295/60r15 D/R S/B what’s your combo/ times
#2826955
09/30/20 02:51 PM
09/30/20 02:51 PM
Posts: 1,390 CA.
RAY1969CARS
CA.
Re: 295/60r15 D/R S/B what’s your combo/ times
[Re: RAY1969CARS]
#2827027
09/30/20 06:17 PM
09/30/20 06:17 PM
Posts: 861 lancaster,california
johnnycuda
I have only been out a couple times with my Cuda, but it ran 10.77 @ 125 at Fontana, car is over 3800lbs with me in it. A '70 'Cuda, 493, Indy SR heads, .600 lift roller, 10.5 comp., 950HP on a Indy single plane, 2" header, 4.56 gear, pump gas, 91 octane swill. The car has CalTracs/springs/shocks. The convertor is really tight and will only footbrake like 2000, so I leave at 1500, flashes a little over 3000. When I ordered it I wanted to footbrake 3000 and flash 4000-4500, but didn't happen. When I ordered it I mentioned I maybe adding a Gear Vendor, so maybe they made it tight for that, Continental made it, 9.5", had it like 10-12 years I think.
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT! 1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air, New daily driver-2003 Ram 2500 Cummins 5.9 '69 Valiant 2-dr, sleeper! New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
[Re: RAY1969CARS]
#2827219
10/01/20 08:45 AM
10/01/20 08:45 AM
Posts: 13,387 Marion, South Carolina [><]
an8sec70cuda
Do you mean the 295-65 or the 295-50 radial? I don't think they make a 295-60 drag radial. I run the M/T 295-65, but not a small block. I've been a good bit quicker in the 1/8 mile since I ran the 8.91 in the 1/4...just haven't made a 1/4 mile pass lately.
[Re: RAY1969CARS]
#2827252
10/01/20 09:53 AM
10/01/20 09:53 AM
Posts: 1,178 Indy
FlyFish
Indy
Well, I have a 275/60/r15 tire small block (close enough??). It runs 1.38 60’, 6.44 @ 105.9, 10.19 @ 130.5 in cool air, 6.5x’s and 10.3x’s in the heat.
Combo: 67 Barracuda, 3250 lbs, 408 stroker, e85, ported Edelbrock heads, Hughes solid FT cam 264/268 @0.05, Victor intake, home built 750dp e85 carb, 13.1 compression, 727, TA manual valve body, 8” PTC converter, 8 ¾ (MO875), spool, 4.10 gears, Hoosier 275/60/r15 DR.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
[Re: FlyFish]
#2827361
10/01/20 12:39 PM
10/01/20 12:39 PM
Posts: 4,701 Wichita
GY3
Wichita
Combo: 67 Barracuda, 3250 lbs, 408 stroker, e85, ported Edelbrock heads, Hughes solid FT cam 264/268 @0.05, Victor intake, home built 750dp e85 carb, 13.1 compression, 727, TA manual valve body, 8” PTC converter, 8 ¾ (MO875), spool, 4.10 gears, Hoosier 275/60/r15 DR. I'm running almost identical times and mph on a 275 ET Street Pro. I drive it the way I race it save for shock adjustment in the rear to soften it up on the street.
