Scarebird Rear Disc and Hydro-Boost #28280
07/07/06 05:11 PM
07/07/06 05:11 PM
San Jose, CA
Blue69Charger Offline OP
San Jose, CA
I just finished installing the scarebird rear disc conversion on my 69 charger. With the mopar actions 11.75" disc swap in the front it stops like a modern car. The install was easy and straightforward. One thing that was not mentioned was enlarging the holes to 5/8". The booster is off a '98 astro. It wasn't too hard to setup. The hardest thing to figure out was how to hook it up to the brake pedal. I used a 2 1/2" pedal rod extension with a 7/16" hole. They can be obtained from the street rod catalog with a 3/8" or pre-drilled from master power. I used a 7/16" by 1 1/4" clevis pin with some washers to hook it up to the pedal. The hydro-boost rod needs to be threaded to 3/8-24. I used russell powerflex hose and aeroquip fittings from summit racing. The master cylinder is off a '94 c2500. I bought it for $10 new from eBay. There seems to be alot of cheap new ones on there. I made the bracket out of aluminum flat bar, but it could easily be made out of steel flat stock like Ira's converison. It took me 15-20 hours to machine and polish. If you need a socket to remove the hydro-boost nut, factory five sells one much cheaper than the GM tool. Out of curiosity I weighed the drum booster, 76 charger master cylinder and cadillac vacuum pump I was using before and it was 6 lbs heavier than my current setup.
Re: Scarebird Rear Disc and Hydro-Boost [Re: Blue69Charger] #28281
07/07/06 05:11 PM
07/07/06 05:11 PM
San Jose, CA
San Jose, CA
Here is a picture of the booster and master cylinder.
Re: Scarebird Rear Disc and Hydro-Boost [Re: Blue69Charger] #28282
04/04/09 07:56 PM
04/04/09 07:56 PM
Edmonton, Alberta, Canada
Dartman75 Offline
Dartman75  Offline
wrong thread...
Re: Scarebird Rear Disc and Hydro-Boost [Re: Blue69Charger] #28283
04/05/09 07:14 PM
04/05/09 07:14 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
sorry CANT help you with your ?? but i do have a ?? myself.
Can the hydro boost be used with disc/drum setup? if so whats needed to do the swap?
Re: Scarebird Rear Disc and Hydro-Boost [Re: Blue69Charger] #28284
04/05/09 07:52 PM
04/05/09 07:52 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Looks great! Got a picture of the lines going into and out of the pump? What did you use for those?
I just noticed how old this thread was
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Scarebird Rear Disc and Hydro-Boost [Re: Blue69Charger] #28285
04/06/09 02:00 PM
04/06/09 02:00 PM
Dartman75 Offline
Dartman75  Offline
This is an old thread and I didn't mean to dredge it up. It's linked from this newer thread, and I was posting some more resources I found as I start to embark on this conversion for my car.
Plumbing diagrams and info can be found on the various links, including some part numbers for line fittings etc.
https://board.moparts.org/ubbthreads/show...&PHPSESSID=
Greg
Re: Scarebird Rear Disc and Hydro-Boost [Re: Dartman75] #28286
01/23/12 11:35 AM
01/23/12 11:35 AM
Mrytle Beach SC
johnscudashop Offline
Mrytle Beach SC
I have the Hydroboost nut socket tools available they are $60 shipped USA 843-324-3586 M-F 8-5 EST , jrivinius@sc.rr.com or www.custommachinecomponents.com I take paypal or MO
Re: Scarebird Rear Disc and Hydro-Boost [Re: johnscudashop] #28287
01/23/12 11:36 AM
01/23/12 11:36 AM
Mrytle Beach SC
Mrytle Beach SC
other side
