Experimenting with quench. #2827537
10/01/20 07:00 PM
10/01/20 07:00 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
I'm finally getting around to putting together the engine for my Imperial. It's not a high-zoot almighty power house but it needs to fit the application.
That application is a 440 powered 5300 lb land yacht with a 727, 3.23 gears, and 29" tall tires. It needs to be able to cruise anywhere I care to go and will need to survive on 91 octane.
This is the first time I've built an engine for this kind of application and I'd like to know if I'm pushing things a bit too far.
Here's the parts I've got on hand:
Eddy Performer heads (early production).
Icon flat top pistons
Stock block, crank, and rods
Cometic 0.027" head gaskets
CH4B intake (possibly swapping to Performer 440) - no hood clearance for a Performer RPM frown
Carb: TBD. Will likely change to throttle body injection after the engine is installed.
Headman 1-3/4" mid length headers with 2-1/2" collectors and 2-1/2" dual exhaust
I measured the assembled piston height, combustion chamber, and all other bits involved. This presents me with 0.036" quench and 10.2 compression.
So good so far.
Now for the cam. It's a highway cruising stick ground for heavy torque to get this beast moving and hold it there climbing hills at highway speed.
Duration @ .050" 218 - 218
Duration @ .006" 261 - 261
Gross lift .463" - .463"
Separation 110
Intake open 3 BTDC close 35 ABDC
Exhaust open 43 BBDC close 5- ATDC
This little stick should purr like a kitten (and bore you to sleep with the exhaust note) while making good vacuum and working from 1500 to 5000 rpm.
Will this little guy make too much cylinder pressure?
Will the aluminum heads and quench work together to reduce the chance of detonation?
If I have to run the timing back a little to control detonation will I be giving up more efficiency (read: torque) than I would by reducing the compression with a thicker head gasket?
I don't mind it being a premium gas engine as long as it delivers the performance I want. My wet dream is 500 lb/ft down low and maybe, just maybe 400 hp around 5200 at the crank.
I do plan on doing a cam break in and basic tune on the engine dyno before installation.
- Stu Harmon
Re: Experimenting with quench. [Re: feets] #2827540
10/01/20 07:06 PM
10/01/20 07:06 PM
I think your dreams are achievable up twocents
Have fun cruising around in it up
BTW, do you have your captains license to be able pilot that yacht lawfully whistling
Re: Experimenting with quench. [Re: feets] #2827542
10/01/20 07:07 PM
10/01/20 07:07 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I think it will work great, the only way to know is to just do it.
Re: Experimenting with quench. [Re: CSK] #2827561
10/01/20 08:09 PM
10/01/20 08:09 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I ran down to .027 on a 318 with closed chamber heads milled .030 and flat top pistons with no valve reliefs and stock 5.9 magnum cam. It had lots of low end TQ, great MPG and never a sign of pinging towing a car out of LA on an open car trailer on those big passes. Oh and it was 87 octane. I think it was around 11.5 compression. With closed chamber aluminum heads, .030 clearance (set piston to wall clearance on the tight side to minimize piston rock) and a slightly bigger than stock cam I bet you would be fine running 11 to 1 in a 440. The stock beer barrel intake I was running absolutely bakes the air entering the cylinder head.
Re: Experimenting with quench. [Re: HotRodDave] #2827626
10/01/20 09:46 PM
10/01/20 09:46 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
I think it looks like a nice setup for what you want to do.
I would personally install it at 108 icl instead of 106.
Re: Experimenting with quench. [Re: feets] #2827650
10/01/20 11:20 PM
10/01/20 11:20 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
Don't know how many times I have posted this, but, your engine sounds like a good combination. If you want some peace of mind before spending the time and money, buy a good engine program, and run your combination. I use performance trends, it will calculate a timing curve, predict detonation, for different octane fuels, cranking compression, idle vacuum, etc. etc. I have built a lot of engines using this program, and they are always close on a real dyno. And the manual that comes with it will teach you tons about the science of how an engine works.
Re: Experimenting with quench. [Re: INTMD8] #2827654
10/01/20 11:38 PM
10/01/20 11:38 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
10.2 CR and aluminum heads with tight quench should live a nice long happy life on pump gas especially if you add engine management to the equation.
Kevin
Re: Experimenting with quench. [Re: jwb123] #2827668
10/02/20 01:10 AM
10/02/20 01:10 AM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
I wasn't happy with the deck so I dropped the block off at a well known shop. The man running the place has been at it nearly as long as I've been alive. He is a man of few words but made more than one comment about needing to drop the compression or add more cam. It made me a bit paranoid.
- Stu Harmon
Re: Experimenting with quench. [Re: feets] #2827686
10/02/20 03:22 AM
10/02/20 03:22 AM
Boise
Moparteacher Offline
Boise
Stay with the CH4B.
Re: Experimenting with quench. [Re: feets] #2827798
10/02/20 11:03 AM
10/02/20 11:03 AM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
10.2 with an iron head and a cam that makes cylinder pressure might be iffy on 91 but with an aluminum head it should behave like it has 9.2.
Kevin
Re: Experimenting with quench. [Re: feets] #2827865
10/02/20 12:59 PM
10/02/20 12:59 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Slightly off topic.
New York cab drivers must be the best in the world, they do millions of miles.
No, they just make the same mistakes millions of times.
Boffin Emeritus
