Need a thin-wall 13/16" deep socket
#2828053
10/02/20 08:05 PM
10/02/20 08:05 PM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
I have a set of Hedman 78030 B-body headers on my low-deck, and the issues with #6 plug access are well known. I made a hole in my inner fender so at least I can get a socket on it. Since I don't have a thin forearm with two wrist joints, using a wrench from underneath is not practical. ![whistling whistling](/ubbthreads/images/graemlins/custom/whistling.gif) The problem is that the tube for #6 is very close to the spark plug base - and my 13/16" spark plug socket binds on the tube. I've been googling for a 13/16" thin-wall, but almost all of them are thin-wall impact sockets which end up being the same OD. There are some wheel sockets which might work, but even with the plastic wheel protector sleeve removed, the OD is not really much thinner. Any recommendations (even $nap-On if necessary)? Thanks. ![wrench wrench](/ubbthreads/images/graemlins/custom/wrench.gif)
Re: Need a thin-wall 13/16" deep socket
[Re: TJP]
#2828086
10/02/20 09:07 PM
10/02/20 09:07 PM
Posts: 234 Brisvegas, Australia
Alchemi
Not exactly sure of the problem area but having the OD of the socket turned down would be a quick and dirty approach. or possibly even making a "special" socket might be another approach. Can you post a few pic's ?? +1 Tighten a long bolt through the middle of it, mount in in a drill (bench preferably, or grab a helper) and have at it with a angle grinder with the drill set at a very low rpm
[Re: TJP]
#2828094
10/02/20 09:30 PM
10/02/20 09:30 PM
DrCharles
West Plains, MO
Not exactly sure of the problem area but having the OD of the socket turned down would be a quick and dirty approach. or possibly even making a "special" socket might be another approach. Can you post a few pic's ?? It'd be next to impossible to get a pic of that area... maybe through the hole in the fender if I took the wheel off! ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) But the description should cover it - the OD of the socket is too big and it hits the header tube, preventing it from going on fully and straight... On FABO someone suggested these: https://www.summitracing.com/parts/pow-pow301155But $68 for two sockets! Although it looks like it would do the job ![whistling whistling](/ubbthreads/images/graemlins/custom/whistling.gif) I think I'll try a friend with a lathe first ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif)
[Re: DrCharles]
#2828107
10/02/20 10:01 PM
10/02/20 10:01 PM
Posts: 1,319 Ohio
jlatessa
Ohio
I don't know if it's the same problem I had years ago, but I solved it by using a box wrench on the plug from below.
See if that's a solution.
Joe
[Re: jlatessa]
#2828116
10/02/20 10:27 PM
10/02/20 10:27 PM
Posts: 10,778 North Dakota
6PakBee
North Dakota
I think I'd massage the tube for a bit more clearance.
[Re: 6PakBee]
#2828132
10/02/20 11:16 PM
10/02/20 11:16 PM
Posts: 20,702 in a cattle trailer down by th...
Guitar Jones
I think I'd massage the tube for a bit more clearance. This is my thought as well.
[Re: DrCharles]
#2828133
10/02/20 11:17 PM
10/02/20 11:17 PM
Guitar Jones
Not exactly sure of the problem area but having the OD of the socket turned down would be a quick and dirty approach. or possibly even making a "special" socket might be another approach. Can you post a few pic's ?? It'd be next to impossible to get a pic of that area... maybe through the hole in the fender if I took the wheel off! ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) But the description should cover it - the OD of the socket is too big and it hits the header tube, preventing it from going on fully and straight... On FABO someone suggested these: https://www.summitracing.com/parts/pow-pow301155But $68 for two sockets! Although it looks like it would do the job ![whistling whistling](/ubbthreads/images/graemlins/custom/whistling.gif) I think I'll try a friend with a lathe first If you don't want to pay $68 for two sockets then you don't want to buy a single socket from Snap On either. ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif)
[Re: topside]
#2828144
10/02/20 11:57 PM
10/02/20 11:57 PM
DrCharles
West Plains, MO
A smaller diameter spark plug would work - if there is one with the proper reach, seat, and heat range. Will have to look into that, thanks. I tried clearancing the tube but I'm not going to take the header off to do it. No way to swing a ball-peen or keep the end of a bar where it needs to go while hitting the end. Believe me, I tried. For those recommending wrenches, when I said: Since I don't have a thin forearm with two wrist joints, using a wrench from underneath is not practical. I meant that it is so difficult to reach that way that I used a hole saw on the inner fender to make an access. All the solid objects(header, motor plate, K-frame, block, etc.) are a perfect storm of getting in the way. (Well, it can be done, I did it once, scraped up my arm and took as much time as the other 7 plugs, and decided there had to be a better approach). Last time I bought a Snap-On socket was in the early 90's. I had a car that the shop manual even warned that a thin wall, deep, 10mm, 12 point socket is required. And they were not kidding. I think it cost me $10, nearly 30 years ago... I'm going on a cruise with the local car club tomorrow morning, but I'll take a pic if I get a chance.
[Re: topside]
#2828157
10/03/20 02:00 AM
10/03/20 02:00 AM
Posts: 4,027 Dearborn Hts, MI
Sledge_57
Dearborn Hts, MI
I can't really visualize the situation here, but: Many years back I found a short plug socket that has a wrench hex on it. Has come in handy many times. Has a hollow center. Another approach is a box wrench with the right bend. Can you use 5/8-hex spark plugs ? I have the same or maybe worse issue. I'm using 5/8 plugs, headers are TTI 2" - 2 1/8" step headers (never should have listened to engine builder...) TTI in their infinite wisdom didn't put a dimple in these. My old TTI's were 1 7/8" and naturally these smaller tube headers were dimpled... Go figure... Oh and the plug boot is smashed into the header too. Takes about 10 minutes to do this to the boot. (fortunately using a straight boot (MSD) and one of those insulating sleeves seems to work but is a major pain to get on... ![[Linked Image]](https://i.imgur.com/hESoNLr.jpg) You CANNOT get a socket or anything on the plug without pulling the header... I'm going to try a thin wall after reading this, fingers crossed. Someday when (if) I have the energy (still messed up from chemo...) to pull the header completely out I'll dimple it. Doing it is IMPOSSIBLE with it attached. Here's a pic... ![[Linked Image]](https://i.imgur.com/X9gdn3K.jpg)
Doug
1967 "Pedal Car" 500" low deck , TF 727, 4.30 Locker Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
[Re: DrCharles]
#2828205
10/03/20 10:07 AM
10/03/20 10:07 AM
Posts: 3,529 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
Not exactly sure of the problem area but having the OD of the socket turned down would be a quick and dirty approach. or possibly even making a "special" socket might be another approach. Can you post a few pic's ?? It'd be next to impossible to get a pic of that area... maybe through the hole in the fender if I took the wheel off! ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) But the description should cover it - the OD of the socket is too big and it hits the header tube, preventing it from going on fully and straight... On FABO someone suggested these: https://www.summitracing.com/parts/pow-pow301155But $68 for two sockets! Although it looks like it would do the job ![whistling whistling](/ubbthreads/images/graemlins/custom/whistling.gif) I think I'll try a friend with a lathe first Much better photo here: https://www.amazon.com/Powerhouse-Products-POW301155-SOCKET-SPARK/dp/B002EE7A0S
[Re: Alchemi]
#2828223
10/03/20 11:05 AM
10/03/20 11:05 AM
Posts: 14,515 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Not exactly sure of the problem area but having the OD of the socket turned down would be a quick and dirty approach. or possibly even making a "special" socket might be another approach. Can you post a few pic's ?? +1 Tighten a long bolt through the middle of it, mount in in a drill (bench preferably, or grab a helper) and have at it with a angle grinder with the drill set at a very low rpm I have a lathe, so I just use that......... but I like your idea for those that don’t have access to one ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
[Re: fast68plymouth]
#2828237
10/03/20 11:38 AM
10/03/20 11:38 AM
Posts: 3,262 Md.
carnut68
Md.
I have the same issue on #6.A body w/TTi. I ground a made in CHINA socket till it worked. There will soon be a hole in the fender well for access. I feel your pain!
America First!
#2828244
10/03/20 11:46 AM
10/03/20 11:46 AM
Posts: 19,696 north of coder
moparx
Not exactly sure of the problem area but having the OD of the socket turned down would be a quick and dirty approach. or possibly even making a "special" socket might be another approach. Can you post a few pic's ?? +1 Tighten a long bolt through the middle of it, mount in in a drill (bench preferably, or grab a helper) and have at it with a angle grinder with the drill set at a very low rpm I have a lathe, so I just use that......... but I like your idea for those that don’t have access to one with a little effort, you can enlist a buddy and also do this with a hand drill and a 4 1/2" angle grinder. just be real careful ! ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
