 02:00 AM
Dearborn Hts, MI
Sledge_57 Offline
Sledge_57  Offline
Dearborn Hts, MI
I have the same or maybe worse issue. I'm using 5/8 plugs, headers are TTI 2" - 2 1/8" step headers (never should have listened to engine builder...) TTI in their infinite wisdom didn't put a dimple in these. My old TTI's were 1 7/8" and naturally these smaller tube headers were dimpled... Go figure...
Oh and the plug boot is smashed into the header too. Takes about 10 minutes to do this to the boot. (fortunately using a straight boot (MSD) and one of those insulating sleeves seems to work but is a major pain to get on...
You CANNOT get a socket or anything on the plug without pulling the header... I'm going to try a thin wall after reading this, fingers crossed. Someday when (if) I have the energy (still messed up from chemo...) to pull the header completely out I'll dimple it.
Doing it is IMPOSSIBLE with it attached.
Here's a pic...
Doug
1967 "Pedal Car" 500" low deck , TF 727, 4.30 Locker
Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
Re: Need a thin-wall 13/16" deep socket [Re: Sledge_57] #2828160
10/03/20 04:24 AM
10/03/20 04:24 AM
Gainesville, Va.
memorylane Offline
memorylane  Offline
Gainesville, Va.
I use a pass through socket and extension, then again I use mine for almost anything lol. Love it. I got craftsman set. pretty cheap. here is a pic of pass through on a plug, you will have extension on for what you want to do. Hope this helps.
Re: Need a thin-wall 13/16" deep socket [Re: DrCharles] #2828205
10/03/20 10:07 AM
10/03/20 10:07 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Much better photo here:
https://www.amazon.com/Powerhouse-Products-POW301155-SOCKET-SPARK/dp/B002EE7A0S
Re: Need a thin-wall 13/16" deep socket [Re: 340Cuda] #2828207
10/03/20 10:12 AM
10/03/20 10:12 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
So a regular 12 pt 13/16th deepwell won't fit?
Re: Need a thin-wall 13/16" deep socket [Re: Sledge_57] #2828220
10/03/20 11:01 AM
10/03/20 11:01 AM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
I bought a cheap socket and ground down the wall thickness on about a third of it allowing about a 1/4 turn, remove reinstall do another 1/4 turn, repeat until finger tight.
the cheap sockets are easier to grind. I actually have different size sockets I've done this to, even to different depths for various projects.yard sales are good places to stock up.
Re: Need a thin-wall 13/16" deep socket [Re: Alchemi] #2828223
10/03/20 11:05 AM
10/03/20 11:05 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
+1
I have a lathe, so I just use that......... but I like your idea for those that don’t have access to one up
Re: Need a thin-wall 13/16" deep socket [Re: fast68plymouth] #2828237
10/03/20 11:38 AM
10/03/20 11:38 AM
Md.
carnut68 Online content
carnut68  Online Content
Md.
I have the same issue on #6.A body w/TTi. I ground a made in CHINA socket till it worked. There will soon be a hole in the fender well for access. I feel your pain!
America First!
Re: Need a thin-wall 13/16" deep socket [Re: fast68plymouth] #2828244
10/03/20 11:46 AM
10/03/20 11:46 AM
moparx Offline
moparx  Offline
+1
with a little effort, you can enlist a buddy and also do this with a hand drill and a 4 1/2" angle grinder. just be real careful ! smoke
beer
Re: Need a thin-wall 13/16" deep socket [Re: fast68plymouth] #2828388
10/03/20 07:19 PM
10/03/20 07:19 PM
TN Hoosier
jb500 Offline
jb500  Offline
TN Hoosier
What has saved me time and skin off my knuckles is a socket I cut down for just this issue.
Started with a 5/8 spark plug socket with 3/4 hex. Socket is .869 OD and cut it down to .950 OAL. Then opened up the ID on the drive end to .630 to fit over spark plug.
With this socket I can change plugs on my angle plug Eddy heads and Hooker Super Comps (1-7/8 tubes) on a B-Body in 30-45 min every time. Just using open and box end wrenches to grab the hex. Couldn't be any easier for me.
