Re: Wrecked in my own driveway [Re: ] #2828057
10/02/20 08:17 PM
10/02/20 08:17 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I have asthma and had to climb over the down fence to get to the driver side to see how stuck I was.I climbed out the passenger door also
Originally Posted by Superfreak
You sounded a little winded.
Re: Wrecked in my own driveway [Re: Clanton] #2828062
10/02/20 08:28 PM
10/02/20 08:28 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
B#gger
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Wrecked in my own driveway [Re: tex013] #2828083
10/02/20 09:04 PM
10/02/20 09:04 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Man that stinks. So sorry to see that happen to you and I’m glad you are ok.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Wrecked in my own driveway [Re: pittsburghracer] #2828099
10/02/20 09:44 PM
10/02/20 09:44 PM
tboomer Offline
tboomer  Offline
Sorry to see that.. down
Re: Wrecked in my own driveway [Re: tboomer] #2828104
10/02/20 09:59 PM
10/02/20 09:59 PM
New York, USA
Chargerfan68 Offline
New York, USA
So sorry to see that. Like they say, luckily you are not hurt. But, i know it hurts you. Sorry
Re: Wrecked in my own driveway [Re: Clanton] #2828111
10/02/20 10:17 PM
10/02/20 10:17 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Sorry to hear about this. Sad to see your car damaged, but good to see your ok.
Re: Wrecked in my own driveway [Re: mopar dave] #2828131
10/02/20 11:15 PM
10/02/20 11:15 PM
On the run…
BloFish Online penguin-006
BloFish  Online Penguin-006
On the run…
Sad to see that happen to anyone, glad it wasn’t worse and that you are ok.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Wrecked in my own driveway [Re: BloFish] #2828137
10/02/20 11:33 PM
10/02/20 11:33 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Not hard to fix but is a bummer to the pride... yep put the spring back on... my buddy did the
same thing but a tree got in the way scared the heck out of him
wave
Re: Wrecked in my own driveway [Re: tubtar] #2828181
10/03/20 08:22 AM
10/03/20 08:22 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Ohhhh man!! Huge OH S##T!!! moment. Certainly glad it wasn’t worse.
Re: Wrecked in my own driveway [Re: J_BODY] #2828202
10/03/20 10:03 AM
10/03/20 10:03 AM
PA
moparacer Offline
moparacer  Offline
PA
OMG. Makes me sick just looking at that.
Cars can be fixed, important thing is nobody got hurt.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Wrecked in my own driveway [Re: Clanton] #2828221
10/03/20 11:02 AM
10/03/20 11:02 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Time to fix the fence.I have a dog[Cane Corso and she needs to run in the back.I talked to the neighbor and IMO the damage may be up to 3k$ with the hvac unit and sun room wall I pushed in 3" but it is just metal frame with cheep panels but idk if parts are around for it it is older[20+yrs]Thanks again,ttyl
Re: Wrecked in my own driveway [Re: Clanton] #2828245
10/03/20 11:50 AM
10/03/20 11:50 AM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Turn it in to your homeowners insurance. I hit my own garage door and they covered a new one. Never know it may be worth a try -- shruggy
Re: Wrecked in my own driveway [Re: max_maniac] #2828409
10/03/20 08:03 PM
10/03/20 08:03 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Thanks I will give that a try.
Re: Wrecked in my own driveway [Re: Clanton] #2828516
10/04/20 08:04 AM
10/04/20 08:04 AM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
did you video,the actual part where the car was pushing thru the brakes and crashing in to the fence? please keep that return spring on when starting and running the car.
Re: Wrecked in my own driveway [Re: Sammy] #2828542
10/04/20 10:10 AM
10/04/20 10:10 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
The spring is back on the car.No I did not record the crash because I had recorded several other videos and felt I shared enough.IDK if I want to relive the crash watching it on video again and again.I am sick just thinking of it.I can still run the car like it is all though not pretty I will get to it.
Re: Wrecked in my own driveway [Re: Clanton] #2846495
11/15/20 11:38 AM
11/15/20 11:38 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
This is just an update so you can see what you could be dealing with having no insurance.Fixing my neighbors house is costing upwards of 7K$ with sunroom parts no longer being made so I am looking at custom fabrication and a problematic neighbor so this is going to drag out.
Re: Wrecked in my own driveway [Re: Clanton] #2846571
11/15/20 01:48 PM
11/15/20 01:48 PM
tboomer Offline
tboomer  Offline
Ouch...
Re: Wrecked in my own driveway [Re: Clanton] #2846626
11/15/20 03:20 PM
11/15/20 03:20 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
On a good note I will be ready with the car in the spring to tune at the track after I get some slicks.I did order a patch for the rear qtr bentup .-R&c[0]=AT0DW1E9ew6x2oBWV4eXiBd...4EFjO8VVMO8I_uMZCkb6xneEFls8UY]qtr patch
Re: Wrecked in my own driveway [Re: tboomer] #2846628
11/15/20 03:23 PM
11/15/20 03:23 PM
Spring Hill Fl
65Fury440 Offline
65Fury440  Offline
Spring Hill Fl
Sorry to see that OP.
2020 was a total crap sandwich for a lot of people, looks like you got your fair share.
Sending positive vibes your way.
Beautiful car BTW
Re: Wrecked in my own driveway [Re: 65Fury440] #2846665
11/15/20 04:49 PM
11/15/20 04:49 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Beautiful car BTW
Thank you,Back at ya for the good vibes
